Project BoostedRunner, SOLD
Started by pumkin toy, January 12, 2009, 09:37:34 PM
0 Members and 12 Guests are viewing this topic.
NITE KRAWLERS
NIce diff armor bra! Pumpkin orange even, SWEETNESS man!!!  I need the FIX ME mod to bra, how much and wer i get one at... HA HA
Sometimes life is a rock an we need a Yota to get over it an Chevy is like a rock so I'm over it!!!
pumkin toy
Quote from: 83crawler12 on January 12, 2010, 10:07:37 PM
i got the pitman arm in the mail today  :thumbs: thanks alot man its just what i need  :ladys-man:
good deal man! glad I could help ya out :biggthumpup:
Quote from: NITE KRAWLERS on January 12, 2010, 11:19:57 PM
yeah dude i can come over and give you your own custom "FIX ME" mod.  20 bucks each :rofl2:
well dudes i worked on my drivelines a bit today. I got yhe front one all welded up and i think it came out pretty straight. I took the rear one to the local driveline shop so they could get it perfectly straight and balance it for me.  Also snapped a couple pics of the begining stages of my new coolant piping.
97 4runner Limited
Jakesteads
I like Toyota
twistedtoy92
YellowJacket
Much better!  :thumbs:
Must have missed why you had to mod the driveline...
twistedtoy92
pumkin toy
Quote from: YellowJacket on January 14, 2010, 12:28:59 PM
twistedtoy92 is right,  Dual T-cases are in now so i had to lengthen the front and shorten the rear.
Quote from: Yota wut? on January 14, 2010, 10:14:12 AM
bling
yeah the stainless is kinda blingin,  I am gonna get the pieces all fit together and installed this weekend.
So the rear driveline got done today, came out real nice! hopefully it runs pretty smooth down the road.   Tonight i got both my diffs refilled, installed drivelines, and I started doing some brainstorming on how to build or modify the skidplate/crossmember.  Now that i have duals, the skidplate i just built will not work.  I might end up starting all over again on that.  Plans for this weekend are to wrap up the new stainless coolant lines and get it all installed. I also need to finish clearancing the console for the shifter and get some kind of boot installed.  And i would really like to cut and rotate the spring perches on the rear axle.  My pinion needs to rotate up about 12 degrees so i have the correct angle for that rear CV driveshaft.  And I need to start trimming the rear fenders!  Man the list goes on.......
97 4runner Limited
NITE KRAWLERS
ya bra the list never ends man! ha ha sons a little
YellowJacket
Quote from: pumkin toy on January 14, 2010, 08:25:31 PM
twistedtoy92 is right,  Dual T-cases are in now so i had to lengthen the front and shorten the rear.yeah the stainless is kinda blingin,  I am gonna get the pieces all fit together and installed this weekend.
:smack: Wow, I am already forgetting things.
minicrawlin
the list goes on but it gets shorter each time! keep it up man springs gonna be here before you know it!
the rocks Rock in South D SON!
pumkin toy
alright i rebuilt my skid/crossmemeber today.  I decided to weld tabs to the inside of the framerails and bolt to those instead of trying to use the bolt holes for the stock member.  Its all welded up, just gotta throw some paint on it!  I also cut a bunch of old brackets and crap off the frame and welded up about ten little round holes in the frame so it looks nice and clean.  I had to relocate the tab that holds the e-brake cable, I ended up welding it on top of one of the new cross member bolt tabs.  The first pic shows how i did that.
97 4runner Limited
NITE KRAWLERS
Nice bro! Ya planning on putting like any rubber absorbers wer ya bolt it up at?? LIke a motor mount that twisted use's dude?? Maybe ya got it in der an i can't see!!
NITE KRAWLERS
Quote from: minicrawlin on January 14, 2010, 10:43:29 PM
Ha HA dude your a smart one. lol But then ya forget some stuff and add it to the list and your back to the never end n one bra!
pumkin toy
Quote from: NITE KRAWLERS on January 17, 2010, 08:49:25 PM
i got the stock t-case mount up on there dog!
So today i got the crossmember all painted and installed.  Also got my stainless coolant tubing installed.  I had to move the radiator down about an inch so the lower outlet would shoot below the oil pan. After i did that the lower stainless tube fit in real nice.  I also got the rear heater hoses modified and all fit up out of the way from the rear driveline.  I will get pics of all of it tomorrow after work.  so basically its all back together and ready to rock with the 23 spline dual ultimates and .25" wall CV drivelines.  Now its back to the drawing board with the stupid engine, hopefully i can figure it out sometime before summer!  I just wanna drive it again :rivers:
97 4runner Limited
yota_krawler
i really like your cross memeber!!! may have to steal it lol, no but i really like it :beerchug:
NITE KRAWLERS
Quote from: pumkin toy on January 17, 2010, 09:52:35 PM
Well least ya got some time to figure it out then. lol man. Wish i was that far dude. Long as i am wheel able before DTC i'm good, thats my plan! That coolant hose is gonna be super gnarly trick man. I just wanna go for a turbo ride again bust n through 3' of snow bra!! HA HA. Well i finally got my build thread started dude. So if ya get board i have stuff to do, lol. lata
pumkin toy
Quote from: yota_krawler on January 17, 2010, 10:05:09 PM
thanks bro!  i need to get some more pics of it tonight now that its all painted and lookin sexy
Quote from: NITE KRAWLERS on January 17, 2010, 11:04:00 PM
I know dude, snow bustin would be alot of fun in th runner!  I will find your build thread.   and yeah dude you gotta make it to the cruiser classic this year!
97 4runner Limited
NITE KRAWLERS
oh I'll be der for all the days man. I'm gona take work off to man! wheel n all day long! if my runner ain't done I'll bash the truck dude. but runner will be done, has to be!
pumkin toy
well here are the said pics. I just need to get a rubber boot installed for my t-case shifter then the interior will be done.  Also took a couple shots of the front fender trimming i did.  And a couple shots of the stainless coolant pipe.  its kinda hard to see where it goes, but its there and it doesnt leak any more!
97 4runner Limited
pumkin toy
97 4runner Limited
pumkin toy
Quote from: NITE KRAWLERS on January 19, 2010, 12:39:47 PM
sweet dude!  its gonna be July 14th thru 17th    Stoked to have you there for the event!  We gotta get Tim to go.  also you need to become a member of our club so you can do the event for free.
97 4runner Limited
yota_krawler
did you lift the cases up at all? I am 25" frame highth, with 127" wheel base on 37s! I am going to have to do something.
pumkin toy
Quote from: yota_krawler on January 19, 2010, 07:36:45 PM
damn dude thats alot of wheelbase!  I lifted the drivetrain about 2.5".  right now with the 40's completely aired up i'm at 24.75" to bottom of skid, 26.75" to bottom of frame with a 107 wheelbase.  I wanted to tuck the drivetrain up even more, but i didnt want to get into extensive floorboard modifications. my orange truck was basically the same height to the bottom of the skid and i never once got high centered on it so i think i'm good
97 4runner Limited
Jakesteads
I like Toyota
axled89
i love oregon wheelin.
NITE KRAWLERS
Ya i need to join da club! "Meet me in da club its going down"   :afro: But ya you need to hook me up wit da info and stuff. What happened to the club meetings, have ya been going and not tell n me again? Sneaky sneaky you.  :outtahere: I've wanted to join for a long time man. I'll be der one way or another and in one of my yota's! Hey maybe work truck. lol  Ya tim should go to!! Well any way  your front fender trim looks tight dude. What bout da rear? ??? Ya i cant tell wat the  :pokinit: that coolant pipe is doing but way cool bra! Good work my friend, keep it up. Lata
minicrawlin
Quote from: pumkin toy on January 19, 2010, 07:30:52 PM
whats this now!!? dude i'm all over gettin in the club and doing this run! always down for wheeling no matter what time the day man you guys know dat!!!     :shocking:    NIGHT WHEELING
Nice dude looking good! crossmember turned out good and probably only cost you 2 cents to make at work huh ha ha you son of a!!!
NITE KRAWLERS
Quote from: minicrawlin on January 19, 2010, 08:34:10 PM
Its the cruiser classic dude!! Camp n and wheeln man!! Were gona do the 1st annual night wheeln runs this year! Bust out da uner lights. Sound good Caleb, lets talk it over??? Iceman and Rice Crisby??  :psss:
80YOTA4X4
Looks good man. You wanna come over and assemble my 23 spline dual cases? Lol.
minicrawlin
Quote from: NITE KRAWLERS on January 19, 2010, 09:16:03 PM
:shocking:   :shocking:    :shocking:    :shocking:    :shocking:    :shocking:    :shocking:    :shocking:
:rockingout:    :rockingout:    :rockingout:    :rockingout:   :rockingout:   :rockingout:   :rockingout:
. . . . thats all i gotta say bout that!!!
