My 84 extra cab is gone. Tacoma build now.
Started by Hyena, November 21, 2004, 12:25:12 PM
0 Members and 9 Guests are viewing this topic.
cause chains are cheap and easy to get!  o ya, it's all about the bling factor too!
kiyul4130
im so not ready..........................askl;dfjasl;dkfj.
but ill be there
-kiyul-
ECV 7-11
KYOTA FOREVER
KYOTA
plus chains are instant adjustment if needed , straps well, by new a new strap for a needed length.
rednk1980
How did you move your front end 1 1/4 in forward? Did you re-drill the spring perches in the front?
Quote from: rednk1980 on April 23, 2007, 09:53:18 PM
Yep!  easy as pie,  took a little less then an hour with 2 people.  easy when you have a forklift, air tools and a plasma cutter  :)
rednk1980
did you have to re-drill the u-bolt plate the 1 1/4 back to keep the center pin square? Im doing the same thing just cant figure out if i need to re-drill the ubolt blate or not.
thats what the plasma cutter was for.  i could have just redrilled it but i decided to cut it.  a lot quicker.
rednk1980
thanks that helps me out alot now i know i need to drill them out. One more thing is your steering arms going to hit because you moved the axle that much more forward?
inmyownsummerami
Quote from: Hyena on April 23, 2007, 10:00:26 PM
Another thing that helps is when you have no bushings in your spring eyes, once you get the u-bolts undone and the weight of the truck off the springs you can just push them out of the way to drill the perch. :gap:
WHITE WHEEL ROCK CRAWLERS "If your wheels ain't white, they ain't right"
:greengrin:My 1st Gen. Toyota SAS (2wd to 4wd) :greengrin: (In Progress)
RIP "Goody Goods" My DDW Brother
86turboyota
that truck just gets cooler every day
My Build 1986 4runner SAS 36s etc
http://board.marlincrawler.com/index.php?topic=22625.0
"Later, I learned that even though I engage 4WD my hubs are not automatically locking? Something about manual locking hubs I think. What's manual mean? I need to read a manual to lock them? lol  So I found these neat autolocking hubs and installed them. Sometimes they dont stay locked while I am backing up, but that's fine because I dont have a backup camera to see where Im going (like our RV) so I just simply dont ever back up"- BigMike
gotrocks
Quote from: inmyownsummerami on April 23, 2007, 10:22:05 PM
Don't give away my secret to better flex!
gotrocks
So what'd you break on the jambo?  It wouldn't be a wheeling trip without breaking something.  You and I have the same luck I think.
"I" didn't break anything on my truck.  Brittany tried taking my truck up Backdoor saturday night.  She gave it hell with the pedal to the floor.  ended up shearing a front spring center pin.  leafs went flying out of it.  found the bottom leaf about 50 feet back down the trail some how.  the only spare center pin i had was only long enough to put 4 leafs back in.  and then the u-bolts wouldn't get tight enough for just 4 leaves.  so i had to ratchet strap the springs to the axle.  limped it back to camp with the gangster lean.  i haven't fixed it yet.  did bend a lower link slightly on one of the trails.
gotrocks
Haha thats funny.  Just flip the link around.  I did the same thing and just flipped it around, that way when it hits again it will help straighten it back.
gotrocks
I can't wait to wheel with you guys at the roundup.  It's going to be a lot fun.
rednk1980
Brad i gotta pick you brain for a second. Do you steering arms touch at all when flexed to the passenger side. Im worried that the two arms are going to hit each other when im flexed all the way passenger. Could you show me a couple pics of your steering box and how you mounted it as well. Thanks it really appreciated.  :thumbs:
kiyul4130
Quote from: rednk1980 on May 02, 2007, 09:41:11 PM
arms hit each other??? and by flex what do you mean? up or down? either way im confused? didnt know arms could hit? and steering box. he doesnt ahve one. he magically gets it through any rock he wants. you have to wheel malls for a long time before you can wheel curbs and elemtary parking lots
-kiyul-
ECV 7-11
KYOTA FOREVER
my pitman arm from the box does contact the tie rod after i redrilled the spring perches and oved the axle forward 1 1/4 inches.  i need to do something about that.  my steering arms don't hgit anything.  and the frame is plated where the box is front and back.  i tilted it as far as i could to move the pitman arm up higher.
rednk1980
yotamckimboy4x4
how much tire pressure you running brad? and have you ever blown a bead with them iroks. i ran mine at 5 and still havent blown a bead
"We ride together, We die together, YOTABOYS FOR LIFE"    85 toy pickup 5 inch springs 2inch body lift, 36" IROKS, custom front bumper
"HOLD ON TIGHT"
not sure what they are at.  the gauge i had wasn't working right.  i haven't blown a bead yet.  i never blew a bead with my mtr's either and i ran them at 5-8 psi every trip.  the Iroks hook up a lot better!
yotamckimboy4x4
"HOLD ON TIGHT"
ToYocRawleR
Im diggin that front end.  You've inspired me to do something similar on mine.
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
6.72:1
Now, that's what I am talkin' 'bout!
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
Austin W
damn your crazy, looks like you finaly smashed in the roof !
ToYocRawleR
How does your motor stand the beating???
Rigs:
i have been tryingto kill this pos motor and i have not had any luck in doing that.  it runs good for just crawling.  but when i try to go fast it cuts out like no other.  i think the injectors maybe clogged or something.  it ran better after i rolled it and hydrolocked the motor here.
and i did finally hit the roof!
