I talked to Dan at ruffstuff and he thinks the new diff cover is gonna make it worse.
really? for some reason i think you can avoid that. maybe push your axle out like 3/4in?
can you rotate the PH bracket back a little? looks like that would make it more parellel with the DL and get it away from the dif a little more?
I put the axle to full stuff, and I am pretty sure i'm gonna have to bend the panhard. I'm struggling on the draglink also. SO any suggestions on making the panhard fit?
it really only needs to be kicked out from the center of the axle tube an 1 1/2" to 2", And it needs to be 6 1/2" tall. I am using a 2" mounting width with 5/8 bolt hole.
Its not a hole lot taller but moves it out a tab further. I hope it fits.
Started by Prismo Chit Chat Camp
Started by 91 super yoda Toyota Pickup/4Runner Tech 1979-95
Started by 854RUN Colorado
Started by DTB « 1 2 » General 4WD Discussion
Started by Volcom Colorado
