im going with a big fat nope.
If you are going to go with a camry v6 block, I think the one you want is the cast iron one from '92-'93 and not anything newer cause they are all aluminum blocks. That aluminum block might bolt up, but I would want the cast iron block for strength. I have heard that Ivan used to run the v6 multi-valve heads from the '92-93 v6 camrys on the 3.0 truck block in his racing trucks back in the day, so at least the headgaskets are similar.
no way
Seeing how the Camry is a front wheel drive set-up, I would think that would preclude the two blocks from being interchangeable, though I could be wrong.While the blocks are similar the heads are diff. The Camry V6 is a twin cam, and truck is single cam. There has been attempt to bolt up the Camry heads to the 3.0 block, but I haven't come across a completed one yet.The HG issue is pretty much a thing of the past, providing you use new TTY head bolts, studs, or non-TTY head bolts.
there is no reason to buy a harness from ors.... there is only 4 or so wires to hook up under the passenger kick panel and the wiring is done.... the motor bolts rite in and you just use the 3.0 oil pan/pickup etc. very very easy swap and a 3.4 will smoke any 3.0 I dont care how built it is..... you can get a low mile 3.4 for under $800......
Started by lilbuddy General 4WD Discussion
Started by jeepwrecker Engine
Started by LARRY PANAMA Toyota Pickup/4Runner Tech 1979-95
Started by spacoli Toyota Pickup/4Runner Tech 1979-95
Started by chris_snchez Engine
