Nuckle Rebuild Question
Started by Halladay, September 21, 2009, 09:28:22 AM
Halladay
ok so im going to be rebuilding my knuckles today because they leak and my tires are sitting like this ^....
so that means my shims in on my lowwer and upper nuckle caps are wrong. so what shims do i put were and how many go were. I know there are 4 differnt size's of the shims.
Paper Thin, Thin, Thick, Real thick lol please help  :beerchug: and yes i tryed the search icon
brockbuilt85
im rebuilding mine so ill be lookin for an answer too
:sofa:
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
TIMS89CRAWLER
you are supposed to set the pre-load with a knuckle pull scale to get the proper amount of shims.... every time I have done mine I just use the shims that came out and make sure the pre-load feels ok and all is good and tight! the amount of shims will not affect how your wheels are sitting... chances are the leaks are caused by bad inner axle seals... order the marlin HD seals and never go back the stock ones will always leak!
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
Halladay
Quote from: TIMS89CRAWLER on September 21, 2009, 09:48:33 AM
could i just use a fishing scale to weigh fish as my pull scale?
so what adjusts my caster camber if the shims dont?
this is what my tires look like....
the pics dont really give is justice... its worce than it looks
88_Pathy
TIMS89CRAWLER
either that or your knuckle bearings are just shot..... time to tear it down and see I guess!
www.choptechfab.com
CHECK THE BUILD
Dark Knight
read the rebuild section http://www.4crawler.com/4x4/CheapTricks/AxleRebuild.shtml#Rebuild
this is what I will be fllowing in the next week as I do mine.
*** YELLER ***
1 thick and 1 thin usually werk just fine
except BACON
TIMS89CRAWLER
Quote from: ** YELLER ** on September 21, 2009, 11:51:25 AM
thats what I am using as well
www.choptechfab.com
CHECK THE BUILD
*** YELLER ***
except BACON
Wermz84
One thick and one thin is not good enough in my mind.  Mine was so far away from that it's not even funny.  :cheese:
I used this method.  works great.  :thumbs:
http://www.pirate4x4.com/forum/showthread.php?t=734345
and the shims do not change your Camber angle.   :)
I like to Drive!
Burl
I see you have some axle braceing and gussets its possible that the axle could have overheated and pulled from a weld that was too long and continous if the knuckle and wheel bearings are still good then this could be a possibility.
TIMS89CRAWLER
Quote from: Wermz84 on September 21, 2009, 04:26:15 PM
I have used 1 thick and 1 thin every time I have built a toyota front axle and they all seem to work great with no issues.... I understand thats not the "correct" way to do it but it has always worked just fine for me as well as everyone else I know that has done it... every single toyota axle I have taken apart has had 1 thick and 1 thin...
www.choptechfab.com
CHECK THE BUILD
calitaco
One thing you might want to check for is to make sure your axle isn't bent.  Mine was leaking real bad and the cause was my axle was bent at the ball.  I've rebuilt it twice and it still leaks.  I'm in the process of replacing the axle housing, but need to get another rebuild kit from Marlin.
Notice how low the axle sits inside the ball.  It was a bish getting the axle in there when it's bent, because I have to lift it up to be able to push the axle into the housing.  By doing that, I damaged the inner seal.
Halladay
update;
rebuilt my axel and my inner seal was toasted! i replaced it and rebuilt the whole nuckle. i also bought some trail gear rock rings and love them! well worth 20 bucks to me ill post a pic in a few i used one thick and one thin and its perfect... after doing all that my camber caster is perfect and my tires are straight!
Halladay
here ya go
Steve_925
make sure you save those old trunion bearings. they are valuable on the trail
UA 342
STEAMFITTERS
brockbuilt85
Quote from: steve_925 on September 22, 2009, 09:56:36 PM
good call!
Turd Box Build:
axled89
they aren't to bad to do huh. looks good. :thumbs:
i love oregon wheelin.
Wermz84
X2.
I put my old ones in a zip lock baggie.
I like to Drive!
TIMS89CRAWLER
did you use the marlin HD seals?
www.choptechfab.com
CHECK THE BUILD
Wermz84
Quote from: TIMS89CRAWLER on September 21, 2009, 06:19:53 PM
I guess my housing is jacked then.  haha.
But its holding now.  :woohoo:
I like to Drive!
Dark Knight
The knuckle kit I bought has only 8 shims in the entire kit. I dont have a gauge to measure the thickness but it seems there are four thin and four thick. I proceeded with the thick and thin route and the axle seems to be centered correctly. Everything is torqued to spec. Thoughts? (from people who have done this before)
Dark Knight
there are 4 large seals in the kit. 2 inner seals for the hub. Where am I missing that the other two go??
there should be 2 seals for the hubs ( about 4 inches diameter) and 2 seals for the inner axle, (maybe 2 inches) they go inside the housing (inside the knuckle ball)
one thick one thin, then tighten it all down and see how much resistance it requires to turn the knuckle side to side most use a fish scale for this
they should be snug not sloppy or too tight to turn
TIMS89CRAWLER
Quote from: 79coyotefrg on October 15, 2009, 07:57:43 PM
there are actually 2 more gaskets about 4" in dia. these are for the spindle to knuckle
www.choptechfab.com
CHECK THE BUILD
Dark Knight
 I got the inner oil seal inside the knuckle ball taken care of, those are the 2"ers. The 4 large seals I'm speekin of are all the same size (about 4") and look exactly like the inner oil seal on the hub. So the hubs takes care of 2 of the 4 (4") seals, the other two 4" oil seal go somewhere in between the spindle and knuckle??? Where??
Dark Knight
I think my seal confusion is because the kit I bought came with the wheel bearing kit for each side and the knuckle rebuild kit. the knuckle kit comes with two inner hub seals and each wheel bearing kit comes with a inner hub seal. does this sound right? Wish I had waited till Marlin had the kit in stock so I could have gotten the HD knuckle oil seal  :smack:
Quote from: Dark Knight on October 16, 2009, 06:06:07 AM
yea  that is what happened,  knuckle kit and wheel bearing kit :yesnod:
i hope you didnt get them from Trail gear :stopit:
