Swapped89 party bus picture update
Started by swapped89, August 19, 2009, 03:12:40 PM
0 Members and 22 Guests are viewing this topic.
91 ex-cab
That body mount doesn't hang down as bad as I thought it would be. The rear shock hoop is looking good :smokin:
swapped89
Quote from: 91 ex-cab on November 15, 2010, 08:35:55 AM
ya, I put a half inch body lift on thefront four body mounts then mocked up the rear mounta flat against the cab. So they woulda been half inch lower but they're not bad at all. I like the rear shock hoop too :thumbs: thanks :)
mattlosch
1983 caged, 22re, slammed
gnarrkill
79 toyota duals,caged,40 mtrs
NITE KRAWLERS
swapped89
Did a couple thngs after work today. Made a new crossmember and cut out the old one to make room for the gas tank. Didn't mount the gas tank yet. Probly do that tomorrow. :cool:
swapped89
luvyota
Hey man looks good your moving along fast :thumbs: waiting to see what it looks like with the bed on. And I like the way you mounted the rear shocks I would like to see how they work
luvyota
swapped89
Quote from: luvyota on November 16, 2010, 02:38:39 PM
hey thanks man. :) I'm tryin to do at least one thing a day to keep movin forward. I really want to wheel the snow as much as possible, that's my biggest motivation.
swapped89
I got the gas tank mounts welded in today. took a little longer than i expected cause i had to clean up where the old crossmember was to make it a clean fit. Ill upload a pic lata :) i think tomorrow im gonna start on the exhaust. Once the exhaust is done I should be able to set my cab down for good and finish connecting the wiring harness to the motor :thumbs:
91 ex-cab
swapped89
couple pics. i still need to drill holes and weld in the bolts/studs for the tank but its pretty much done. Took a lil longer then I expected cause i had to clean up the frame where the old crossmember was. And Im gonna put some plate over that big ole hole right der.
luvyota
Looks good where are you going to play in the snow?
luvyota
swapped89
Usually just up mt. Hood somewhere or out past estacada. In Oregon if anyone is wondering.
NITE KRAWLERS
I board up on mt hood dude!!  That place has some sick snow, timberline and mt hood meadows are pretty killer.I talked to early awhile ago bout some back counry the next time i'm up der so maybe i'll holla if i make it up der again and ya can take me snow mobb n... LOL I have family in up that way and usually make it out at least once...We,ll see but anyway hurry up the snow will be gone!!!!
swapped89
Haha fo sho man. I will def be down to take you mobbin. Just gimme a heads up if/when u head up.
Last night I finished my gas tank mounts and welded up my exhaust. Took out the old 40 series flow and put in a 50 series my buddy gave me. Can't wait to see what it sounds like :) Those bolts are welded to the bracket so they're like permanent studs :)
exhaust is up higher then it used to be and straight no bends excet the one that comes off the  manifold.It's not welded in this pic, but pretty much exactly how it is now just needto put a turn down on it.
91 ex-cab
swapped89
Quote from: 83crawler12 on November 18, 2010, 09:45:19 AM
sick sticker on the your crossmember.  :thumbs:
o yah :beerchug:
Quote from: 91 ex-cab on November 18, 2010, 10:43:59 AM
Do you have your muffler before your cat?
noooo way haha. The picture is taken lookin towards the rear of the truck. :thumbs:
to the lef is the front of the truck and to the right is the rear of the truck.
CrawlerBrennan
Lets go camping
91 ex-cab
Quote from: swapped89 on November 18, 2010, 10:48:52 AM
:smack: I thought i was looking towards the front of the truck for some reason.
Quote from: BLUE on November 18, 2010, 11:16:18 AM
people do this? iv never seen people do that.
No, I have never seen it either.
CrawlerBrennan
Lets go camping
NITE KRAWLERS
Quote from: BLUE on November 19, 2010, 09:41:55 AM
o ok, i was lost as to why you would do that
Don't be lost dude follow the yellow brick road.... uh not sure where that came from..Ya i was  wonderin the same, like who would do such a thing!! Ya never know though man.. Well the tank set up looks good and the straight pipe is gonna be nice up out of the way! But why the muffler in front of the cat..... LOL sorry had too  :smack: :shhh:
91 ex-cab
Quote from: NITE KRAWLERS on November 19, 2010, 11:49:13 AM
:shake:
swapped89
axled89
i love oregon wheelin.
swapped89
Thanks man I'm about to go out in the garage and get crackin on it. :thumbs:
swapped89
Quote from: 91 ex-cab on November 20, 2010, 10:08:42 PM
Get anything done today?
ya I gusseted the the body mounts that hang below the frame rails. Covered up the hole in the frame under the gas tank mounts. Finish welded the spring hangers and shock hoop. Then painted everything behind the cab.
Then I set the cab down and started hookin everything up in the engine bay :thumbs: if all goes well today I may actually get to start it. :beerchug:
... And I modified the old exhaust hangers for the modified exhaust I made. Before it just had some rope holding it up.
