3/4 ton D44 rotors, 8 lug and use 1/2 ton calipers.find the brackets on ebay or pirate for around 60 bucks.
If your axle is semi float, I'm guessing it's 6 lug. If so, use half ton Chevy rotors. If it is 8 lug, use 3/4 ton Chevy rotors. In either case, the calipers are the same dimensions so will bolt in place of each other but the 3/4 ton calipers do have a slightly larger piston for greater clamping force.
I am just assuming it is semi float. It is under an older dodge 3/4 ton at my uncles house and I havn't had alot of time yet to look at it. It still has the hubcaps on it. I plan to have it at my house hopefully by this weekend.
3/4 Dodge=FF 60 w/30 spliners. The semis came under few trucks (J10s, heavy1/2 Chevys, etc.) Blue Torch makes some awesome parts and Dan is a great guy to deal with. I haven't used his caliper brackets but I'm guessing the quality is on par with the rest of his products. I have used Great Lakes Offroad brackets (Pirate or EBAY) and they worked perfect. I had a Ford 60 so they were slightly different. When I got them they were $45 shipped with hardware, I believe they are currently around $60.
Yeah I just went cheap on a build and bought Great Lakes plates for a Dodge 60 to GM calipers. I had to grind more than 60 thou out of the axle radius to get em to fit. I would use blue tourch every time now. saves the aggrivationWayne
Started by SQUIRREL MONSTER « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by PreRunnin41 Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by Dr.Maxwe001 Project Research and Build-Ups
Started by 84toyota4x4sr5 Parts For Sale
Started by al7ou@hotmail.com 1989-1995: How-To Guides
