Your Opinion
Started by jrock, March 03, 2009, 11:25:07 PM
jrock
I have around $800, a steering problem and a tire problem. Shimmy in the steering, two bald tires.
Do I get hi-steer or two new tires and fix the stock steering?  ???
00taco
i think it is your tires im running some bald tire right now and it shimmies, could be your alignment too.
jrock
I have not bald 30s on now and the shimmy is not so bad but it is slightly noticeable. I put on my bald 33s and the thing shimmies on bumpy ground. It likes to change its mind on the direction.
emsvitil
How's your steering stabilizer/shock?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Snowtoy
Where is the shimmy, bump steer, or death wobble?
If it is in the steering wheel it is the tires, usually a balance/out of round issue.  The other 2 are steering issues
You cheapest route would be to  have either the 30's or 33's balanced and see if that doesn't solve your problem.
jrock
Quote from: emsvitil on March 04, 2009, 12:20:41 AM
It's good, as far as I can tell.
Quote from: Snowtoy on March 04, 2009, 12:31:17 AM
Not bump steer, not DW. There is no motion transferred to the steering wheel and it doesn't pull when braking. It pulls to one side and then it'll pull to the other, when running straight. Both the 30s and 33s are balanced.
Fix the steering, no bandaids.
if you are running 30's  and going to 33's  you dont need high steer,  you do need new tires
maybe new tie rod ends ($10 per side +/- )
blackdiamond
Are your steering arms tight?  I drove my 4Runner the 1st time not realizing that the steering arms were not torqued and it horrible.  Just an idea...
jrock
Rebuilt the front about 2 months ago, first thing I checked was the trunion preloads, they were loose and have been tightened. The wheel bearings have been re-re-torqued. The toe-in is 1/8in. The steering box has been tightened/adjusted as tight as it will go and is now back to around specs. Newer poly bushings in the front. Everything has been tightened.
The only other thing I think could be causing this is the negative arch in the springs.
steveco.
you could probably get both if you shop around..
Let's put a smile on that face!
93tonkatoy
I don't know if you've checked it, but wear in the steering box can cause "play" in the steering. Have someone slowly turn the steering one way then the other, while you watch the steering box. Any movement of the input shaft without immediate movement in the pitman arm will indicate this type of wear. If that looks right, continue through the steering components to find any play (drag link ball joints, tie rod ends).
SAVE TELLICO post 491
jrock
Quote from: 93tonkatoy on March 04, 2009, 03:35:38 PM
That sound about right.
peacesells
I wouldnt put a dime into the stock steering if you ever wheel it :twocents:
Sounds kinda like you had a tire seperate internally.
this my man lysol, fresh out the joint
jrock
#15
Quote from: peacesells63 on March 04, 2009, 04:41:30 PM
I wouldn't put a dime into the stock steering if you ever wheel it :twocents:
Sounds kinda like you had a tire separate internally.
Interesting. But since I get the same issues with both tires I think it is an issue with the geometry of the suspension.
jrock
Here is what my front springs look like. Besides the box, this is what I think is wrong. But before I tear into this can-o-worms, what do you think?
Sleeve of Wizzard
*** YELLER ***
Quote from: jkief86 on March 06, 2009, 10:53:33 AM
:yikes:
except BACON
79toy20r
correct me if im wrong, but you cant put highsteer on it unless you lift it around 4" or so.
good luck finding the problem. these guys have you heading in the right direction
Redbeard1
Ummm.. The first thing I would do is find some new springs (hellofa negitive arch you have there) and sense you are on a tight budget I would sugest you go with RUF you can get rears at the wrecking yard pretty cheep.Tighten up your drag link balls too if there is any play in them.
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
__________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
jrock
Good information, thank you all. I'm putting together some parts and some help so I can start of this. I'm going to hit up some scrap yards for a "better" push-pull box and leafs to use in a stock hybrid pack.
jrock
Okay, so, PnP in Stockton and in Fremont where no goes with boxes. Hybrid packs are in but kinda fungly  :laugh: . A friend gave me the tops from a better pack and I will be rebuilding with them. The steering box is giving me issues and I have procured a hi-steer for cheap... I might be going down that road instead.
Question: Do hi-steer now, are any issues likely? Or find a push-pull box for now and put the hi-steer on this summer with a spring hanger and all the goodies?  :dunno:
RABIDYOTA
might as well go hi-steer now why replace boxes twice  do it once and be done
jrock
Well I just got bumped from the hi-steer for a better offer. Sucks  :thumbdown: . Now I'm looking for a push-pull power-steering box if someone has one.  :help:
jrock
Okay, finally fixed. :) I replaced the box with one from an 1980 and after way too long, it was in, bled and working.
