Author Topic: Quick Question 22RE rev limits  (Read 5110 times)
JohnHalladay
  • Turtle Points: -6
  • Male Posts: 221
  • Member since Dec '07
« on: Nov 01, 2008, 09:10:08 PM »
Does and 80's toyotas come stock with a rev limiter?
« Last Edit: Nov 02, 2008, 07:03:10 PM by 79coyotefrg »
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
Re: Quick Question
« Reply #1 on: Nov 01, 2008, 09:14:32 PM »
fuel injected or carbed?
JohnHalladay [OP]
  • Turtle Points: -6
  • Male Posts: 221
Re: Quick Question
« Reply #2 on: Nov 01, 2008, 09:15:14 PM »
EFI
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
Re: Quick Question
« Reply #3 on: Nov 01, 2008, 09:28:12 PM »
im not sure, ive seen a buddy down shift instead of up shif on the interstate and it hit 9 grand
JohnHalladay [OP]
  • Turtle Points: -6
  • Male Posts: 221
Re: Quick Question
« Reply #4 on: Nov 01, 2008, 09:31:37 PM »
hahaha  i bet that was sight to see and hear!  :rofl2: well does anyone else know???  :dunno:
Pat
  • Turtle Points: 786
  • Male Posts: 944
  • Member since Jun '02
  • Oroville, Ca
Re: Quick Question
« Reply #5 on: Nov 02, 2008, 12:02:20 AM »
yes efi Does, i think 5500 rpm..  But down shifting cannot be controlled by a rev limiter..  the revving is being done by the momentum of your rig and the gear you slam it in too..  but pushing the clutch in should do the trick
Sharing time between Northern Ca and Western Tn..
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: Quick Question
« Reply #6 on: Nov 02, 2008, 12:17:20 AM »
i dont even see how 9k is possible, thats outside the range of the stock tach... and even then, what did he slam it into first while doing 80 mph? just sounds liek a gross exaggeration
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
Re: Quick Question
« Reply #7 on: Nov 02, 2008, 09:52:12 AM »
he has 35" mtr's and was runnin down the interstate in 3rd at 4500 and went for 4th, and grabbed a handful of second. and 5500?  that cant be true, ive had my 4runner up to 6500 all day long, so deffinantly not a 5500 rev limiter
JohnHalladay [OP]
  • Turtle Points: -6
  • Male Posts: 221
Re: Quick Question
« Reply #8 on: Nov 02, 2008, 05:24:46 PM »
this might be a question for marlin! haha
joey0712
  • Male Posts: 1,459
  • Member since Apr '08
Re: Quick Question
« Reply #9 on: Nov 02, 2008, 05:40:37 PM »
Hold her pinned and see what happens. Its gonna go dadadadada or BOOM!!!!
91 Toyota High pinions f&r.
JohnHalladay [OP]
  • Turtle Points: -6
  • Male Posts: 221
Re: Quick Question
« Reply #10 on: Nov 02, 2008, 05:48:11 PM »
ill let you test that on your truck! i got a brand new motor in mine! lol
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Quick Question
« Reply #11 on: Nov 02, 2008, 06:02:24 PM »
a 22RE wont breathe (restriction in the intake and head) enough to rev past 6500 or maybe 7000, without cam changes and some porting
the 22R/RE is a long stroke engine and  really doesnt like anything over 6500,(bottom end)  meaning you really have to work  to get that rpm
unless your running a 20R head on a 22R with a big cam like i used to, i miss that motor :burnout:
it died when i dropped the #4 exhaust valve at 7200 rpm,  :down:
my tach goes yellow at 5000 and red at 6000
JohnHalladay [OP]
  • Turtle Points: -6
  • Male Posts: 221
Re: Quick Question
« Reply #12 on: Nov 02, 2008, 06:19:39 PM »
i do have a stage two cam in mine with punched .040 over
Re: Quick Question
« Reply #13 on: Nov 02, 2008, 06:59:40 PM »
stage 2 from who??  it REALLY matters,  what lift and duration??
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: Quick Question
« Reply #14 on: Nov 02, 2008, 07:02:04 PM »
No rev limiter in a Toyota, just the limits of the engine to suck that much through the intake. Then of course the valves floating and creating a limiter-like feeling.
JohnHalladay [OP]
  • Turtle Points: -6
  • Male Posts: 221
Re: Quick Question 22RE rev limits
« Reply #15 on: Nov 02, 2008, 07:21:07 PM »
its an Engnbldr 261 cam
« Reply #16 on: Nov 02, 2008, 07:43:19 PM »
um what part of stage 2 is that??
lift??  duration??
JohnHalladay [OP]
  • Turtle Points: -6
  • Male Posts: 221
« Reply #17 on: Nov 02, 2008, 07:48:49 PM »
Stock is 198°, .398" lift, 110° center
the 261 cam that i have is 218° & .425" lift, 110° center.
The 261C has more duration @ .050" lobe lift, 222°. It has less lift,
.410", and faster ramp speed, so it recovers quickly off idle and has more
RPM portential..Perhaps 3-4 H/P less at peak but longer powerband.
« Reply #18 on: Nov 02, 2008, 07:50:30 PM »
for example,  my LC Engineering Stage 2 race cam is .460 lift 290* duration and is designed for 1500-5500 rpm
Quote
20R/22R - Stage 2 Camshaft
4WD / Pre-Runner / Hot Street 2WD (1500-5500 rpm)
Modified Carb or Throttle Body & 1 1/2" Header
   Intake    Exhaust
Valve Lash    .008    .012
Valve Lift    460    460
Advertised Duration    290°    290°
Duration @ .050"    240°    240°
Lobe Center    102°    118°
Intake Opens    18° BTDC
Intake Closes    42° ABDC
Exhaust Opens    56° BBDC
Exhaust Closes    4° ATDC
JohnHalladay [OP]
  • Turtle Points: -6
  • Male Posts: 221
« Reply #19 on: Nov 02, 2008, 07:52:43 PM »
as i said above mine has .425" lift and 218* duration
« Reply #20 on: Nov 02, 2008, 07:53:31 PM »
i wouldnt be concerned with over reving, unless you plan to sit at redlights with your foot on the floor for some reason
JohnHalladay [OP]
  • Turtle Points: -6
  • Male Posts: 221
« Reply #21 on: Nov 02, 2008, 07:55:29 PM »
yea i dont really plan on doing that. i like my motor to much!
« Reply #22 on: Nov 02, 2008, 07:55:40 PM »
i didnt see you post till after i posted
JohnHalladay [OP]
  • Turtle Points: -6
  • Male Posts: 221
« Reply #23 on: Nov 02, 2008, 08:01:29 PM »
hahaha ok no worries lol i was going to say, can you read! hahaha just kiddin.
« Reply #24 on: Nov 02, 2008, 08:01:32 PM »
the 261 eb cam is close in specs to LCengineering's  base model cam,
Quote
20R/22R - Mild Street Performer Camshaft
2WD or 4WD Carb/EFI (1000-4000 rpm)
Smooth Idle, Stock Replacement
   Intake    Exhaust
Valve Lift    424    424
Advertised Duration    270°    270°
Duration @ .050"    220°    220°
Lobe Center    102°    110°
« Reply #25 on: Nov 02, 2008, 08:04:20 PM »
yep, just slow when im trying to keep up with 3 different threads and find info for 3 different people :willynilly:
i think its bedtime for me :thud:
« Reply #26 on: Nov 02, 2008, 08:06:28 PM »
btw  listen to my engine,  the big cam isnt for everybody, actually they say  this cam isnt compatible with efi without mods to the efi
http://www.mhdfl.com/forum/Glens-truck.mp3
JohnHalladay [OP]
  • Turtle Points: -6
  • Male Posts: 221
« Reply #27 on: Nov 02, 2008, 08:12:17 PM »
that sounds like my motor. just not as bad of a valve tic. lol what muffler do you have?
  • Momentum Man
  • Lego Enforcement
« Reply #28 on: Nov 02, 2008, 08:24:04 PM »
You've got to be kidding, I over rev offroad in low gears.
JohnHalladay [OP]
  • Turtle Points: -6
  • Male Posts: 221
« Reply #29 on: Nov 02, 2008, 08:33:39 PM »
see thats what i have done! but i dont have a tac so i dont know what im reving at!
Last post Apr 26, 2005, 05:28:21 PM
by germ
Last post Jul 02, 2005, 07:50:28 PM
by 79coyotefrg
Last post Mar 28, 2006, 04:16:19 PM
by bmxanddie
Last post May 15, 2006, 06:06:33 PM
by Stump
Last post Sep 13, 2007, 08:49:29 AM
by Rocksurfer
