You can also bend your T-case shifter.Pretty easy actually.But yes, remove it and put it in the vise.
pictures are worth a thousand words.
Take the T-case shifter out, turn 180 degrees and re-install, problem solved. How do I know, I did the same thing.
Is it possible you have a t case shifter off a top shift and you have a forward shift case? I agree with the cheese that they had slight differences over the years with different bends. Also cheese, i am interested in your dog leg. That makes allot of sense for the setup. I put a R151F in my runner and didn't get the 5speed shifter with it so i scrounged up parts to get a working setup. I had to bend (heat up and twist) my setup allot to make it work. To do this i used a simple butane torch with a vise. the upper black part of the shifter will melt off if you get the lower section your bending to hot. I was extremely careful and it was still too hot. So be prepared to glue it back on ( i think i just used some rtv to be honest). It took me 5 trys to get it to work perfect so trail and error is your best bet to perfecting it.
Started by wildchild1066 Parts Wanted
Started by Thomas P Toyota Pickup/4Runner Tech 1979-95
Started by brookspage Project Research and Build-Ups
Started by sailsdan30 Parts For Sale
Started by tgmaul88 Parts For Sale
