How much do you have into it so far?
Axle upgrades sound sick!
Those wheels look sweet Russell!
Wow, the excitement renews! ballin Bro
love the wheels, i'm running a similar set. is there a particular reason you went with steel, over the alloy ring?
Never ask that question Russell doesn't want to know.
The leak you are hearing is most likely the EGR Pipe. It runs down the back of the engine to the right side exhaust manifold. They crack on the accordian part. I believe a '96 has a 2 peice EGR pipe and it is the lower one that leaks - still, pretty easy to replace.
awesome pictures man! that bobbed bed looks very clean too, paint is perfect!
Russell, as for the knock sensors I believe it is possible to remove them if you pull off the throttle body and use the right socket with a extension and a universal joint. I don't remember if you can replace that harness though with the intake still on. If you can't do it without removing the upper intake plenum, make sure you drain a bunch of coolant first before you pull the intake or you will end up with it in the heads. BTW, there's 2 knock sensors - one in each head.
Started by CruzrDave Parts For Sale
Started by toymech Project Research and Build-Ups
Started by 88wildrunner Parts Wanted
Started by punkrock crawler Parts For Sale
Started by H8PVMNT General 4WD Discussion
