1st gen "Super-Cab" Mod...COMPLETE...kinda...
Started by 82juguete, February 08, 2009, 06:52:10 PM
BUDDERS
That does look sweet!
You better connect the bed to the cab though or the tortional twist from the frame is gonna wrinkle up your pretty sheetmetal.  I've seen that happen on a few lowriders with a walk through into the camper shell.  I think the best thing to do is to weld up some C channel vertically on both sides once you've cut out the back of the cab and the new portion is tacked in place.  Then you can go to town doing the rest of the welding and sheet metal fab.  Have you figured out how to connect the back wall of the cab to the bottom portion of the bed yet?
axled89
i love oregon wheelin.
82juguete
Thanks guys,
Yes, its definitely going to become a unibody of sorts, with the cab merged to the bed.  For the lower seam, im leaving the cut along the bottom of the cab a little high, so i have enough material to fold over and beat into shape along the ridges of the bed floor...  I was going to do similar for the sides, but may just use c channel or flat like you said, to fill that gap and make it solid, kinda like they do for demolition derby stuff...
Quote from: boggerunner on November 29, 2009, 04:42:07 PM
foung this on pirate
N-I-C-E. I've been thinking about converting my cab into an XtraCab for a loooong time now. Threads like this give me inspiration
boggerunner
Quote from: BigMike on December 19, 2009, 10:48:01 PM
yeah, the bed is hideous, but the cab is a work of art
I say go for it MIKE!
82juguete
Had to post this in here... believe it or not i found it on a local CL ad here in fresno:
Custom 1984 Toyota Pickup Extra Double Cab 4X4 - $3500
Custom made extra double cab truck with tons of upgrades and extras including a 1988 fuel injected 22r, lift kit with 35" tires, custom front bumper and more. Has a new clutch and brand new front brakes and rotors.
Interesting concept but looks like a super clean job... I think i like it!
82juguete
So today i trimmed up the extra cab portion, and got it fitting to the back of the cab nice and tight.  Basically i need to:
-remove front wall of bed
-cut out back of main cab
-fold down flap, weld to bed floor
-weld in strips to tie bedsides to cab
-weld rooflines together, brace if necessary
-weld extra cab sides to bedsides and bottom to floor
-move slider window from cut portion to xcab
-seal inside with silicon
-clean welds, bondo, sand, primer
-lay carpet inside (if im feelin ritzy  :eyebrow: )
I have to go back to school in 12 days, minus about 3 for holiday stuff so 9 days give or take..
Do i go for it?
91crawler
ninja turtle
hilux-1983
Talon84x4
Quote from: 82juguete on December 23, 2009, 12:54:16 AM
I'm planning on doing that to my 2nd gen, only 4 door...
And I say go for it
Low & Slow 84 PU - http://board.marlincrawler.com/index.php?topic=31982.0
Central Valley Crawlers
82juguete
cool, so i got 1 thing checked off the list today
got the bedwall out... im realizing more and more that leaving a lip on bottom cut on the cab and "folding" it over to meet the bedfloor is going to be next to impossible, with that big hump in the middle.
So tomorrow i think im going to make a cardboard template that will be used to make a sheetmetal filler for this joint.  My plan is to cut strips from a donor bed to fill the gaps inbetween the cab and bed, and do some heavier reinforcing on the inside.  Man i wish johnny from wildyoats still had his build pics up for reference, oh well ill wing it.  But the next 2 days im going to be busy so very little will likely get done.
GONZO97
next week we'll get started on everything that way we can get it done before you head back to school we'll finish it no worries
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
Damn dude.... your committed now... GET ON IT SON!
82juguete
Got a little more done today... Made a cardboard template for the floor piece im going to have to make... im thinnking 18ga sheet, that way i can make this piece and a strip to join the roofs together as well:
Also made one piece of "angle" actually cut from some rectangular tubing, so the long side would overlap the bedside mount plenty.  This option should give me plenty of welding surface and make for a pretty strong joint...I wanna say its 3/16'', maybe 1/8'' thick.
hopefully i can get the sheetmetal soon so i can get this stuff done. I can weld the angle to the bedsides now, but not to the cab, as i may need to cinch in the sides while fitting things.
82juguete
Man, I need like a half-sheet of 18ga sheetmetal (roughly 4'x5') Valley iron has full sheets(4x10) for $50somthing... but thats WAY more than i need.  Anyone know a good place in the Fresno area that would have half sheets, remnants, etc at a good price?
82juguete
nobody huh? well hopefully i can ttrack some down  tomorrow.  spent most of today shooting with some buddies, but did a little work with the hour or so of daylight left when i got home. got most the surfaces ill be welding ground down and loosened up the headliner inside where ill be doing the cut.  anyone have any tips for removing the back window without damaging the seal?
82juguete
Nevermind on the window, the FSM has a pretty detailed writeup i just found.  Still welcoming any pointers though...  :yesnod:
82juguete
Got more done today... got the floor pieces cut and tacked in, also welded the angle iron side pieces onto the bed, oh and removed the back window.... heres the pics:
Im having my doubts about finishing now.... feelin soooo close yet soo far away at this point.  I had a funeral today, my gf's mom is having surgery tomorrow, so that basically leaves me friday and saturday to finish everything, so im not sure if i should even make the big cut now anymore....  ????????
GotMyYotaBack
Trekker Build- http://board.marlincrawler.com/index.php?topic=64943.0
Aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it deosn't mttaer in waht oredr the ltteers in a wrod are, the olny iprmoetnt tihng is taht the frist and lsat ltteer be at the rghit pclae. The rset can be a total mses and you can sitll raed it wouthit porbelm. Tihs is bcuseae the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe.
So dont tell me I spelled it wrong! You knew what I ment.
hilux-1983
Yeah Buddy,  :therethere: you can do it!!!!!! Can you do us all a favor and make the pics bigger, kinda hard to see, thanks
GONZO97
Dude you have to try to finish it....idk if youll have time in the morning but i am free in the morning maybe if you work on it ill come and lend you a hand
The Build:
Coming Soon
82juguete
Man we did work today, for only a couple hours of work.... I thinnk im going to go ahead and go for it now lol:
82juguete
starting out by mapping out the cuts and drilling holes in the corners where the vert and horizontal top cuts would meet.
I chose to cut right outside of the body seam, which is about as far out as you would want to go anyway.
82juguete
got at it at about 7:15 this morning...just 6" cutting wheel, nice and slow:
82juguete
My cousin helped me cut the bottom line about an inch and a half above the floor patch piece.... this left a flange that he then cut at every angle change:
Also note, once at this point, i could hammer out from the inside, areas which had slightly too-large of gaps.  Then i could fully weld everything.
82juguete
put some black jack all along the seam to seal out the weather, and began pounding the tabs down to create a rolled edge:
