tons 2rz three link front. Now slamming on its nuts spring under rear!newpics
Started by 89sastoyo, March 15, 2009, 11:46:16 PM
mattlosch
1983 caged, 22re, slammed
2006 cummins 6spd... somewhere around 750whp for a tow rig
89sastoyo
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
mattlosch
89sastoyo
dude you shoulda came to bend man it was sick. Granted it wasn't as good as last year it was still fun.. and were going in like 3 weeks haha well I take that back some time after the 4th and a cage....
92 2wd DD
first gen cab
mattlosch
im in i wanna go soooooooooo bad... boating was dope though 16 people half girls~  you should come out tuesday with us
89sastoyo
im down what time? Gotta work at ten. And if you have tried texting me or anything I kinda threw my phone out the window when I was driving the other day..
92 2wd DD
first gen cab
mattlosch
hahaha wtf lol yeah i have been tryin wonderin why.. um were probably go out around like noon or so
89sastoyo
for sure i should have a phone tomorrow haha if not ill try and get your number from someone and hit you up. Stack FTW by the way.
92 2wd DD
first gen cab
mattlosch
did you get oine??? ya hit me up
971-645-8729
swapped89
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
GrenadedToy
its super sick 8" sectional stove pipe.
89sastoyo
ryan why'd yuo have to kill it...
yeah i was half drunk and looking for some 4 inch I thought I had and then saw that set it in my bed decided it would look gangster said flopp it and cut the hole haha. I just took the tip from mine cut it before the 90 un bolted the clamp bolted the 90 to it so its like 3" 90 up a couple inches above my bed then the stack is tacked into the bed and yeah haha but it sounds legit and doesnt look as ghetto as ryan made it sound.
I got a 97 dodge 12 valve lariat 5spd single cab teal super ugly.. has a white half ton door and badges on the driver side it was flopped no cab damage dude tried kicking out the windshield so I need one. interior is super clean new tires good breaks built 5 speed with bigger 5th gear and welded nut. straight piped to a stack k&n cold air with box and evertything ats afc housing adjustable smoke switch a believe in the cab? I honestly still not sure what it is adjusting he said it was the fuel plate but you cant really adjust that so i think its the smoke switch either way it makes a rediculous amount of difference in power. #100 fuel plate. newer clutch yada.... I will have pics of it when I get a phone hooked up haha.
92 2wd DD
first gen cab
mattlosch
that stack does sound ghetto but i bet it looks good... hit me up when you wake up
crawln503
FOR A 97 12v 5spd YOU COULDNT BEAT THAT PRICE!!!
i thought you were going to buy my stack :gap:
-85 ext cab swap on std Toyota frame, 3rz, built narrowed 6 lug 60's duals/4.7 42's iroks
-94 Ford CCLB 12v. 6spd, pump cranked, guages, lifted & lots of other mods:smokin:
-89 ext cab Toyota, 3.4, 5spd on 33's
swapped89
89sastoyo
for the dodge or stack? I got the dodge for 2900... and joel wants 125 or 100 for his stack I can't remember haha.
Im getting a 7" cat stack fo free:D I think. I am not sure yet actually because matt might be a little mad at me not to sure though
92 2wd DD
first gen cab
swapped89
damn 2900 for a tow rig. Sweet deal man goodluck with the new ride
mattlosch
Its hella legit for a tow rig! Dude hit me up tomorrow I. Wanna come hang out. And I still wana buy joels stack when I get money
89sastoyo
yo dog not thingy blockin joel but fozo said he'd sell for 200 with the flex pipe bed clamp everything. I might buy it just for the kit and everything once I give max some money.
92 2wd DD
first gen cab
mattlosch
I know but I don't really like fozo stack. And joels is only 75 so I can buy flex and adapters for same price. Idk I might do just five inch out the back too
GrenadedToy
Quote from: 89sastoyo on June 09, 2010, 05:37:08 AM
haha when you take off out of mulino and half of it falls off into the bed, its ghetto.
lets see some install pics adamdude :gap:
the clock is ticking, better have this burnt turd done for hammatyme.
and is max still going or does he need a trailer still?
Jud
"bout tree fiddy"
swapped89
Any of you guys goin wheelin anytime soon?
89sastoyo
ryan smd brah.
jud its done. Well not quite I have to make new seat mounts because the cage dealy it was mounted to wont work with the new tranny tunnel. I want to bleed the breaks again there pretty soft. adjust the idle weld the exaust back on check bolts adjust the idle. swap power steering pumps and ifs boxes.
Here are some pics from today :D
I really wanted to flex it out on its own will to see if anything binded expecially my steering I'm super close to the drag link hitting the tie rod since I moved the axle forwards more but it doesnt hit. I also was checking for rubbing the front should be fine since I fixed it with a 12 pound sledge a little while back haha. The back I might need to re do my bumps I cut one side off to move it forwards the oter side apears to work still so I might just weld the other one back on we'll see.
92 2wd DD
first gen cab
89sastoyo
oh yeah and tripples make it slow:DDD
92 2wd DD
first gen cab
89sastoyo
oh yeah and max is going ill tow his ass if he doesn't have a trailer ill just take two trips I guess but he might have his gauges in and tow it with his dadge I dunno yet
92 2wd DD
first gen cab
cederrowe
swapped89
you guys goin up friday or saturday? campin?
89sastoyo
im going friday threw the 5th im not sure what day friday is I think the second? but im leaving at like 5:30 am or 6 untill mid afternoon the 5th
92 2wd DD
first gen cab
