Poll
Exo or internal?
4xinnovations internal
Partial exo
Author Topic: 91 extra cab on 60's with 3 link (Fordyce carnage)  (Read 149874 times)
0 Members and 13 Guests are viewing this topic.
91 ex-cab
  • Turtle Points: -171
  • Male Posts: 1,660
  • Member since Mar '10
  • Honey Badger
Re: 91 extra cab on 60's with 3 link..
« Reply #450 on: May 20, 2011, 12:18:52 PM »
More pictures. I have no idea what I am going to do with the resivoirs on the shocks, there is not a lot of places for them to go.
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
« Reply #451 on: May 21, 2011, 05:56:28 PM »
Burned everything in today, and added some support to the upper link tower. Also flexed it out :thumbs:
87hillbillyoter
  • Turtle Points: -43
  • Male Posts: 1,066
  • git er duuunnn!
« Reply #452 on: May 21, 2011, 06:24:44 PM »
my ifs could do better :gap: no looks real good man, thats some real nice flex!
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
« Reply #453 on: May 21, 2011, 07:42:32 PM »
Thanks man, I think it has a few more inches to go but my roof was about to hit the lights in the garage and I still don't have the limit straps in.
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
« Reply #454 on: May 23, 2011, 11:17:33 PM »
So i painted all of the links and axles today. While I was out there I was thinking about how much beef I should put in the axles. If I get the 35 spline upgrade kit for the front with 4wd factory drive flanges, yukon greasable u-joints, and yukon 1541h outers..and then get dutchman custom alloy 30 spline shafts for the rear will I be alright? I don't wanna be afraid to get it a little bit, in fear of breaking. I will be running 5.38's, spool rear, arb front and I am only on 40's.
Link to the dutchmans and the 35 spline kit.
https://www.4wdfactory.com/store/products.php?product=GM-%7B47%7D-Dodge-Dana-60-35-Spline-Upgrade-Kit-w%7B47%7D-Drive-Flanges
http://www.dutchmanaxles.com/products/flanged-floater-axle-pair
kiyul4130
  • Brown Star Award
  • Turtle Points: 279
  • Male Posts: 3,265
  • Member since Jul '05
  • Turdburgalin since 1985
you will be fine for strength if you do that. as far as the height, if you dont like it, swap out the upper coils while there brand new still for some that are 2" shorter?
-kiyul-
ECV 7-11
KYOTA FOREVER
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
That wont net him anything unless he likes having his springs drop out and hang loosely at full extension. Typically thats not so good because they can become misaligned in their seats and mar the soft aluminum parts of the shock. He'd be better to purchase a third spring called a helper spring, which is designed solely to reduce ride height. Besides he has more than enough room on the shock to fit one of these helper springs.  Thats why I sent him a 14" upper and a 16" lower. It makes room for that helper if its needed.
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
bigarms23
  • Turtle Points: 111
  • Male Posts: 2,897
  • Member since Jun '07
go with both sets of shafts
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
After looking around at moonrocks this weekend, it sits exactly were I want it to be.
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
Got some limit straps in, might take some pics tommorow for the hell of it( not that it's any real progress, looks sweet with it all painted though).
I'm onto brake lines now, and I can't figure it out.   The rear still has the toyota fitting that came factory on the truck(10mm or whatever), and I have the fittings that go in the drums on the rear axle. The front is converted to standard(unknown size but the fitting on the truck screws into the flex line coming off the calipers).  So should I just go all toyota fittings and then flare the fittings on for the drum in the rear, and then run all chevy whatever size that is up front?
  Also what is the easiest way to buy all of my hard line, buy a bunch of hardline from summit racing or jegs..or just go to the auto store and get one of those 5' pieces of hardline with random fittings on it, and flare my fittings on?
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
Shorter version,
-Anyone know what size the toyota fitting is that would come stock on the rear of my truck? It threads into a stock toyota axle caliper.
-Anybody know what size fitting the chevy dana 60 uses? I know it is standard.
- What is a good place to source all of my hardline, and also the steel braided line to go from the hard line on my axles to the hard line on the truck? I need one toyota for the rear, and chevy for the front.
bigarms23
  • Male Posts: 2,897
pmd you a place to get the hard lines and fittings you need
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
I used Summit or Jegs for the fittings, Napa for the line.  Most of Toyota uses M10x1.0 flare.
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
Everything is painted, limit straps are on, working on running the brake lines.
Norcal crawler
  • Male Posts: 84
  • Member since Feb '08
Hey i found that brake line bender so whenever you get all that crap let me know. I've also got a roll of brake line you can use if you want, but its not exactly gonna be the most straight when its all done. it should work though.
-'85 Toyota pickup, 35's, 4.7 dual cases, locked f/r, longs, etc.
-'04 Jeep Wrangler, 4 1/2" RE Lift, 33's, ARB's, 4:1's.
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
Now that the truck is done( besides the little crap to get it on the road), I am thinking about a roll cage. I'm leaning towards getting the 4xinnovations internal kit for it, but still tossing around ideas of a partial exo. I added a poll so put your vote in! I would do something like this for an exo, with the tube that normally runs over the windshield wipers in the gutter under them if possible.
« Last Edit: Jun 12, 2011, 01:58:49 AM by 91 ex-cab »
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
There would be two tubes in a /\ going up the windshield but I guess one of them didn't save, whatever it's late i'm going to sleep :puke:
TacoRunner
  • Male Posts: 2,324
    • 4wheelunderground
I voted for the 4xInnovations kit, buy it, put it in and start wheelin.
87hillbillyoter
  • Male Posts: 1,066
  • git er duuunnn!
i say partial exo, looks sick and you dont lose cab room. just my :twocents:
bigarms23
  • Male Posts: 2,897
4xinnovations cage or do a simple in cab cage
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
Looks like its gonna be about $750.00 for the dom 4xinnovations kit to my door :yikes:. I think thats what i'll end up doing though.
On a side note, does anyone have a good source for steel braided brake lines? I need to have two lines made, one for the front and one for the rear. I should be able to get lines, they just need to have standard chevy fittings 1 male 1 female, but I haven't found anything yet.
yota_krawler
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,379
  • Member since Oct '06
  • proud parent!!!
Interior!
GloNDark
  • Turtle Points: -1
  • Male Posts: 282
  • Member since Nov '03
I fawking love mine. It was worth it, all pre-bent, pre-notched and ready to go. Fedex dropped it off around noon and I had in the truck and 90% done by dinner time. hahaha
yota_krawler
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,379
  • proud parent!!!
So what's your wheelbase, frame highth, and belly highth?
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
Ya yours looks good. I'm 95% positive i'm gonna order it, depending on how i'm sitting after I order my axle shafts and the front arb. The only thing I don't like about it is how much i want to add to it. I will add a dash bar, window bars, harness bar, tie it to the frame, and mounts for some bucket seats.
Wheelbase is 126", frame height is 27 1/4" with the tires full, belly height is 24". I might go flat belly if I think I really need it.
yota_krawler
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,379
  • proud parent!!!
Mine sits at 125 1/2" wheel base, 25" frame height on 38s, and 21" to the bottom of the stock cross member. So if I put 40s on I'd sit the same... I'm going to flat belly and shorten my wheel base to some where around 118"
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
What size tires are you on? I think if I shortened my wheelbase to 118, my tires would rub the cab.
yota_krawler
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,379
  • proud parent!!!
38s right now, but I'm going to run 39 maddogs. 118-120. Still have some figuring to do. Might not work but that's the idea.
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
I just measured, you should be alright. Theres a good 14" or so to the cab on mine, I am going to move the rear axle forward 6" when I do the 4 link.
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
Dutchman rear shafts, 35 spline yukons stubs, spicer u joints, and solid flanges are on the way. Brake lines are done, heres the list:
Need to buy,
-arb mini compressor
-rear shocks( the cheap ones I can use as bumpstops :clap:)
-4xinnovations cage kit( not nessecary to wheel it)
What I need to do,
-Bleed brakes
-put the new shafts in front and rear
-take truck to wfo concepts to get gears/lockers done, and also shocks charged with nitrogen.
I also need to have the rear drive shaft shortened.
Last post Apr 20, 2005, 01:48:48 PM
by UNBREAKABLE
Last post Dec 13, 2005, 03:27:32 PM
by furrballs95
Last post Mar 27, 2008, 08:36:08 AM
by Volcom
Last post Mar 28, 2010, 07:06:46 PM
by Quick Draw
Last post Jan 25, 2012, 09:28:22 PM
by Russell_G
