you are supposed to set the pre-load with a knuckle pull scale to get the proper amount of shims.... every time I have done mine I just use the shims that came out and make sure the pre-load feels ok and all is good and tight! the amount of shims will not affect how your wheels are sitting... chances are the leaks are caused by bad inner axle seals... order the marlin HD seals and never go back the stock ones will always leak!
1 thick and 1 thin usually werk just fine
One thick and one thin is not good enough in my mind. Mine was so far away from that it's not even funny. I used this method. works great. http://www.pirate4x4.com/forum/showthread.php?t=734345and the shims do not change your Camber angle.
make sure you save those old trunion bearings. they are valuable on the trail
I have used 1 thick and 1 thin every time I have built a toyota front axle and they all seem to work great with no issues.... I understand thats not the "correct" way to do it but it has always worked just fine for me as well as everyone else I know that has done it... every single toyota axle I have taken apart has had 1 thick and 1 thin...
there should be 2 seals for the hubs ( about 4 inches diameter) and 2 seals for the inner axle, (maybe 2 inches) they go inside the housing (inside the knuckle ball)one thick one thin, then tighten it all down and see how much resistance it requires to turn the knuckle side to side most use a fish scale for thisthey should be snug not sloppy or too tight to turn
I think my seal confusion is because the kit I bought came with the wheel bearing kit for each side and the knuckle rebuild kit. the knuckle kit comes with two inner hub seals and each wheel bearing kit comes with a inner hub seal. does this sound right? Wish I had waited till Marlin had the kit in stock so I could have gotten the HD knuckle oil seal
Started by 95TacoTruck General 4WD Discussion
Started by Hyena General 4WD Discussion
Started by RokCrawlinToy Project Research and Build-Ups
Started by Tusker Toyota Pickup/4Runner Tech 1979-95
Started by 86turboyota Engine
