Where do you live?
Truck looks good with the new tires.
I watched your video a page back. I'm curios how your rig handled the hard part, er the ledges, on cheap trick. I bet it would handle those ledges much better now that ya have the irocs. Jake, were gonna have to get together for some trails sometime soon.
I didn't have any trouble with the ledge at the entrance of cheap trick. I used the bypass for the ledges towards the end . Never even pulled cable. I'm sure the new iroks will make it really go. We definitely need to hook up and go wheelin'. For now I'm thinking I'll just beef up my Toyota axles. I keep bugging Jordan7118 to get his tons in so I can have his taco rear. This time it'll get some added beef prior to installation.
IThat ledge a the start is crawlable even when wet. those ledges on up towards the exit were fun and requied some creative lines and some throttle bumps. We did that trail at night and all 4 rigs made it without winching. my buddy Chris and I made the left side ledges other 2 took the bypasses. It was dryer when we were there than it was in your videos though.Some of my local buddies are heading back to flat nasty the 2nd weekend in oct. I'm possibly out for any trips for a while due to scedule changes at work. I may atleast try and ride along. I wouldnt bother with a taco rear uness your planning to run chromo axles from the get go. The 3rds might be a tad bit stronger but the axles are weaker than the ifs rears. I've beat my stock ifs rear axles hard with out even a twisted spline, and have seen taco rears break under way less stress. As a matter of fact i have seen narrow rear axles break, but never a ifs rear axle.. I'm shure its been done I just havent seen it. Isnt Jordan's rear an elocker rear anyhow? The elocker 3rds are = in strength to the v6 3rds, which isnt much stronger than a 4cyl 3rd due to comparable 8" ring gears. give it time, youll see when you get to that point and really start moving your weak links around. Those 4's will start showing your weak links.
Well I've got a complete IFS rear but didn't want to richard with modifying it. Also I need the rear width because with my taco rear and the 40's I'm rubbing on the frame at full stuff. Also I've heard it rumored that with IFS housings and e-lockers you don't get full axle engagement at the 3rd member. So I'm leaning towards a set of these: http://www.marlincrawler.com/axle/rear-axle-parts/chromoly-rear-axles they're on sale for $145! My only problem is my rear is from an 02 Tacoma. It says the axles are for 95-00 Tacos. Is it something to do with the ABS? So it could be easier to build up my IFS housing and add 1.5" spacers to it. If the chromoly axles will work, I think I'd just beef up my taco housing throw those in and be done with it. Whats your thoughts?
If the taco rear is already in there, I'd just run it till it breaks then figure it out from there. Just be prepared for the carnage by carrying along an extra shaft to stick in to get ya back to the trailer. A friend broke a narrow rear and took out his detroit. Another friend with a 8.4 taco rear broke an axle and it just broke smooth off. Both of them were running 36s. Another friend has been running a ifs rear with 40s and has only succeeded to break ring gears with the v6 3rds, but he is in a really lightweight rig. The ring gears have been my weak link as well. I'm not familiar with the elocker rear diffs. Pretty well everyone I wheel with goes for the basics, and trailers their junk. Unlocking a diff just isn't necessary when you only see trail time. 90% of the locals run welded diffs. We all wheel low budget, and as hard as we can git it!What backspace are your wheels? Rubbing the frame with 40s isn't necessarily because of your axle width.
jake would you happen to know what the caster is on your front axle?
Not a clue but it has the stock front hanger and 5.5" shackles. I get very SLIGHT wobble at 40ish mph. I have no steering stabilizer though.
drop hanger will fix that :]
no way
Nice, that would be cool to score a free set of tons. Hell, I'd say get the truck even if it has a D44 just for the free 14B then you can always sell the D44 and part the truck out and get over half the money for a D60.
Nice, that would be cool to score a free set of tons. Hell, I'd say get the truck even if it has a D44 just for the free 14B then you can always sell the D44 and part the truck out and get over half the money for a D60.EDIT: If it's a D44 it should be balljoint and if it's a D60 it should be Kingpin. They both have 10 diff cover bolts.Also a D44 will have 2 ubolts on the passneger side while a D60 will have one ubolt then two studs or bolts.
you have the tacoma elocker housing correct? so they as weak as people say it seems.
Here is my list of want I'm wanting to do next since I'm not going to tons yet:Trail Gear's Trunnion bearing Eliminator kit5th Stud modARP StudsKnuckle Ball GussetsMaybe 4.70s in the rear caseHydraulic assist would be nice too
For the price of all that you can buy the axles. Then sell you Toyota axles to pay for the disc brakes on the 14B and steering for the D60. You'd be really close to having the tons done then...
Started by tryn2Crawl Chit Chat Camp
Started by swapped89 For Trade or Barter!
Started by 85toyota « 1 2 » Project Research and Build-Ups
Started by muddywaters Toyota Land Cruiser Tech
Started by Pat « 1 2 3 » Project Research and Build-Ups
