Author Topic: Flywheel Install?  (Read 1686 times)
YotaNate
  • Male Posts: 276
  • Member since Dec '06
Flywheel Install?
« on: Jul 30, 2009, 05:14:14 AM »
How do you keep the engine from rotating when torquing the flywheel to the crank?  The last time I did this was a long time ago on a supercharged 408ci small Chevy and if I recall there was a slot where I could insert the handle of a tool in order to torque the bolts without the engine trying to rotate.  If anyone has a suggestion please let me know, I am sure there is a nifty trick.  Also is there a specific torque or just "good and tight"?  Thanks guys and gals!
Nate
"A CNN reporter, while interviewing a Marine Sniper asked.  What do you feel when you shoot a terrorist"?
The Marine shrugged and replied, "Recoil."
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
Re: Flywheel Install?
« Reply #1 on: Jul 30, 2009, 06:46:45 AM »
Use a tie down strap around the ring gear, and tie it off to the frame.
I used a piece of flat bar, drilled to fit the bolt holes for the clutch housing.
YotaNate [OP]
  • Male Posts: 276
« Reply #2 on: Jul 30, 2009, 06:48:47 AM »
Thanks cheese.  I will have to find a flat piece of steel i can fab up to work.
Nate
Joey88RUNR
  • Turtle Points: -23
  • Male Posts: 1,057
  • Member since Feb '08
« Reply #3 on: Jul 30, 2009, 06:50:22 AM »
i just impacted mine on :hammerhead:
83MT
  • Member since Jun '08
« Reply #4 on: Jul 30, 2009, 06:51:19 AM »
Use thread lock. And yes there is a specific torque. Don't know it off the top of my head but there's definitely a specific torque.
Zach
I like Yotatech
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #5 on: Jul 30, 2009, 01:11:24 PM »
If it's in the truck, a socket on the front pulley bolt ..........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #6 on: Jul 30, 2009, 06:53:51 PM »
:werd:
Cheesemaker
  • Male Posts: 4,525
« Reply #7 on: Jul 30, 2009, 09:25:32 PM »
The torque is like 85 lbs.
And the clutch housing is 14 lbs.
Moit88RNR
  • Turtle Points: 39
  • Male Posts: 360
« Reply #8 on: Jul 31, 2009, 09:47:42 PM »
i used a pry bar in the teeth and screwed a trans. bolt into the block to get leverage off. thats how it says to do it in my Chiltons. and its 73-86 ft. lbs. to be exact :gap:
Last post Dec 10, 2003, 12:02:22 PM
by vikingsven
Last post Jan 12, 2005, 03:07:35 PM
by Mike D
Last post May 31, 2005, 10:52:20 PM
by WHITE_TRASH
Last post Jan 24, 2006, 08:02:10 PM
by kneedownnate
Last post Mar 10, 2008, 12:36:57 PM
by yota18
