Author Topic: Fuel tank ideas??  (Read 2159 times)
4.3 headache
  • Turtle Points: -182
  • Male Posts: 321
  • Member since Aug '03
  • keep goin!!
    • myspace
Fuel tank ideas??
« on: Jun 14, 2010, 12:11:23 PM »
 I've got an 84 sc/sb that I put a 1st gen 4runner body on, the fuel tank that was under my flatbed will no longer work
with this set-up ( It hangs down too low)
Here's a link to it : http://board.marlincrawler.com/index.php?topic=50836.msg726042#msg726042
I've got a friend that works in a fab shop that offered to make a fuel tank at cost for me. So I'm thinking around 25gal. (30x30x7)
between the rear frame rails. My big concern is the position of the filler neck in relation to the tank, its going to have a sweep in it but the fuel cap is still higher than the tank inlet, (see green line in pic)
with the vent on the tank i'm thinking it'll be ok, but i don't want a truck that's a pain in the rear to fill.... I don't want to cut into my rear seat space, but i suppose i could cut into the inner body panel and partially run the filler neck through the wheel well to the tank.
What do you think?
all i want is a little more than i'll ever get!!
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Fuel tank ideas??
« Reply #1 on: Jun 14, 2010, 12:47:43 PM »
just move the filler door assembly tp behind the rear tire,  cut a couple inches away from the door on all four sides then match that on the back, use the piece that comes out of the back to fill the hole in the stock location.
-Matt-
  • Turtle Points: -184
  • Male Posts: 1,010
  • Member since Jul '07
  • Full throttle Rollin steady
« Reply #2 on: Jun 14, 2010, 01:01:17 PM »
i dont know how much your gonna pay but you can order a brand new 19gallon f150 tank shipped to your door for 100$. it will fit in the same location. just another thought
http://www.autopartswarehouse.com/details/QQFordQQF53QQReplacementQQFuel_TankQQ19881989QQARBF670110.html
4.3 headache [OP]
  • Male Posts: 321
  • keep goin!!
    • myspace
« Reply #3 on: Jun 14, 2010, 01:48:10 PM »
I've looked at the pirate 4x4 thread on ford tanks .
http://pirate4x4.com/forum/showthread.php?t=484247&page=2
I've got a carbed ford tank, it has no vent pipe for one, so i'd have to solder one in, and I've got a chevy pump in my existing con-ferr tank now so i'd have to cut a hole in the ford tank to accept the pump/ring assembly, I don't think it's worth the extra work. I can get the custom tank built for about $150.
I'm thinking about doing that, I guess I'm still wanting to hear somebody tell me I can use the stock fill location without the pump clicking  off.....
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
  • Member since Jul '05
« Reply #4 on: Jun 14, 2010, 03:13:19 PM »
Do something so you can fill it through the tailight area after you've made a hinge for the light.  Just a thought...
Last post Apr 05, 2008, 09:21:13 PM
by Huhwhye
Last post May 21, 2008, 11:45:25 AM
by REG535
Last post May 17, 2009, 07:26:19 AM
by Redbeard3261
Last post Jan 16, 2012, 06:57:05 PM
by brainlessfool
Last post Nov 03, 2012, 11:05:12 PM
by speedstar751
