Author Topic: Having Trouble Pulling A Pitman arm.  (Read 3942 times)
crawlerdad
  • Male Posts: 395
  • Member since May '09
    • Please ban me!
          OK!
      I am banned!
« on: Jun 11, 2009, 05:45:34 PM »
I have been trying to pull the stock pitman arm off my Toyota box and have broken two pullers. Anybody have any tricks up there sleeves? :dunno:  Yes I did take the nut off. :screwy:
Precision guess work done here.
slabcs
  • Turtle Points: 329
  • Member since May '05
Re: Having Trouble Pulling A Pitman arm.
« Reply #1 on: Jun 11, 2009, 05:48:03 PM »
Hit it with a hammer a couple times when you've got that puller on nice and tight.
Relentless
Slolyfe
  • Turtle Points: -117
  • Male Posts: 2,048
  • Member since Aug '07
  • Heyo
You'll never take me alive
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #3 on: Jun 11, 2009, 05:49:33 PM »
heat it up with a torch
spray the splines you can get to with pb blaster
bfh
pickle fork
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #4 on: Jun 11, 2009, 05:50:49 PM »
I usually drowned it with PB Blaster, let it sit overnight and it has always come right off.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #5 on: Jun 11, 2009, 06:06:29 PM »
cut off wheel
yjay
  • Male Posts: 555
  • Member since Feb '09
  • SFA Station Wagon
« Reply #6 on: Jun 11, 2009, 06:12:25 PM »
I had one I could not get off-broke a puller, heated it, hit it, PB'd it. I ended up cutting a groove in it with a skinny wheel as close to the shaft as I thought was safe, then put a big chisel in the groove and hit it to crack the arm. Works great if you don't need the arm.
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
crawlerdad [OP]
  • Male Posts: 395
    • Please ban me!
          OK!
      I am banned!
« Reply #7 on: Jun 11, 2009, 06:44:06 PM »
I think the cutting wheel will help me get my aggression out on my task that was not supposed to be this hard. Thanks guys! :biggthumpup:
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #8 on: Jun 11, 2009, 06:56:55 PM »
I broke 2 pullers too, then gave up and got my money back on the puller......... (free life-time replacement)........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Inittowinit
  • Male Posts: 207
  • Member since Jan '06
  • AKA: inittowinit
« Reply #9 on: Jun 12, 2009, 01:22:45 AM »
PB Blaster(its what I like) the hell out of it in advance...tighten puller... hit pitman arm down with hammer...tighten...hammer...tighten...hammer...continue until you win
Trick:when puller is fisrt tightened...max it out(or just before you broke it the last time)...then hit arm w/ hammer...next time puller is tightened its only going to turn a small amount (a few degrees) until maxed out again...turns get progressively larger as it goes
"Lunatic friends, I know you're out there"
http://www.youtube.com/watch?v=3PGNCeVuYBw
zippo
  • Turtle Points: 550
  • Male Posts: 1,557
  • Member since Nov '08
    • oppiz.net
« Reply #10 on: Jun 12, 2009, 02:05:41 AM »
Put some heat into it. not to much just enough to make things expand. NOT RED HOT. then pull em.
« Last Edit: Jun 12, 2009, 02:21:00 AM by zippo »
If you see it, its for sale.
crawlerdad [OP]
  • Male Posts: 395
    • Please ban me!
          OK!
      I am banned!
« Reply #11 on: Jun 12, 2009, 07:21:34 AM »
Has anyone damaged the box with the hammer trick?
fordh8r
  • Turtle Points: 850
  • Male Posts: 2,588
  • Member since Jan '07
  • when my toyota grows up it'll be just like my chevy!
« Reply #12 on: Jun 12, 2009, 09:17:37 AM »
It works!  :thumbs:  Just get that puller as tight as you can, without breaking the puller, and use a small sledge (3lbs or so, The bigger the better and not a weeny ballpeen) and hit the large surface of the arm towards the front of the truck. It should just pop right off. I've had plenty of stuck arms in the past and this works everytime. You may have to repeat the process more than once until it's off. Good luck.  :crossed: :beerchug:
Slolyfe
  • Male Posts: 2,048
  • Heyo
« Reply #13 on: Jun 12, 2009, 01:36:43 PM »
Yes, I screwed around with heat banging and prying, and damaged the seal on the bottom of the box.
toyotanner
  • Turtle Points: 66
  • Male Posts: 1,958
  • Member since Oct '07
  • low n slow
« Reply #14 on: Jun 12, 2009, 02:05:04 PM »
i had to heat mine up with a torch and i took a pretty decent size hammer and gave it a few whacks and PRESTO it was off
Bazzi
  • Turtle Points: 97
  • Male Posts: 1,095
  • Member since May '04
  • From Reykjavik Iceland...
    • R&T
« Reply #15 on: Jun 15, 2009, 05:27:36 PM »
I have taken a qouble boxes like this..... remove the box from the truck,  remove the 4 bolts on top of the box. examine the shaft,  when it is turned right the shaft goes through the box, only the arm is stopping it, put it in a press. and voila no problem. only down side is that you might need to replace the seal
 2,4 dti duals 2,28 x 2,28 to 8" 5.71 with arbīs  and 39,5" trxus
crawlerdad [OP]
  • Male Posts: 395
    • Please ban me!
          OK!
      I am banned!
« Reply #16 on: Jun 18, 2009, 07:51:31 PM »
 :thumbs:  Well after letting it sit for a week I went back to conquer it and I started to cut it off then applied the puller and it came off with little effort. I think after letting it sit the penetrating oil got into it and took the work out of it. Thanks for the help.  :thumbs:
fordh8r
  • Male Posts: 2,588
« Reply #17 on: Jun 18, 2009, 09:03:07 PM »
Nice!  :gap:  Now, get to work!  :whip:  :cheese:
crawlerdad [OP]
  • Male Posts: 395
    • Please ban me!
          OK!
      I am banned!
« Reply #18 on: Jun 18, 2009, 09:26:17 PM »
I am so close  :hammerhead:  I hope to get the runner done this weekend. Well done enough to play with.
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
« Reply #19 on: Jun 18, 2009, 10:39:32 PM »
Blow Torch, Blow Torch, Blow Torch, Blow Torch, Blow Torch, Blow Torch, Blow Torch, Blow Torch, Blow Torch, Blow Torch, Blow Torch, Blow Torch, Blow Torch, Blow Torch, Blow Torch, Blow Torch, Blow Torch,
And then :ladys-man:
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
Slolyfe
  • Male Posts: 2,048
  • Heyo
« Reply #20 on: Jun 21, 2009, 06:03:47 PM »
Just be careful with all the beating and heating. This happened to me on the rubicon this weekend.
potter85
  • Male Posts: 257
  • complete disregard for sheet metal.....
« Reply #21 on: Jun 21, 2009, 06:13:13 PM »
dont make the mistake of heating the shaft.... heat the arm evenly around the shaft put the puller on it till it is about to break then hit the pitman arm with a BFH.... make sure to do this quickly because the cooler the arm gets the more it shrinks back to normal.
that above picture is gnarly i have never seen that happen before wow....
3rz in the making
looking for 38s
2 tundra 4.7l v8 soon to be sas'ed
Slolyfe
  • Male Posts: 2,048
  • Heyo
« Reply #22 on: Jun 21, 2009, 06:18:59 PM »
Neither had anyone on the trail. hahaha Luckily someone had another box with the ears broken off but good insides.
hilux-1983
  • Turtle Points: 3
  • Male Posts: 1,271
  • Member since Apr '09
« Reply #23 on: Jun 21, 2009, 06:49:27 PM »
I aint trying to be a smart butt, but this would work better:
 :clap2: :clap:
crawlerdad [OP]
  • Male Posts: 395
    • Please ban me!
          OK!
      I am banned!
« Reply #24 on: Jun 21, 2009, 08:40:24 PM »
Wow that makes me glad that lube and puller worked for me.
Last post Sep 17, 2002, 11:10:42 AM
by rEdnECkwHeE1eR
Last post Jan 01, 2005, 04:48:01 PM
by Makohon
Last post Apr 21, 2005, 09:07:04 PM
by TOYJOETA
Last post Aug 25, 2006, 10:19:20 PM
by brainlessfool
Last post May 17, 2007, 07:34:52 PM
by brainlessfool
