so how long are the f150's?how much froward is the front hanger from the factory one? and why did you moved your rear shackle forward?i think your running a square front shaft right?are you having any pinion angle problems with the stock front hanger and banana shackles?are you using first gen main leafs or 2nd gen?i know that a lot of questions but i just about have everything i need to do my suspension and hysteer and im going to do it all at once. thanks for the answers
do you have axle wrap running them long side forward?
have they gotten hung up on anything yet? i asked about the axle wrap cause i heard you do when they are long side forward but i've also seen them short side forward. but your truck looks good man you do good work.
alright sweet i think im going to run the f-150's. and could you snap a picture of where your ifs box is mounted. and do you run a flat or drop pitman arm?
stock 2.28 in both cases?
where did you get that flat pitman arm? so you like the duals with the stock 2.28? i heavnt decide on duals with 2.2b's or just a single 4.7 cause of cost. havent decided yet. what setup did you do for the crossmember?i was reading on your first page that yu can have boomerang shackle's made? how much would they be? and what did you use to cut the toyota rear leafs down for ruf?
Hurry up and mount those! I want to see how much trimming you are going to have to do. I am just about to buy a set of those for myself. So did you go with 4.88 or 5.29s?
Looks sweet. What did it measure when it was up on the forklift?
I have a great idea, but the one tons out from under my k5, or buy the entire truck. I'm asking 1800 for the entire truck. It's listed under rigs for sell. It has a 454 in it. If you bought it and parted it out you would get the axles for nothing.
Started by tryn2Crawl Chit Chat Camp
Started by swapped89 For Trade or Barter!
Started by 85toyota « 1 2 » Project Research and Build-Ups
Started by muddywaters Toyota Land Cruiser Tech
Started by Pat « 1 2 3 » Project Research and Build-Ups
