Author Topic: electric fan  (Read 3155 times)
olemisstoy88
  • Turtle Points: -381
  • Male Posts: 521
  • Member since Dec '05
electric fan
« on: Jan 24, 2006, 12:47:34 AM »
I have a fan from a 4.0 jeep. I wnat to put it on my truck in place of the stocker. Do ya'll think it is beefy enough? It is about the same size as the stock in width and diameter. I think its a puller. but that doesnt matter if I wire it the other way right? If I do wire it, what size relay do i use?
88. 4x2  Total chaos 6.5" caddy uniball kit  Racerunner 2.5 x 14" coilovers on front, 62" deavers, fabbed engine/shock cage, bed cage, roll cage and great frame, complete int., (5) 5x4.5 outlaw II w/235 buckshots <----- parting out! make offer
'84 4x4 . 5 speed 22r  3.5" lift  33x10.5s bfg MTs  Hannamann Glass frontcap, 32/36weber, LCE swirlie plate, Magnaflow,
"Im madder than Toby Keith at a Dixie Chicks concert"
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: electric fan
« Reply #1 on: Jan 24, 2006, 02:40:07 AM »
a puller fan is what you want under the hood of the vehicle..... you are trying to pull cold air into the engine bay from outside... not push warm air through the radiator into the outside air....
a puller is a puller, reversing it jsut makes it ineffective... it wont work properly trying to run the dc motor in reverse as the blades arent tuned for that
89 toy
  • Turtle Points: -1198
  • Male Posts: 383
  • Member since Dec '03
Re: electric fan
« Reply #2 on: Jan 24, 2006, 11:03:30 AM »
a pusher fan mounts to the out side of the radiator and pushes cold air from the front of the truck thru the radiator. u can mount a fan either way you just have to wire it acordingly.
krawlz
  • Male Posts: 106
  • Member since Jan '06
Re: electric fan
« Reply #3 on: Jan 24, 2006, 01:50:04 PM »
FLEX A LITE MAKES A GREAT(PULLER) FAN FOR THE 84-89? YOTA. i PUT ONE IN MY 83 WITH SOME MODIFICATION TO THE CORE SUPPORT. IV BEEN RUN'N MINE FOR ABOUT A YEAR. GOT IT WIRED WITH A SWITCH FOR DEEP WATER.
CALL SUMMIT RACING FOR INFO
Any man, in the right situation, is capable of murder. But not any man is capable of being a good camper.....So, murder and camping are not as similar as you might think.
Some men are alive simply because it is against the law to kill them.
Bob Garrett
  • Turtle Points: 7
  • Male Posts: 134
  • Member since Mar '04
  • Lone Star Land Cruisers
Re: electric fan
« Reply #4 on: Jan 26, 2006, 10:56:35 AM »
Unless you're running a different engine or doing deep water crossings, why would you want an electric fan?
Bob Garrett
95 FZJ80
83 Mini Truck
olemisstoy88 [OP]
  • Male Posts: 521
Re: electric fan
« Reply #5 on: Jan 26, 2006, 11:04:48 AM »
its just sitting in my room. I used one one my chevy for a long time and just figured it would have the same benefits. I would just like to know what size regulator I should use.
krawlz
  • Male Posts: 106
Re: electric fan
« Reply #6 on: Jan 26, 2006, 02:56:05 PM »
The reason I went electric   :shocking: ,Is couse I had a overheating problum on long idle times on the trail. Tried a new clutch fan and Rad. But did'nt work tel I put in the electric.
  • Administrator
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: electric fan
« Reply #7 on: Jan 27, 2006, 08:12:47 AM »
krawlz
  • Male Posts: 106
Re: electric fan
« Reply #8 on: Jan 27, 2006, 10:09:05 PM »
:biggthumpup: Thanks for the link. That looks like a worthy  :twocents: investment. Right after I get this  trailFlex Kit in.
P.S. Anyone concedering an electric fan on an older rig, your gonna need to upgrade your Alt. The stock 40 Amp doesn't cut it. I'm running a 105 Amp Delcotron. Pretty easy install.
 Oh ya BIGGER wires to.    :sad2: Trust me.
AKDuramax
  • Turtle Points: 77
  • Male Posts: 47
  • hondas R like tampons... every pu$$y has one
Re: electric fan
« Reply #9 on: Jan 31, 2006, 08:10:33 AM »
my buddy has a stock alt on his 83 and we hooked up a elctric fan and it works fine
83' toyota sr5 long bed 31x10.5 bfg mt's -under construction-
86' suzzuki samuri 33x14.5 boggers, 1.6 tracker spap, 4.62's locked trackuri axles, 4.1 transfer, exct.
02' chevy 2500HD duramax 35x12.5 mt's fabtec 6", edge box,k&n intake, mbrp 4" duals, exct.  :)
synwars
  • Turtle Points: 360
  • Male Posts: 485
  • Member since Mar '05
  • Fabbing with Maffy
    • Can you feel the love?
Re: electric fan
« Reply #10 on: Jan 31, 2006, 05:04:55 PM »
Because they are better?
I can work on the inside of my engine compartment with the engine running without having to worry about hacking my hands or fingers off.
Built in shroud. Controls. More efficient. Smaller. Lighter. I can pull my engine more quickly. You know... All sorts of pluses!
"Don't let common sense stop you..."
Build up thread:
http://board.marlincrawler.com/index.php?topic=11425.0
KEEP IT CLEAN PEOPLE!!! :bat:
krawlz
  • Male Posts: 106
Re: electric fan
« Reply #11 on: Feb 01, 2006, 04:03:04 PM »
Ill very true statements. When I put elec. in, I ended up being very pleased with myself for all those reasons and more. My problem was, when i was on a night run and had everything on, ( Stereo, Lights, Heater, Fan, and more Lights) Things got a little toasty under the hood. The stock Alt. and wiring couldn't handle everything at once. So I had to figure out an upgrade. Not to mention more power for the Wench.
Last post Jul 06, 2009, 11:32:11 AM
by hilux-1983
Last post Jun 27, 2010, 08:19:30 PM
by Shamb
Last post Jul 08, 2010, 11:13:38 AM
by Shamb
Last post Sep 09, 2010, 07:54:39 PM
by Snowtoy
Last post Jul 08, 2011, 03:58:44 PM
by topar
