electric fan
Started by jrock, February 07, 2007, 04:26:06 PM
jrock
i know the black magic fan from flex-a-lite($220) is on of the best but is it worth the money? i just want an electrec fan to save gas. would it be better to get a fan from kregan($80). the black does come with thermo. sensor.
robrub00
do a search for a taurus fanon here or pirate 4x4.  you can get them from a pick and pull yard.  they are ausome!!!!  you can get a thermo switch from kragen for it cheap.  there  is a write up some where if i find it ill post it up
bunch of stuff for sale!!!!------> http://board.marlincrawler.com/index.php?topic=31225.0
robrub00
jrock
thank you. thats perfict.
dov'd85
#4
Quote from: robrub00 on February 07, 2007, 04:37:39 PM
http://www.pirate4x4.com/tech/taurus/index.html
here is one.  thare is a ton more info
thanks for the great link!! so what did it take to run your radiator in the back? i have been thinking about it for a long time i just cannot figure out what to use as  far as tube from the font to the rear? spend the money and use like HERW or some 1 1/2 or 1/4 exhaust? i like the rear of your truck so do you run a switch or is it constant? and what is the fourth post for?
nice battery mount.. i like were it is :thumbs:
85 long bed: 30 spline long, hydro assist, hysteer, 223.1 twin sticks, 39.5 iroks, rear disk,
http://board.marlincrawler.com/index.php?topic=28696.msg344178#msg344178
robrub00
thats not my truck!  i wish.
Listen, if you are going to go e-fan, then please at least make sure it will be as reliable as possible by using a programmable computer controlled thermostat.
http://www.dccontrol.com
robrub00
jrock
both cites way cool. thanks. anyone ever use either, which is longer lasting and such?
Saber
Quote from: jkief86 on February 07, 2007, 04:26:06 PM
The Flex-a-Lite Black Magic (400-165) is 100% absolutely worth every penny.  Adjustable thermostat, truck loads of air movement, shroud, and super sexy.  The tight shroud is what really makes the difference when comparing against standard electric fans.  Settle for something cheap and you'll be pissed later...
***  SAS'ed '94 ext. cab - V6 auto - 4.88's - TrueTrac front & rear  ***
DavidW
There is a guy on the Pirate classifieds that usually has some on hand.
DavidW
