Is it possible that your wiring is messed up causing the injectors to be powered even with the key off? Granted, dirty injectors will do this also, it's just a thought. And FYI, the 3RZ has a Mass Air Flow sensor, not an Air Flow Meter as the older toys did. Just a terminology lesson for ya, no charge... Lol
I think the speed sensor does need a signal to the ECU. I had a 90s speed sensor that hooked right up but I know most guys hook something from their speedometer that sends the proper signal. Look on the 3RZ database thread...
Started by johnyreb69 Project Research and Build-Ups
Started by Caboose Parts Wanted
Started by 4.3 headache Project Research and Build-Ups
Started by Toyota cali Newbie Questions
Started by yotaman198481 « 1 2 » Toyota Pickup/4Runner Tech 1979-95
