CARNAGE PICS
Started by DTB, July 14, 2008, 06:26:31 AM
solar86yota
That's some crazy broken stuff!  :biggthumpup:
By the time I get the money for an SAS I'll be 65 at this rate!
Wermz84
I like to Drive!
86toyota
here is my broken junk. slid around a muddy logging road a little to fast and into the side enbankment. all that happened was a broken steering box shaft and tweaked bumper.
T86OTA
GNasty 82
OK, so when I bought the truck, I knew the rear frame was in bad shape rust wise.  I said I'd wheel it till it broke and then replace it.  Well that's pretty much exactly what happened.
I slid down a steep hill into a downed tree that I wound up straddling and my rear diff got caught on the tree and well, this is the result.
82 Toyota SR5 Pickup
  Marlin Dual Ultimate
  Front 5.29 LC HP Elocker
  Rear 5.29 Grizzly Locker
  BFG 37" KM2s
  Custom rear frame and flatbed
  Propane Powered.
Build Thread:
http://board.marlincrawler.com/index.php?topic=64521.0
Quote from: Toymin8r on July 19, 2010, 02:18:05 PM
"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
studentwheeler
GNasty 82
Already got a new rear frame done, check the sig.   Believe it or not, we trail fixed it, wheeled it the rest of the way down the mountain, through the mud and back home.
  BFG 37" KM2s
  Propane Powered.
Build Thread:
Quick Draw
Not serious carnage...but scary as hell.  And not really on the trail....but I wish it was!
My steering shaft didn't want to tighten down all the way.  So the bolt was tight, the shaft was not.  I did not know this.  I just tightened the bolt, and didn't see if I could yank the shaft off the splines.  Over time, it slowly backed off the input to the steering box until one day going down the highway at 75....   So I slammed on my brakes...and then found out that I had a damaged brake line that had been waiting for a panic brake to put enough pressure on it to pop...  So I started drifting over, realized I had no steering....stomped the brakes and got about about 1 second of brake time before "POP!" and my foot went to the floor.  Fortunately nobody was in my way.  I hit the center cables and took out 6 posts.  Total damage was a broken spring center pin, crushed fender and cab.  It was badly tangled in the cables, so the tow truck had to pick my truck up on the other side, take off the wheel, and pry the cables off the front axle.  This could have been much worse, and it was probably the scariest thing that's ever happened to me.
'80 Pickup, 5VZ-FE engine, A340F transmission, Marlin gear drive adapter, Dual Ultimate transfer cases, 5.29 gears, Detroit rear/Lockrite front locker, 37" Goodyear MTRs, XRC8 winch, custom tube bed and armor
axled89
that would suck.  glad your OK.
i love oregon wheelin.
Yoat Goat
That last one is a sweet flex shot!  :joke:
T urning
O ver after
Y ears
O f
T rail
A buse
BUNYAN
Quote from: Rocksurfer on July 15, 2008, 10:21:48 AM
My usual comeback for that one is, "How much of your Jeep is oem"? Then like you noticing that the axles are not I continue my reply, "Hey Those axles don't look stock, why don't you put that Dana 30 back in and call me and we'll see who goes further".
jeeps are like tampons every girl thingy needs one
86bobbedtoy
well atleast you have an extra axle housing already in the back
lol
87pickup
I have been pretty lucky and happy that all i have broken is the rear output of my t case. installed a Longfield output and i have been trouble free ever since.
junya92toy
Hey quick draw, you forgot to add after all that you might need a new seat?
Quick Draw
Haha yeah, fortunately my axle housing still seems to be straight after that so I haven't needed it yet...
And yeah...new seat might be in order.  It certainly had a pucker mark.
After some quality time with a BFH and fresh paint, it's much less noticeable now:
Still ugly on the cab...  I haven't pulled that out yet.   The cable marks are cool though.  You can see 4 distinct cable impressions/cuts in the sheet metal still
BTW, I am NEVER running doorless again.  After worrying about theft, rainstorms, losing :pokinit:, etc on top of nearly losing my leg in the accident, the added visibility and cool factor is not worth it at all.  That said, I may run some half doors, but it will have to be on a quick release system so I can swap out doors just for the trail.
