Author Topic: Shifters for T-case/Trans on same side...whats up with that?????  (Read 5090 times)
Toyotoy84
  • Male Posts: 19
  • Member since Nov '09
Good day,
I am in need of bit of a "why question" When i got my 84 toyota and spend the next month fixing it up and finally going for a drive in it testing the 4x4, the trasnfer case shifter is on the left and so is the transmission shifter..
How annoying, you can only stay in 1st in 4L, unless you pull it out and squeeze the shifter down and around and then put it in 2nd, then back into 4L...Ohhhhh and if i have to back up :hammerhead:!!!! ha ha wait for it...wait for it...if i needed to get out of a situation fast...NOT :tantrum:!!whats up with that, i figure 2 very different year components. any idea what years'ish. I believe its a gear driven case.
1984 Toyota SR5 Ext-cab, 4x4, 22R, cam, header, 4:56's, 36.5" TSL, ARB style front bumper, Rear tube bumper, Warn 8000lb
1993 Toyota 4Runner SR5, 4x4, 5spd, 22RE with Header, Pro-comp shocks
1992 Toyota 4Runner SR5  4x4, 5spd, 3.0V6
1991 Toyota 2wd P/U 22RE, 5spd
MY YouTube video.
http://www.youtube.com/watch?v=w8gGanfVMc8
Early
  • Turtle Points: 67
  • Male Posts: 470
  • Member since Oct '09
  • The Buddhas ridin shotie
huh??
Grab a torch and bend your 5 speed shifter. O and remove it from the truck first.
1994  4Runner w/ full doors
My hands are dirty cause i drive a yota
sounds like someone put the tcase shifter in backwards, unscrew the shifter knob, then take the rubber boot off around the tcase shifter then the smaller boot thats around the base of the shifter, under that smaller boot is a type of a c clip, remove the c clip then the shifter will come out of the base, flip the shifter 180 degrees and re install
MC387
  • Turtle Points: -4
You can also bend your T-case shifter.
Pretty easy actually.
But yes, remove it and put it in the vise.
Early
  • Turtle Points: 67
  • Male Posts: 470
Maybe should mention that the upper section of the shifter will melt off the lower section if you use to much heat. I was careful and still used way to much heat so i rtv'd it back in place.
Coyote's idea might hit it closer on the mark though.
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
If there is no c-clip, you have to push the collar down and rotate it to remove it.
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
 :inthedark:
pictures are worth a thousand words.
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
Toyotoy84 [OP]
  • Male Posts: 19
:inthedark:
You want a picture of my shifter layout or what cheesmaker is taking about? Thx
MY YouTube video.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Take the T-case shifter out, turn 180 degrees and re-install, problem solved. How do I know, I did the same thing. :hammerhead:
84pickup
  • Male Posts: 335
  • Barnwell Mountain (stock) Texas TrailRiders Jam 08
X2
you've got it installed 180 degrees out. the easiest way would be to unbolt it and just rotate the plate and stick it back in.
lets not and say we did.
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
Its weird gettin one back in. Mines backwards, I tried like 5 times, but kept puttin it back in the same way. It should sit way to the right. It didnt look right until I saw another truck. I can shift into all my gears, but sometimes in 4lo, its hits 2nd, and pops it out. Ill fix it when i get around to it....
Toyotoy84 [OP]
  • Male Posts: 19
So i pulled it out and put it in the other way and i can not shift into reverse now and in 2H i can not get 4th or reverse, the shifter is in the way, WTF!!!!
I have a transmission and T-Case from an 85 and both are different than in this truck, the shifters are further apart than on this truck so i could not use any shifters from the 85, what is all the difference?
MY YouTube video.
Toyotoy84 [OP]
  • Male Posts: 19
:inthedark:
Pictures are up...
MY YouTube video.
Cheesemaker
  • Male Posts: 4,525
Looks like somebody may have swapped out the tranny shifter.  I know there are several different ones for specific trannys.  I've got a R151F and it has a healthy dogleg to clear the forward shift t-case lever.  My brother in law had a 87 also, but carb'd and his shifter and t-case shifter layout were different than mine.
Best thing to do is call the Marlin in the morning (or when ever you can) and they should be able to get ya lined up.  And maybe have the right shifter laying around.
Cheesemaker
  • Male Posts: 4,525
Here's the dogleg I'm talking about.
First and 4lo
Second and 4lo
Toyotoy84 [OP]
  • Male Posts: 19
Is there a specific name for the shifter?  It has 4 bolts holding it, my spare shifter on the 85 trans has 6 bolts. is there somewhere i can see what trannies are what name and styles?
Thanks for the pics...
MY YouTube video.
Cheesemaker
  • Male Posts: 4,525
Give Marlin a call.  Those guys can get you straightened out over the phone in no time.  And possibly have what you need just laying around in the back lot!  :thumbs:
Early
  • Turtle Points: 67
  • Male Posts: 470
Is it possible you have a t case shifter off a top shift and you have a forward shift case? I agree with the cheese that they had slight differences over the years with different bends.
Also cheese, i am interested in your dog leg. That makes allot of sense for the setup. I put a R151F in my runner and didn't get the 5speed shifter with it so i scrounged up parts to get a working setup.
I had to bend (heat up and twist) my setup allot to make it work.  To do this i used a simple butane torch with a vise. the upper black part of the shifter will melt off if you get the lower section your bending to hot. I was extremely careful and it was still too hot. So be prepared to glue it back on ( i think i just used some rtv to be honest). It took me 5 trys to get it to work perfect so trail and error is your best bet to perfecting it.
Toyotoy84 [OP]
  • Male Posts: 19
I couldnt tell you what i have, would be nice to get to know the differences....like your R151F type numbers for what  type an dyear differences...thx
MY YouTube video.
Last post Mar 12, 2006, 07:13:33 AM
by Jared
Last post Mar 05, 2011, 01:38:09 AM
by Thomas P
Last post Apr 15, 2011, 02:44:49 PM
by brookspage
Last post Jul 18, 2011, 08:17:36 AM
by BoG-ToY
Last post Feb 19, 2013, 09:18:46 PM
by 894runn'n
