Russell_G's 87 longbed build up. The door panels and interior wrap up.
Started by Russell_G, May 20, 2009, 01:55:00 PM
are you going to strip all the harness so its kinda like a plug and play deal?
Russell_G
Were still trying to figure out if were going to go that far with them. Most people i know that are in to swaps just want the full harness to cut in what they want. We can offer dash swaps and dash swap advice to people who want it and even factory sheet metal sections. Our motor swaps come with the tacoma battery trays and fuseblock mounting tabs for a factory look(same thing i did in mine)
Factory brackets out of the taco
87 longbed bobbed 12inches, locked,geared,Tacoma dash, 3rz swap Its a never ending project.
My build
http://board.marlincrawler.com/index.php?topic=58589.0
Russell_G
No new pics but this weekend Nate and i busted out all the lines for brakes,fuel and some body stuff...Then today Trent came up with nate and he taught me how to do the steering shaft. and got my PS lines to work. I have to cut and flare the main feed line for the fuel and have a new hose made to reach the other side of the truck and get some other line for stuff like the evap(have to add it or CEL even tho i dont want it) set pinion angle and pretty much button up everything. Its all easy stuff i can do while the shafts are being made. Dash will take an hour or so, Doors maybe an hour, Seats a few minutes battery, Fluids and stuff....I might be driving it for Xmas after all.
My build
peacesells
I had a question about the fatmat, do it cause any interior smell? Ive heard about some of the cheaper dynamat- like products that cause a tar smell when it gets hot outside. Im about to order 160sqft of fatmat 80 mil for my 4runner in the 115 degreed heat of az, just want to know for sure!
this my man lysol, fresh out the joint
Russell_G
Quote from: peacesells63 on December 14, 2009, 02:22:38 AM
I have not had it smell in any of the cars or trucks i have installed it in. The green truck we used almost the full 160sqft and it sat out for 2 weeks closed up and all i could smell is the new carpet. Its not Tar based like the cheap stuff at home depot people use. Its the same as all the higher end stuff but its not name brand so they are trying to get in the market...I used a heat gun on mine and stuck it down and had seeping edges and still havent smelled it.
My build
86rustbucket
what about on the roof? i heard it's no good on roofs the glue will fail at high temps. and it will be hanging on your head.
got any ideas on a homemade headliner?  mainly for insulation not looks
yota_krawler
Jakesteads
I like Toyota
Russell_G
Quote from: 86rustbucket on December 15, 2009, 12:43:35 AM
I layed it on fresh paint so it was clean and used a heat gun....I dont see it peeling anytime soon. I think as long as you clean it and press it on well enough you wont have an issue.
For a headliner maybe some jute padding with a rubber over it(same as the floor factory but they had rubber backed carpet)
you could glue jute padding on and thenthrow a bow in liner in like stock
Quote from: Yota wut? on December 15, 2009, 06:40:24 AM
bling bling you are in colorado?
yeah Live in longmont and work in longmont now(toyota parts shop) and have my own personal shop in FtCollins. LMK when you get in to CO and you can come check out what we have going on and maybe do some snow bashing
My build
yota_krawler
Russell_G
Thanks, Im not sure if it was worth it yet.
For you guys who have been watching....Longmont shop is stocking up fast. Call if you guys need stuff we do ship parts.
http://ttora.com/forum/showthread.php?t=146960
My build
Russell_G
Got a battery in it lastnight, Everything worked first try. Cranked it over but it died right away due to no gas tank. All the lights, Heater, Signals... Now to put the dash in, Seats in, Driveshafts, tank and button up all the wiring.
My build
Volcom
Quote from: Russell_G on December 21, 2009, 07:56:56 AM
You'll be driving it in no time!  Good to hear.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
axled89
i love oregon wheelin.
Russell_G
Thanks guys, The new shop has been taking a ton of time so i havent got as much time to work on it as id like. If you guys ever need anything for parts/parts rigs or swap parts let me know.
NorthernColoradoAutoParts.com
720-404-7714 ask for russell
My build
Russell_G
Set the rear pinion angle, Shocks are on and started dying the dash over the weekend. Should see the road this weekend im thinking.
My build
Great job Russell!  I like checking out this thread every now and then to see the progress, and it doesn't disappoint.  I'd love to have the area, time and money to do the same with a 1st gen.
twistedtoy92
Russell_G
pics
Dropped the shafts off today to be tubed thicker and made to fit. CV's front and rear with 10inch slip front and new Ujoints.
My build
Russell_G
My build
Russell_G
Thanks!
Scotty from Addicted offroad came by and we sorted out the drive flange issue i had lastnight. I have the front one in but he took the rear shaft to match up a flange.
Fuel line is reflared and i measured it so i can have one made tomorrow.
Got the dash dyed and put in and test fit the seats....Im now looking for different seats cause the Ones i have are too tall and too bulky but man are they comfy. Im on the hunt for clean black leather GSR seats and i will just put my heaters in them. I think its a good answer and still have a nice leather seat.
Pics will be up later tonight i hope. Im going to get it going this week cause the maxima is starting to poop out. The tranny is flashing codes and stuck in 3rd lastnight so i left the battery off all day and i hope it was just a glitch.
My build
Russell_G
Ok heres a quick update of pics..... I have been slammed between the truck and work and now im back on the lifting soi will have a little less time...
heres pics
the caps were from the gf for xmas
My build
axled89
