1st gen "Super-Cab" Mod...COMPLETE...kinda...
Started by 82juguete, February 08, 2009, 06:52:10 PM
hilux-1983
More pics toyota smasher that looks great. I wish we could just import the already done 4 door models from out of the country
toyota_smasher
It not my truck  :(    But here is a link to the website with all the pictures of it so far.
http://www.sky-manufacturing.com/new/viewgallery.php?id=5
Runner- sas,locked front/rear,5.29s,dual cases,30 spline Longfeilds,36in swampers on beadlocks,Much more
hilux-1983
I just got a nervous feeling in my stomache when I saw your pic of that piece of cab in the back of your truck. Now that I have parted out this 82 that I came into, I have a bare cab that is prime for adding to my cab just as you are bout to do. Make sure and load PLENTY of step by step pics. I just may follow suit. Did you ever get a hold of a complete working dash guage assy? Sorry mine didn't work for ya.
82juguete
No...but mine functions besides the odometer, and it aesthetically pleasing.  I just wanted a factory tach, but can do without.
All i am going to do for now is trim, fit and mock up the donor cab portion.  No cutting to my actual truck cab until i have time to do it all, start to finish...
fj-rankenstein
the never ending build...
http://board.marlincrawler.com/index.php?topic=12165.0;highlight=extend-a-toy
Quote from: BigMike on April 10, 2010, 11:30:18 AM
Was searching for something and came across this old jew. BUMP to a classic thread :thumbs:
82juguete
Well i did some trimming today...  started off by making a cardboard template of the inside contours of the bed:
You can see i tried to make it very tight fitting:
82juguete
then after taking some reference measurements i traced the template onto the donor cab and cut the backs of both sides...
82juguete
Then going from cut to cut, i used the "string and spraypaint" technique, just like on my bed-bob, to get a straight line to cut across the bottom of the back of the cab... this is the edge that is going to be welded to the bedfloor...
82juguete
after some long, and some tricky cutting i ended up with this...
82juguete
oh and i guess i should show the actual portion i will be using...
82juguete
Now i tried to jam it into position just to get a visual, but its just not going to happen.  I am happy with how everything is fitting and shaping up, but the geometry of the bed shape and cuts just wont allow it to drop in without removing the front of the bed and spreading the sides some....
I soooo want to just keep movin on this but i need my truck for moving this weekend, and can't dismantle it at this time.
As hard as it is, i have to walk away now until i have a long weekend or something when i can knock the rest out...
hilux-1983
Nice job so far! I've never see that approach that your using before(countouring the sides to fit the bed)  :bowdown:
82juguete
Nope, sorry guys....  I'm living in SLO, all my tools are back home and i want SO BAD to finish this but im not about to cut the back of my cab off in the middle of winter, without being sure i can finish it.  I fear this will have to be resumed next summer..
hilux-1983
Quote from: 82juguete on November 24, 2009, 04:40:03 PM
What or where is SLO?  You have to finish that thing, I've got my donor cab just waiting to get cut up and fitted.
LilChief87
hell eyah bro looking good cant wait to see how its done
82juguete
SLO= San Luis Obispo, CA.  That is where i attend Cal Poly, and unfortunately my apartment there is less than ideal for an operation like this (no garage, no driveway, no tools)
I will find a way to finish this some day!
82juguete
Anyone ever remove the front bed wall on a first gen.  I took out the 3 bolts up each side and the sides break free fine but the bottom seam wont budge.. is there anything more than that silicone stuff holding it on the bottom edge?  Im gonna have to investigate closer tomorrow
papa mike
Quote from: 82juguete on August 21, 2009, 04:44:00 PM
Now i tried to jam it into position just to get a visual, but its just not going to happen.  I am happy with how everything is fitting and shaping up, but the geometry of the bed shape and cuts just wont allow it to drop in without removing the front of the bed and spreading the sooo want to just keep movin on this but i need my truck for moving this weekend, and can't dismantle it at this time.
did you put it in at a angle then turn it straight??
papa mike
Quote from: 82juguete on November 25, 2009, 07:10:11 PM
if you need a hand  let me know
82juguete
Thanks Mike... and yea i definitely tried to shimmy it it sideways first, but i just dont have the room with my current shock mount/cage setup in my bed right now.  All that stuff will be coming out eventually but im not going to screw around with it much more over Thanksgiving...maybe more on Christmas break, we'll see.
82juguete
Well i went ahead and pulled out all my bedcage, spare carrier etc. out of my bed today.  Thats probably gonna be it for now though, might try a test fit on the xtracab tomorrow....
Heres a quick photoshop of more or less what im going for, though it might change along the way:
boggerunner
82juguete
yea i saw that in the first gen pic archive.... great job on the ex-cab but i cant stand the stepside!  :ack:  Definitely unique though...
kiefer1980yota
Quote from: boggerunner on November 29, 2009, 04:42:07 PM
foung this on pirate
Ive got a 1st genn that i just got and started rebuilding and want to make it an ex-cab like this but i want a normal bed. Not a fan of the step sides.
1980 toyota 4x4 swapped in 22r and 5speed
Triumphant
Over
Years
Of
Terrible
Abuse
82juguete
Check it out.... this ISNT a photochop!
Its just mocked up, obviously nothing is welded but i finally got it into place and im really happy with how things are lining up and fitting.  Also am diggin the look of it.... its making me want to finish it so bad!
46&2
LilChief87
looks flippinsweet man awesomecant wait to seeit done
Ah man thats a pretty sweet idea dude.... lookin good!
