Author Topic: front axel widening  (Read 11838 times)
Digwoods01
  • Male Posts: 16
  • Member since Oct '07
Re: front axel widening
« Reply #30 on: Sep 06, 2010, 01:42:47 PM »
i was just wondering if that was possible
MeSwoleShane
  • Turtle Points: -1
  • Member since Jun '10
« Reply #31 on: Sep 07, 2010, 08:16:10 AM »
Jake is the guy on pirate I got the idea from. Great idea man.
MeSwoleShane
  • Turtle Points: -1
« Reply #32 on: Sep 07, 2010, 08:20:03 AM »
You can also replace lugs by just taking the tires off. There is enough room to slide new ones in from the back. I drive just over 90 miles a day in my 4runner on 35's and this brake setup has given me no problems.
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
  • Member since Jun '07
    • Buy me a drink
« Reply #33 on: Sep 07, 2010, 09:57:32 AM »
Sorry for the stall guys, i got a digital from my GF last night so ill be taking good photos today and make a detailed walkthru.
I can't wait to try out 4-Wheel Disc brakes!
PBrown
  • Turtle Points: 27
  • Male Posts: 100
  • Member since Jul '10
« Reply #34 on: Sep 07, 2010, 09:59:16 AM »
Sweet. I need to see how this is done
91 reg cab sas, duals 4.7, 5.29s, detroits, 35s, bunch of marlin debt.
blue_toy
  • Member since Mar '06
  • 85' w/39"s dual cases, 4.7, ARB, 63" rears, was2wd
« Reply #35 on: Sep 13, 2010, 08:31:15 AM »
Will check back for pics
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #36 on: Sep 13, 2010, 03:09:23 PM »
Been super busy guys and waitin on my knuckle seal kit to assemble this. I will get postin on this. as I am doing a taco rotor/ifs caliper conversion on the rear as well. so ill post up pics asap.
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #37 on: Sep 13, 2010, 03:11:30 PM »
Here are two crappy pics I did manage to take on the driver side. ill document the pass side once I start it.
Oddmar
  • Turtle Points: 74
  • Male Posts: 402
  • Member since Aug '04
  • J3 Productions
« Reply #38 on: Sep 16, 2010, 09:17:05 AM »
I wanna do this too.
Is the caliper cast steel or cast iron? Could i weld the nuts to the caliper ears so i just put the bolts in and tighten?
I'm big on welding nuts to stuff so i don't have to use two wrenches.
I recently rebuilt a frame and welded nuts to the frame mounts for the bed. Then i drilled holes down through the bed so you just drop the bolts in through the top like on a Ford Ranger bed.
The United States Constitution © 1791. All Rights Reserved.
Only when i am finished will there be peace: The peace of an empty wind as it blows across a land strewn with the bones of my enemies.
SloCrawler
  • Turtle Points: -116
  • Male Posts: 1,333
  • Member since Mar '08
    • http://board.marlincrawler.com/index.php?topic=60800.msg856812#msg856812
« Reply #39 on: Sep 16, 2010, 09:19:39 AM »
Nice mod
MeSwoleShane
  • Turtle Points: -1
« Reply #40 on: Sep 16, 2010, 02:35:58 PM »
No nut needed. Just put the bolt in from the other side.
Oddmar
  • Turtle Points: 74
  • Male Posts: 402
  • J3 Productions
« Reply #41 on: Sep 16, 2010, 04:52:06 PM »
I saw you did that, but i'd rather be able to slip the caliper on normally and put the bolt in (like THK did), rather than juggle the rotor and caliper while trying to start the bolt in backwards from behind the rotor.
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #42 on: Sep 16, 2010, 08:11:03 PM »
I think you should be able to weld nuts to the calipers. dont quote me on that.
and I dont know how to tell the difference.
This way is really easy.
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #43 on: Sep 19, 2010, 10:00:04 PM »
Here are some pics of one completed side of my Rear Disc.
Empire Fabrication
  • Turtle Points: 3
  • Male Posts: 50
  • Member since Feb '13
  • Do it right the first time
    • Empire Fabrication
« Reply #44 on: Aug 03, 2013, 02:32:25 PM »
So I got 96 4 runner caliper.  They have 2 different rotors. They have a 11.5 and 12.5. The 4runner fits both they say and the Tacoma caliper only fit the 11.5  I want to know if any one has ran they 12.5 rotors. Cus I do, and I don't want to buy the wrong ones.
cgbemis
  • Turtle Points: 560
  • Male Posts: 568
  • I love Marlin Crawler!
« Reply #45 on: Aug 28, 2013, 09:39:17 PM »
I know this thread is a little on the older side, but I thought I would add a little tech. If you end up doing this mod., pick up a spindle stud kit. This way if you ever want to replace a birfield, you can pull the whole hub assembly off as one piece. Putting it back on isn't as difficult when you've got the studs on there to help you support the hub assembly.
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #46 on: Aug 28, 2013, 10:23:06 PM »
thats a good idea!!
Last post Aug 04, 2004, 06:08:30 PM
by 5spd
Last post Dec 17, 2004, 07:59:45 PM
by Charles
Last post Apr 28, 2005, 06:36:40 PM
by 86yota
Last post Dec 24, 2008, 05:58:45 PM
by 79coyotefrg
Last post Mar 25, 2009, 04:05:26 PM
by COToy91
