1966 Toyota Stout Build (20/22R Hybrid)
Started by SloCrawler, July 30, 2009, 05:47:42 PM
SloCrawler
So finally got confirmations I needed,  all smog removed motor 99% back together when to fire up and nothing, no click nothing. Windshield wipers work. Found no signal wire to engage the starter solenoid,  more the starter relay. Somewhere between me the middle owner this component disappeared,  or I just can't find it and my key contacts are. Originally an 81 hilux if any of you have input on location and what connection in the harness it is. Others wise I might try a push button starter not sure how that would work with the clutch safety?
Sent from my SM-G900V using Tapatalk
SloCrawler
Any input appreciated,  glad the beast is about to be alive again. Decided to do LC Cam and timing gear after I get DUI distributor after talking to a friend.
SloCrawler
Fired the hybrid today,  so excited, this has been years in the making. Got to install my better cam and tourqe the bolt under timing gear, other than fixed all leaks. Need to adjust valves when she gets warm and adjust the weber carb wants to die when I give it gas. Should start moving along faster now with the body swap
SloCrawler
  this is the wire I was missing to start solenoid, the green and tan plug, also had to connect the ground on this little sub harness and she fired right after a little fuel down the carbs.
SloCrawler
Didn't like how the adjustable cam hit mechanical fuel pump lever so ended up wiring carter electric on frame well
Cleaned frame and painted a little as well
_HOIST_
Holy windshield price to ship! That'd be a major bummer.
Cool project, the older the better!
green200b
That's awesome. Whilst I really like the early Toyota shape, I like the look of what is happening here. Keen to see it all finished and driving  :thumbs:
green200b, aka Alistair
1982 Toyota Hilux 4WD - 350 Chev, G52, 4.3s, Detroit Locker, 33x12.5 mud tyres
1981 Mazda RX-7 Sport, 12A rotary - daily
1974 Mazda RX-2, 13B rotary - cruiser
1980 Datsun 200B - first car, now hibernating
H8PVMNT
– Steve McQueen
pleasetellmeno
SloCrawler
Front body mounts complete minus needing to be drilled.  Reinforced front body to mount better. Good friend who kindly has the space to do the work moved in the middle so on hold till he's settled. Loving the stance so far
pleasetellmeno
Right on! i'm in San Luis, i'd love to come check out the build sometime. maybe when you get settled back into a work space
SloCrawler
For sure.  We are part of Slo County Crawlers. Always welcoming fellow crawlers
SloCrawler
Got some more goodness to install
Crawlnow
82hilux
Any update on the body swap or finished yet i enjoyed reading this write up looks killer btw
I love my 4 wheel digger
SloCrawler
Waiting on my welder friend to finish moving into he's new home before able to finish, thanks for the support
Crawlnow
thought about rzr seats in mine. ended up finding 2015 chevy equinox seats on craigslist.  black leather with red stiching heated and power but i havent found a control for the heat. cant wait to see the finished product. probably have to do a bunch of the same bs i had to.
joeyf
Are you planing on making a cage for it.
SloCrawler
Quote from: joeyf on November 16, 2017, 02:16:19 PM
Planning on exo caging the cab, possible dove tail rear into cage just using bed skins
joeyf
I hate exo's but I think I may end up going that route to. Looking forward to seeing what you come up with. That A pillar is going to be very hard to make look good, it's one of the big reasons I haven't started on my stout cab swap.
SloCrawler
Quote from: joeyf on November 16, 2017, 04:35:58 PM
Got to protect my $900 windshield so I'll have to figure it out
SloCrawler
Coming back to life soon
Sent from my SM-A215U using Tapatalk
