Author Topic: birfield question  (Read 2545 times)
yoda316
  • Member since Aug '06
birfield question
« on: Mar 19, 2009, 08:01:23 PM »
ok so im in the middle of doing a front axle rebuild for the first time.
and i think when i separated the birf from the axle i lost a piece. i think its a spring clip that goes onto the axle and holds the birf on.
my question is do yo need it and if so . know where to get one?
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
Joey88RUNR
  • Turtle Points: -23
  • Male Posts: 1,057
  • Member since Feb '08
Re: birfield question
« Reply #2 on: Mar 19, 2009, 08:22:48 PM »
its not really neccasary to remove the birf from the inner unless you are replacing it, but yea there is a clip that goes inside there.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #3 on: Mar 20, 2009, 06:54:39 AM »
its not really necessary to remove the birf from the inner unless you are replacing it, but yea there is a clip that goes inside there.
When rebuilding a front end with stock Birfields it is a good idea to take the Birfields completely apart so you can check the cage for cracks and the inside for wear and surface cracks. Here is a link for the FSM on the front end and it shows how to take them apart if you do not know how to.
http://www.lukemiller.org/toys/1985_toyota_4wd_front_axle_FSM.pdf
sweetmeat
  • Turtle Points: -13
  • Member since Dec '08
  • Friends don't let friends join the sierra club
    • Wrecked4x4
« Reply #4 on: Mar 20, 2009, 06:37:16 PM »
I never put them back in. You don't really need them
A&G Motorsports Class 1 #1553 Crew Member
Wrecked4x4.com
desertoy
  • Turtle Points: 3
  • Member since Dec '03
« Reply #5 on: Mar 20, 2009, 07:03:37 PM »
You don't need them UNLESS you have a locker in the front that doesn't have a cross shaft such as a Detroit Locker. If the center section doesn't have a cross shaft and you don't have the retainer ring on the outside of the axle shaft, the axle will slide into the locker and become disconnected from the birfield.
yoda316 [OP]
« Reply #6 on: Mar 21, 2009, 02:17:15 AM »
cool . yeah as i was taking out the other side i was carefull to check and see if it had one one it. nope nothin
im using a lock rite up front . so i guess i should be good . thanks guys , one more thing
im not using the stock birfs , the guy i bought it from said that they were longs. they dont say longfield anywhere on them .( they have no markings on them at all actually)
any ideas on what they are? heres a few pics
OOPS
  • Male Posts: 2,561
« Reply #7 on: Mar 21, 2009, 08:24:47 AM »
Wrong, the axles can go into the third enough the the "sweet spot" for the seal is to far in and it will leak. Making "Birfield Soup". That is where the "Martack" on the axle came from. Back in the day before super Birfields (Longs, etc.) we would leave them off for ease of changeing Birfields on the trail. I once asked Bobby Long if I should run them in his products and he said a yes.
sweetmeat
    • Wrecked4x4
« Reply #8 on: Mar 22, 2009, 12:28:14 PM »
I run a detroit locker with longs and have never had those clips in mine.  Nobody i know uses them and we have never had an issue
Wrecked4x4.com
OOPS
  • Male Posts: 2,561
« Reply #9 on: Mar 22, 2009, 06:51:23 PM »
Do what you want to do, I will take the word of Toyota and Bobby Long. I have to much money invested in my front end to mess it up because of not running a 50 cent clip.
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
« Reply #10 on: Mar 22, 2009, 09:59:30 PM »
Those look like Bobby Long's.  Same shape and look as his 27 spline.
http://www.longfieldsuperaxles.com/27spline.html
Last post May 21, 2006, 07:34:39 AM
by DanS
Last post Oct 10, 2008, 12:40:44 PM
by porkchop
Last post Jun 05, 2009, 11:38:22 PM
by DeadlyPeace
Last post Oct 02, 2009, 03:15:12 PM
by crawlerdad
Last post Dec 29, 2009, 02:47:04 PM
by 85_4RNR
