Um im thinking the head was shaved .020 off. The bore is .020 over as well. the cam is EngnBldrs rv 268° .425 cam.
What will lowering the float do for me?
Just purchased the fuel mileage/ elevation kit from lc, hope this fixes it.
i would look into finding a shim headgasket, .020 is way too much to remove from a head unless your gonna be running methanol or propaneyou will definitely need a adjustable cam gear and you'll need to dial in the cam timing because otherwise you'll be about half a tooth or more off on the cam timing
Sorry 79, that was a typo. The head was shaved .005 down to true it up. my bad.
OK, ill write down the jet number when I get the kit. Are the numbers stamped onto them or something?
Ok the fuel mileage kit showed up today and I tore into. My current factory jets are as follows.Primary fuel-140secondary fuel-150primary air-170secondary air-180primary idle-60secondary idle-50let me know what you thin that I need to do.Also on a odd side not, I reinstalled the fpr that I've got and turned it to the 3psi mark and it starves the engine. It even starves the truck at the 5.5 max mark.
Ok, I just reinstalled the fpr and 4 turns out is the best spot to get it to run with the fpr set at 3 psi
Started by hacksaw Parts For Sale
Started by ajkretchmer Parts Wanted
Started by BigMikeyC Engine
Started by Rocksurfer Parts For Sale
Started by Jason E. « 1 2 » Engine
