82 Toy, it begins!
Started by YotaNate, July 30, 2009, 07:03:40 AM
YotaNate
Quote from: 79coyotefrg on September 11, 2009, 10:29:06 AM
ground wire,  it goes under a bolt on the power steering, over to a plug on the regulator harness
i'll try and look and see what plug  on my truck
Awesome Glen!  You are the man.  I'll go take a quick look and see what I can find before I have to pick the little guy up from school.  I'll be back and about 45 Min.
Nate
"A CNN reporter, while interviewing a Marine Sniper asked.  What do you feel when you shoot a terrorist"?
The Marine shrugged and replied, "Recoil."
YotaNate
A smaller problem but very annoying...
Oil is leaking from the bottom of the fuel pump like crazy!  I can watch it drip!  I pulled it back off and used black rtv on both sides of the spacer and gasket and it's STILL leaking!  What am I doing wrong?
Nate
Dr.Maxwe001
[img]http://bo
Quote from: TJNate on September 11, 2009, 10:35:05 AM
Nate
spacer is broken,  get a new one
YotaNate
Quote from: 79coyotefrg on September 11, 2009, 11:04:49 AM
Yeah it was broken, i put it back together with rtv in the crack until the new one comes tomorrow.  Any info yet for the wire Glen?  I'm realy nervous driving without that!  Plus I still cant get the truck into gear while it's parked and the engine is running.  I have to put it in gear and THEN start it.
Nate
83MT
Looks a bit like this, no?
Shifting issue sounds like either master or slave cylinder going out, not adjusted right, or fluid has air in it.
Zach
I like Yotatech
YotaNate
Yes it does 83MT !  Now where in the world does the other end go lol :headscratch:
Nate
pumkin toy
if that wire does plug into the regulator harness, and its not hooked up,   thats probly why your battery is dying.  your regulator must not be working right.
97 4runner Limited
Quote from: pumkin toy on September 11, 2009, 05:17:22 PM
ya think :eek:
Nate,  i didnt get a chance to look at my truck today, and its dark now
i'll look in there tomorrow
pumkin toy
Quote from: 79coyotefrg on September 11, 2009, 05:35:25 PM
ya think :eek:
yeah my post sounded stupid but sometimes people dont make the connection in their head.  I was just simply stating that so TJNate can test to see if his charging system is working properly again when he gets the wire hooked up.  you would be surprised how many guys i talk to that have yotas and dont even realize they have a regulator or what its for.
97 4runner Limited
Quote from: pumkin toy on September 11, 2009, 05:46:17 PM
yea  you DO have a point,  i mean  yesterday i was talking to a friend on facebook and they said "i had a DA moment"   i was like HUH??
about a hour later it hit me like a BRICK :doh:  DA = dumb ass   :rofl:  and i felt like one
YotaNate
UPDATE:
 OK so I found a connector over near the regulator that was only using 3 of 4 openings and upon closer inspection the "empty" slot looked way to clean where the wire could be.  Long story short i pulled out the rubber seal slid the blade end of the wire in there and it plugs right in.  I went ahead and put the eye end of the wire on a bolt that hols the PS bracket on as Glen had suggested and it all seems to work fine!
 Glen i pulled that damn fuel pump off and sure enough that damn spacer was cracked right on the bottom!  It was brand new to!  Damn Autozone!  I ordered a new one but after cleaning it all up and putting black RTV in the crack it is no longer leaking.  I'll keep an eye on it and replace as needed.
 As for the transmission I was able to put about 10 miles on the truck and now it goes into gear just fine at a stop with the clutch in!  It take alto of effort between gears but my last one took a while to break in if i remember right (that was almost 10 years ago!).  Anyway another fine product from Marlin and the gang.
:thumbs:
adjust the clutch, if you have an adjuster on the slave just make it longer,  if not adjust the pedal
Halladay
whats a regulator?.....
kidding.......... :rofl2:
pumkin toy
Quote from: Halladay on September 11, 2009, 07:08:29 PM
it controls the flow of your muffler fluid! :yupyup:
97 4runner Limited
Halladay
Quote from: pumkin toy on September 11, 2009, 07:32:04 PM
really i was thinking it was blinker fluid level.... Shoot proved me wrong.......  :beerchug:
Toyospearo
GREAT LOOKING TRUCK!!
More pictures, more pictures!!
YotaNate
OK it got dark on us quick but here are a few more.....
Here is the new Downey springs going on the rear, yes it is possible to put them on backwards!  Thank god my wife was paying attention and noticed the wheel was not even close to being centered in the wheel well!  LOL  I guess I was a bit excited.   :hammerhead:
And more....
And here is my full time parts cleaner!  Damn i married a good one!  Love you babe! :ladys-man:
hilux-1983
Thought you said you got 3" springs. It looks taller than that. My wife would kill me if I posted a "surprise" pic like that:)
YotaNate
Quote from: hilux-1983 on September 12, 2009, 07:48:40 PM
haha they are supposedly Downey 3" springs.  She knows I posted the picture she just rolled her eye's and told me I had to take her to breakfast in the morning.  I work 1500-0100 so that's Eaaarly for me!
Nate
hilux-1983
It looks great. You'll be able to use your own rig for your computer background before long!
Truck's lookin good man  :thumbs:  Springs should settle a little bit, I've never seen a set of Downeys sit that high  :yikes:
YotaNate
The sun is not even up yet but I had to get a picture for you guys!
And from the front
I took the rear mudflaps off because the were pretty close to the tire.  After I drive it a few days I am going to try and put them back on and see if there is enough room to run them.  Thanks for looking!
Nate
unclejpl4x4
I can't believe i missed this :slap:
I have seen Toyota water pumps do that before well that's why i got a new T-cover for mine.
The inside the the truck is way clean :thumbsup:
your parts cleaner is nice :boobs:
O and my i suggest well i would do it  INSTALL A OIL P -GAUGE  so U can watch it :psss: i don't trust those people.
and yes ATM your motor is pretty it will me covered in mud fist time u go out don't :rivers:
84pickup
man i want your truck! lol i'm so jealous. especially now that i'm out of a truck. i couldn't help but notice your exhaust. On my 84 i had stock exhaust manifold to straight pipe to a thrush glasspack with an echo tip right off the end and i loved the sound of it. it did get a bit ricey in the upper RPMs though. can't wait to see some action pics!
lets not and say we did.
hilux-1983
YotaNate
Quote from: 84pickup on September 13, 2009, 12:59:31 PM
man i want your truck! lol I'm so jealous. especially now that I'm out of a truck. i couldn't help but notice your exhaust. On my 84 i had stock exhaust manifold to straight pipe to a thrush glasspack with an echo tip right off the end and i loved the sound of it. it did get a bit ricey in the upper RPMs though. can't wait to see some action pics!
That Thrush thing was  $19 way to not annoy my neighbors :D  With the next paycheck I'll be looking for an exhaust shop than can set me up with a nice stock exhaust replacement.  I want the truck quiet and comfortable and the thrush is neither LOL.
Nate
YotaNate
#88
Problem:  Truck runs good down low and idles great, more than half throttle and it cuts out for a second and then when it catches its all broken up.
Engine, brand new ATK longblock 22r
Carb, brand new Weber 32/36 on Offenhauser (SP?) intake with NO smog
Cam, stock as it came in the long block
Exhaust, LCE Header with 4' of pipe to a crappy Thrush muffler (until I get it into the exhaust shop, I want the truck QUIET)
Timing is set at 5 Degree's at idle and if I hit the throttle while watching with the timing light it shoots up to around 12 degree's so I know the advance is working.
Brand new NGK plugs and 8.5mm wires.
K&N Air filter
I was under the impression the carb would be pre set up for a stock 22r and I'm at sea level here in NC so I doubt elevation is a factor.  Anyone help me out here?  I know this little motor should run real good and I don't want to drive it around at 1/3 throttle all the time!  PLEASE HELP!!
Nate
****EDIT**** I just remembered I have not run a 12 volt source to the electric choke, I will do that in the morning as well.
Nate
toysnowta
Sounds like a carb proplem, those webers can be really tempermental at times. Try this link
http://board.marlincrawler.com/index.php?topic=45126.0
It helped me a lot when I was having troubles with my weber. Nice dogs btw, I've got a pair of the little monsters as well.
83 bobbed yota 4" pro comp lift with 5.29s and an aussie up front sittin on 35" toyo m/ts.
