Author Topic: front axel widening  (Read 11853 times)
E YOTA
  • Male Posts: 690
  • Member since Jan '04
front axel widening
« on: Aug 23, 2010, 09:31:05 PM »
can u use really use ifs hubs to widen the width or wats the trick here?
built lastnight, crawl today...
NCK4L
  • Turtle Points: -2
  • Male Posts: 522
  • Member since Oct '08
Re: front axel widening
« Reply #1 on: Aug 23, 2010, 10:15:03 PM »
i think the tacoma rotor mod is the easiest thing to do to widen your front end. Every way out there still strains your bearings though . the only true way to do is widen your housing
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
drayday55
  • Turtle Points: -1
  • Male Posts: 299
  • Member since Feb '09
« Reply #3 on: Aug 23, 2010, 10:32:04 PM »
i have the front range Tacoma break kit on my 85 and it is one of the best mods i have done.
i just test drove a 85 4 runner with high steer fj rotors and ifs calipers (same as my old setup) with land cruiser master and i felt like it would not stop!
i let the guy drive my truck and he was sold on the kit!
my set up is 92 4 runner master and booster, tied up lspv, front range brackets for callipers, swap knuckles from driver to passenger, ifs hub turned down to fit inside a factory 2000 tacoma rotor, and tacoma calipers.
added bonus is to change the birf all you have to do is take off the hub dial. pull the snap ring and remove the 8 bolts holding the spindle on the knuckles. !!!!!  no wheel bearings need to be touched!!!
also to do a brake job, just pull the caliper!!
only way to fly!
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
    • Buy me a drink
« Reply #4 on: Aug 23, 2010, 11:19:38 PM »
only way to fly!
Sold me!
E YOTA [OP]
  • Male Posts: 690
« Reply #5 on: Aug 24, 2010, 09:26:48 PM »
u have any pics of that mod. and do it widen your axel too or do u have to do the ifs hubs....
« Last Edit: Aug 24, 2010, 10:05:32 PM by toyrider »
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #6 on: Aug 24, 2010, 10:43:20 PM »
Here is a link to the FROR kit that uses IFS hubs and Tacoma calipers and rotors. This is a sweet set-up and makes serviceing the axle a breeze.
http://frontrangeoffroadfab.com/nfoscomm/catalog/product_info.php?products_id=136&osCsid=f750ba8ae86c20a3f6aafb30de3289a9
hilux-1983
  • Turtle Points: 3
  • Male Posts: 1,271
  • Member since Apr '09
« Reply #7 on: Aug 25, 2010, 11:10:58 AM »
 :biggthumpup:
earfarmer
  • Member since Aug '10
« Reply #8 on: Aug 25, 2010, 11:42:31 AM »
Thanks for info!! :D
MeSwoleShane
  • Turtle Points: -1
  • Member since Jun '10
« Reply #9 on: Aug 25, 2010, 01:33:08 PM »
You can use stock ifs hubs and calipers with taco rotors and bolt the caliper from the other side and it will do the same as this but not cost anything!
drayday55
  • Turtle Points: -1
  • Male Posts: 299
« Reply #10 on: Aug 27, 2010, 11:06:29 PM »
really, is this common? i have not heard about it.  id like to see it though,
  • Turtle Points: 1128
  • Male Posts: 9,757
« Reply #11 on: Aug 28, 2010, 01:30:40 AM »
Ditto, I need to see that!
On the fror kit, I saw lc engineering has a tacoma brake upgrade that includes tundra calipers (didn't say mods were needed so should bolt up the same) and slightly larger vented rotors.  It's spendy, but it sounds like you could combine this with the fror kit and have phenominal front brakes!  Might be able to snag the rotors separately, get some tundra calipers and save a bit of money over their kit too.
WHITE_TRASH
  • Turtle Points: 679
  • Member since Feb '03
« Reply #12 on: Aug 28, 2010, 04:03:57 AM »
I've done that setup on a friends truck.  It works just ok but the taco rotors are the same diameter as 86-95 IFS which is about 1/2" smaller OD than solid axle or FJ40-80 rotors.  You actually lose braking force rather than gain it by going to a smaller rotor and less pad contact.  Anyone that thinks they are getting better brakes due to anything but using a V6 caliper is delusional plain and simple.
Nate it's the same as the standard IFS hub swap but rather than machining the caliper to get proper rotor centering you add washers.  I ended up using one standard bulk washer and one thinner machine washer to get proper spacing.  Works fine for a wheeler.
MeSwoleShane
  • Turtle Points: -1
« Reply #13 on: Aug 31, 2010, 08:08:47 AM »
Here are a few pics of my set-up
I got the idea from a guy on Pirate
I used the 4 large piston calipers with taco rotors. I just ground the outside of the IFS hub to let the taco rotor slide over it. I just left it on the IFS spindles and pressed hard with a grinder so it spun while I pressed. Ground evenly this way. I just bolted it from the other direction. I used a washer to space it evenly, you can barely see it in the pics. Works great, I have tested with many hard stops on 35's.
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #14 on: Aug 31, 2010, 10:57:51 AM »
2000 Totota Tacoma 4x4 Front Rotors - $37/ea at Oreilly Auto :]
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #15 on: Sep 04, 2010, 11:17:17 PM »
Got my Taco Rotors today, picking up flat washers, bolts and nuts and getting the pass side done. :] much easier then the previous IFS hub conversion i did! And grinding down the Hub wasnt that bad either.
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #16 on: Sep 05, 2010, 05:09:35 PM »
Just an added info piece.
Using IFS Hubs and FJ Rotors, your WMS-WMS is 58.25in
Using IFS Hubs and Taco Rotors, your WMS-WMS is 58.75in.
So now your front is .25in wider then an IFS Rear instead of .25in narrower.
and changing a Birf will be a SNAP!
I just got done dry fitting and bolting on the pass side. Looks awesome.
drayday55
  • Turtle Points: -1
  • Male Posts: 299
« Reply #17 on: Sep 05, 2010, 09:45:22 PM »
nice work!
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #18 on: Sep 05, 2010, 09:51:17 PM »
tomorrow when i have good lighting... ill post some pics.
possume22
« Reply #19 on: Sep 05, 2010, 10:18:02 PM »
i just used the ifs hubs and solid axel brakes and rotots
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #20 on: Sep 05, 2010, 10:22:11 PM »
you had to do more machine work though. i did the IFS hubs, FJ rotors and V6 Calipers on my 90 4runner and that was the biggest PITA of a conversion. this is MUCH cleaner and straight forward. and makes changing birfs and rotors... a BREEZE!
I can do a walk-thru if anyone is interested.
PBrown
  • Turtle Points: 27
  • Male Posts: 100
  • Member since Jul '10
« Reply #21 on: Sep 05, 2010, 10:29:22 PM »
I'm in. I would like to do this to mine in the. Near future.
91 reg cab sas, duals 4.7, 5.29s, detroits, 35s, bunch of marlin debt.
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
  • Member since Sep '09
    • Poly Goats
« Reply #22 on: Sep 05, 2010, 10:32:42 PM »
Do it  :thumbs: I'm really interested in this swap, just not sure how its done.
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #23 on: Sep 05, 2010, 10:36:25 PM »
I will do one tomorrow with pics. its straight forward.
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
    • Poly Goats
« Reply #24 on: Sep 05, 2010, 10:59:44 PM »
Cool cool, looking forward to it. Did you use the fror kit?
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #25 on: Sep 06, 2010, 01:55:54 AM »
No kit or brackets
-Jake-
  • Turtle Points: 9
  • Male Posts: 538
  • Member since Oct '09
« Reply #26 on: Sep 06, 2010, 09:54:07 AM »
i did the ifs hub/taco rotor a year ago to my truck and its still problem free heres the build thread with details on how to do the swap.
http://board.marlincrawler.com/index.php?topic=63910.0
check out reply #8 for the write-up  :thumbs:
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #27 on: Sep 06, 2010, 10:48:21 AM »
Hey Jake, I forgot about yours!
Only difference is I barely did any grinding on the caliper, in fact i used a flap disk on bleeder half of the caliper and clearenced it just a hair. everything else was straight forward. I was kind of surprised on how much material needs to be removed on the hub.
-Jake-
  • Turtle Points: 9
  • Male Posts: 538
« Reply #28 on: Sep 06, 2010, 11:25:57 AM »
Yeah, I only had to grind the drivers side, the passenger side fit perfect.
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #29 on: Sep 06, 2010, 11:33:00 AM »
Strange... lol
Last post Aug 04, 2004, 06:08:30 PM
by 5spd
Last post Dec 17, 2004, 07:59:45 PM
by Charles
Last post Apr 28, 2005, 06:36:40 PM
by 86yota
Last post Dec 24, 2008, 05:58:45 PM
by 79coyotefrg
Last post Mar 25, 2009, 04:05:26 PM
by COToy91
