electric fan....
Started by RustyToy, May 31, 2005, 09:37:35 PM
RustyToy
Has anyone puy a flex fan or electric fan into a 82 truck and what did you use?  I"m confused....
Yup its an easy fit and install but you really dont gain much except heating issues..
RustyToy
whatone do i use. will the 150 universal work or do i have to pay outthe arse for the toyota one. i have a 82 toy. i'm not expecting much horse power. its just when i go over 65 on the freeway the temp goes way up.
Sounds like your radiator is going away. The fan is totally out of the picture when your going that fast.  you can get a radiator from www.radiatorbarn.com for $112 shipped to your door for a 3 core heavy duty one. ;)
RustyToy
you mean the fact that i have no fins on the bottom 3rd section of my radiator mightbe the problem? chit.   :dunno:
LOL  yea that should be a sign....  If you fan clutch is in good shape ie it doesnt spin forever and you've changed the thermostat in the last decade your radiator is gone.  Save your $$ fromt he fan buy and get the 3 core rad.  Its a bolt in deal.
Uncle Jesse
A stock fan clutch will work the best on a properly functioning system.  I ran one of those flex a lite toyota fans on my truck and like white trash said, all I got was overheating issues.  Also keep in mind that in an 82, the stock alternator is what, a 40 amp?  Running a fan that pulls 20?  Thats only 20 amps left over to run the truck, forget about running the headlamps and the heater blower. . .
Along the same line, what you horsepower you gain by removing the stock fan and clutch you lose by having to drive the alternator harder.
RustyToy
never thought of it that way... good point... sometimes its a good idea to do the math.
Duffil
I wouldn't even think about a flex fan...they are designed to have the blades flatten out at higher RPM, thus reducing drag and increasing HP, however slightly.  In a 4x4(think gear reduction), you might be at 3500 RPM, yet only moving 2MPH, which is not enough to cool the engine while running a flex fan.
RustyToy
thanks guys... new radiator is in and everything is running great.. i'm goin to the goat ranch...
crawlerdan
my buddy put one on his 83 22r pickup, it added about 5-7 hp, not that you can really feel it, but anything helps. he used a flex-a-lite fan, it was about 200 dollars i think
shad
#11
Can't just run a ford taurus fan? I got one for $25 from the junkyard I used to have that setup in my 93 runnah. Worked good but you would have to watch the manual cut off switch.
I had problems remembering to turn it back on.
The downside I had to upgrade my alternator to at least a 105 amp one.
I think on low fan which is all I had to use it drew like 35 amps.
I used a 40 amp relay and a manual adjustable temp switch to turn it on and off with a override switch to turn it off for water crossings and stuff.
86 Toyota 4 runner
My cardomain page
crawlerdan
that sounds like an electrical nightmare. :shocking: mmmm pre wired harneses! :bowdown:
DeMented Toys
I put a flex-a-lite Black Magic electric fan on my 92.  It has a 22RE.  The fan works fine.  I noticed a little bit of an increase in power, but not too much...  I think the money would have been better spent on a header.
Jeff DeMent
-DeMented Toys-
b_ripper8
I ran a black magic electric fan over 6K miles and never had any heating problems. I did however, break 4 of the blades off when I went through some mud so I'll never run one again. You can't replace the blades either so now I had a spare motor if anyone wants to buy it off me.
In Progress: 3RZ-FE Swap Underway.
Currently: 87' 4Runner - SAS - 5.29's - welded rear - Dual 2.28 cases - Optima bluetop - round headlight conversion - FZJ80 grill - rattlecan paint job - trimmed fenders - Ranger hybrid springs front - Tacoma hybrid springs rear - schedule 160 drivelines 8" slip front - Marlin's crossmember - disk brake conversion
crawlerdan
b_ripper8
Yeah, sucks bad. Biggest waste of money.
RustyToy
i thought the fan idea would be great... dont sound so great... i'll stick with the stock for now. the one works great in my runner, but its just for the streat and snowboarding.
b_ripper8
Yeah, there are difinately other things that would be worth the money before an electric fan. On the other hand, if you can get one for free, it wouldn't be a bad idea to rig it up. I always carried a spare stock fan which I did end up needing. Anyway, in summary, don't spend money on it, if you're having heating problems get a three row turbo radiator first.
BUBBA
One of the biggest reason's I went with an electric is because of a 3inch body lift.Rather than trying to relocate the rad I just put one on I had laying around.It came off a taurus I think,got it from a friend for nothing.
My budget beater
