yep just a couple of the peices.... really easy and it doesnt take away much of the hood stability either.... much easier and cooler than the body lift!
there is no reason to buy a harness from ors.... there is only 4 or so wires to hook up under the passenger kick panel and the wiring is done.... the motor bolts rite in and you just use the 3.0 oil pan/pickup etc. very very easy swap and a 3.4 will smoke any 3.0 I dont care how built it is..... you can get a low mile 3.4 for under $800......
snotoy think what you want man! you must have got those price quotes from the toyota dealer or some man! you an roll to any local wrecking yard and pick up the 2 plugs you need for $10 max and if you have a truck with the 3.0 then you have the other half already and all the relays/fuses you need & the ECU is $100 from any wrecking yard.... the motors have always been cheap! and your full of BS if you think everyone who has done these swaps used the ORS harness... I know a few different people locally who do these swaps everyday and would never touch a ORS harness for whatever outrageous amount of money they charge for 10 1' pieces of 20 AWG wire... these motors make way more power and run 500% better than any 3. ever built by anyone! hell our local toyota dealers will sell a customer on a cheap 3.4 swap before they rebuild a 3.slow..... just my I dont care what anyone sais the 3.0 is JUNK when you put it up to ANY 3.4 otherwise why would have toyota ever built the 3.4
Started by lilbuddy General 4WD Discussion
Started by jeepwrecker Engine
Started by LARRY PANAMA Toyota Pickup/4Runner Tech 1979-95
Started by spacoli Toyota Pickup/4Runner Tech 1979-95
Started by chris_snchez Engine
