Did you change the condenser?The old style serpentine (R12) condensers aren't efficient enough for R134a (and too restrictive).You really need a parrallel flow condenser if you've gone to R134a.
I use to use a set up from Flex-lite called the "blackjack". It comes with all of the hardware and sensors. I had it in my 83 toy with a/c. When it worked, it worked great. It pulled plenty of air. The design is flawed a bit. They put the circuit board down in the middle of the main part of the heat being drawn from the radiator. It failed on me 4 times and finally got my money back. If they had relocated the board where it wouldn't over heat it would be great. I don't understand why they wont re-design it. I'd love to have an electric fan back again. I installed the mechanical fan back in for now. I did run across another build thread that the guy is using a 16" slimline puller. It has the sensor and board located anywhere you want. He got it from summit racing. I am still using r-12. It's a few degrees colder and more expensive but I think it's worth it.
you are then going to need to get a huge electrical fan, brecause that will be blocking the airflow of wind force driving through to the mechanical fan.... so it better be able to move enough air do offest it blocking some of the natural pressurized air from driving
No, the condenser is stock. Thats a great idea. Is there a new condenser for R134a that is a direct bolt in? (name, part number, etc??)
Propane has long been used as a refrigerant, and was used long before r12 w/o issues. There also isn't that much actual propane in the cans, and IIRC I only used two of the cans to fill the system. If it was to leak out during an impact it would be so quick it wouldn't be an issue, and would/should be able to detect it if it leaked into the cab, whereas there isn't a smell w/R134.The report I read about testicle tumors was in a study done w/rats, so the levels used may be more determinant than simple exposure, but it is hazardous and can be deadly if you inhale the gas.Actually IIRC R134 is also being discontinued since it also contains ozone depleting properties.
Started by RustyToy Engine
Started by olemisstoy88 Toyota Pickup/4Runner Tech 1979-95
Started by jrock Project Research and Build-Ups
Started by 19864runner Newbie Questions
Started by 83yota Engine
