Author Topic: rear brake thing 3rd gen.  (Read 2023 times)
axled89
  • Turtle Points: 296
  • Male Posts: 2,526
  • Member since Jan '09
« on: Aug 09, 2009, 10:35:13 PM »
ok. working on a 89 pickup.    lifted 6 inches .    and i don't know how to adjust the rear brake thing that goes from the frame to the axle.       it's like a valve or somthing.         i think it is for when you hit the brakes it won't let you skid out.    when the frame lifts up.      is it ever been by passed and not used or do i have to keep it.        :headscratch:       :beer:     let me know thanx.
i love oregon wheelin.
84xcab
  • Male Posts: 261
  • Member since Oct '07
Re: rear brake thing 3rd gen.
« Reply #1 on: Aug 09, 2009, 10:42:06 PM »
Load Sensing Pressure Valve, supposedly senses wheight in the bed and changes braking power. most people cut the part going to the axle and tie it up.
Bobbed 84 xtra cab, pickin up parts as I go.
If at first you do not succeed, put it in 4low and try again.
84xcab
  • Male Posts: 261
« Reply #2 on: Aug 09, 2009, 10:46:46 PM »
heres a link with a custom adjustable bracket that could be made cheap
http://board.marlincrawler.com/index.php?topic=23316.0;highlight=lspv
axled89 [OP]
  • Male Posts: 2,526
« Reply #3 on: Aug 09, 2009, 11:10:08 PM »
so cutting it would make the rear brakes totally not work.  or  would it make them just skid allot easier.
89sastoyo
  • Turtle Points: 148
« Reply #4 on: Aug 10, 2009, 12:05:48 AM »
ok if your take that little clip thing off the rubber boot and pull on it it will come off i took them off both my toyota's and can lock the rear brake up doesnt leak or anything so its fine to take it off. I see it pointless being there unless your towing a trailer or somehting which is semi unheard of on a toyota
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
chim
  • Turtle Points: 1302
  • Male Posts: 1,258
  • Member since Apr '05
  • www.infowars.com
« Reply #5 on: Aug 10, 2009, 02:22:04 PM »
I cut mine about 2" from where it comes out of the valve on the upper frame side and zip tied the the 2" extension parallel to the cross member above it, and never once had any braking issues and my 4runner doubled as a daily driver as well as a wheeler... So cut away!
ballzdeep4x4808
  • Member since Jun '09
« Reply #6 on: Aug 10, 2009, 02:54:53 PM »
x2
crazykooter
  • Turtle Points: -369
  • Male Posts: 1,418
  • Member since Apr '09
  • Located in Byron, CA
« Reply #7 on: Aug 10, 2009, 04:32:42 PM »
I just removed my rear valve today and I havent noticed any diff from when it was on.  Although I did have it pinned up.  I removed it since it was leaking.
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
« Reply #8 on: Aug 10, 2009, 06:21:24 PM »
i sell a adjuster for it
Last post Oct 10, 2005, 02:35:29 PM
by TURNER
Last post Jan 10, 2006, 03:01:36 PM
by KWP
Last post May 03, 2006, 05:23:36 PM
by 79coyotefrg
Last post Jun 23, 2006, 07:54:50 PM
by MudSlinginYota
Last post Sep 23, 2010, 09:50:34 PM
by brainlessfool
