tons 2rz three link front. Now slamming on its nuts spring under rear!newpics
Started by 89sastoyo, March 15, 2009, 11:46:16 PM
0 Members and 9 Guests are viewing this topic.
83 Crawler
ya dude that car isnt bad you just need to fix the wipers so you dont have to flip them up lol and make sure the hood dont fly up again! that was scary :shocking:
89sastoyo
Quote from: Talon84x4 on April 28, 2010, 08:57:02 AM
are those metal shavings all over the ring gear from the grinding? that won't be too healthy for your bearings and gears if you don't get all that out  :twocents:
yeah I got it all out I put it on jack stands and spun it around and around sprayin it off with break clean.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
83 Crawler
truck is coming out sick. i havent seen it for a long time!!!
89sastoyo
thanks bra you should see it in person looks pretty sweet...
I fixed the car up some too. I fixed the front wheel that was rattling it was the cap for the wheel bearing nut rollin around in the center cap of the wheel. I also put a can on it and mounted my stereo legit..
92 2wd DD
first gen cab
89sastoyo
its on a metal stand thing i made for it. it looks super ghetto but there was really no other way to mount it.
92 2wd DD
first gen cab
83 Crawler
89sastoyo
either way it works really good other than I have noticed when I transition from a right turning drift to a left I knee the deck and hit the face plate release button. I welded the diff on the car to:d and put exaust on it.
But for the toyota. I got all the bolts I need to finish putting the rear axle together finally got my break pads so its pretty much on me to throw everything together and it will be driving minus a driveline. Im going to run triples and see how I like them. If I don't like them than ill go to duals with 4.7s I want to run the triples so I can have a shorter rear driveline. I really want to run a 1 piece and with the triples I can and still have a good driveline angle.
92 2wd DD
first gen cab
swapped89
Sounds pretty sweet man. How long will your driveline need to be with triples?
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
89sastoyo
if i remember right it should be right around 50"
92 2wd DD
first gen cab
GrenadedToy
hurry up and finish this turd so we can go wheelin on joels B day. you got 6 days honkey.
swapped89
Quote from: 89sastoyo on May 04, 2010, 01:45:31 PM
Damn man, with triples? Thats still longer than mine with duals! haha. that will be nice for sure!
mattlosch
im running a one piece and wasnt mine about that long? without a cv also...
6-days till joels birthday i dunno if we will be done lol
1983 caged, 22re, slammed
2006 cummins 6spd... somewhere around 750whp for a tow rig
89sastoyo
He's not going right on his birthday weekend. We can get done though aren't you gonna be in vegas next weekend?
92 2wd DD
first gen cab
mattlosch
swapped89
mattlosch
swapped89
nice have fun, try the oxygen bar at treasure island. And you can get picked up at yer hotel in a giant limo for free if you go to the worlds largest strip club. the Saphire, go there its awesome  :drunk: :boobs: the bellhop guy at yer hotel can call them for you.  ;)
89sastoyo
haha sounds like you know all about vegas.
But yeah I got all my misc stuff for my truck the other day finally done with my probation stuff and I;m going to work tomorrow so i should get it done asap
92 2wd DD
first gen cab
swapped89
Na. I went once, and that's about all.I remember lol
89sastoyo
so I planned on finishing it up thiss weekend but had to work last night just off a little bit ago. I have to re fab my x member make new mounts put the cases in do my rear disc again put my break lines on blead the breaks gear oil make drivelines build a floor and bolt on my pinion guard. From what I can remember right now thats it. I am also waiting on arp studs from ballistic for my steering. They should be here today or monday so im hoping by tomorrow ill have everything done except rear driveline and the studs. I will get pictures up of it when I get it moving. I will have the front driveline done today or tomorrow so I can roll around. The rear I am trying to find a d line of a truck with a 14 bolt so I have the ujoint and all that stuff to start with. also have some bling ill post up not to bling but blling(:
92 2wd DD
first gen cab
DoveGray85
It sounds like you still have some work to do! At least you're getting closer. The weather is still crappy, so it's a good time to work on the truck :)
I'm in the middle of a "head gasket" job. I needed a new head cuz old one had cracks. I'm also doing timing set, rod bearings, and rings while I'm at it.
89sastoyo
very nice I went threw my second gen dang it ran so much better when I was done thats pretty lame but there cheap to rebuild and deff are a lot better to drive after.
Yeah I am gettin there lol I had a bunch of time off work but didnt have money now I have money and no time haha. I'm hoping within the next few weekends it will be done.
92 2wd DD
first gen cab
89sastoyo
tonight me and max busted out a couple things. I routed all my breaklines did the rear disc swap and bled the breaks they acttually have quite a bit of pedal for having a toyota mc still. I still need a proportioning valve but we'll see how they work.
here are some pictures aswell:D ejoyyy
92 2wd DD
first gen cab
TheCookieMonster
nice. you running tripples or quads in that sleeper ??
89sastoyo
hahah triples I still have a dummy shifter because my tranny is forward shift and is a single plate I never run a tunnel untill now so i didnt want it just cut and lookin ugly lol but i might cut it when I re do the tunnel and get everything legit. I wanna focus on cleaning up the interior a lot Its pretty hacked right now lol. I have like all bling :pokinit: in there but its just chillin no floor soon to be no seat belts lol I have to mount harness's and make the tunnel and clean the carpet and she'll be good lol.
92 2wd DD
first gen cab
89sastoyo
june 4th im entering a competition in bend OR. We'll see how it goes. From now to then I have to finish the tranny tunnel, build an interior cage. Make drivelines replace steering studs mount a winch and pack lol. Its going to be really hard since I only have a few days to do it all. I don't really know if I will end up going because of the winch thing. I personally hate them and don't want one on my truck.
92 2wd DD
first gen cab
gnarrkill
Quote from: 89sastoyo on May 27, 2010, 07:39:20 PM
im coming bro!
79 toyota duals,caged,40 mtrs
the build thread i dont update
http://board.marlincrawler.com/index.php?topic=65367.0
swapped89
Goodluck man! are u going to groundhog?
GrenadedToy
Just don't hammer it like cody was last year or your rear out put might turn to dust haha
