i do have a stage two cam in mine with punched .040 over
its an Engnbldr 261 cam
20R/22R - Stage 2 Camshaft4WD / Pre-Runner / Hot Street 2WD (1500-5500 rpm)Modified Carb or Throttle Body & 1 1/2" Header Intake Exhaust Valve Lash .008 .012 Valve Lift 460 460 Advertised Duration 290° 290° Duration @ .050" 240° 240° Lobe Center 102° 118° Intake Opens 18° BTDC Intake Closes 42° ABDC Exhaust Opens 56° BBDC Exhaust Closes 4° ATDC
Stock is 198°, .398" lift, 110° centerthe 261 cam that i have is 218° & .425" lift, 110° center. The 261C has more duration @ .050" lobe lift, 222°. It has less lift, .410", and faster ramp speed, so it recovers quickly off idle and has more RPM portential..Perhaps 3-4 H/P less at peak but longer powerband.
as i said above mine has .425" lift and 218* duration
20R/22R - Mild Street Performer Camshaft2WD or 4WD Carb/EFI (1000-4000 rpm)Smooth Idle, Stock Replacement Intake Exhaust Valve Lash .008 .012 Valve Lift 424 424 Advertised Duration 270° 270° Duration @ .050" 220° 220° Lobe Center 102° 110°
hahaha ok no worries lol i was going to say, can you read! hahaha just kiddin.
i wouldnt be concerned with over reving, unless you plan to sit at redlights with your foot on the floor for some reason
Started by MiniSimp General 4WD Discussion
Started by paradisekid General 4WD Discussion
Started by bmxanddie Toyota Pickup/4Runner Tech 1979-95
Started by Tice Toyota Pickup/4Runner Tech 1979-95
Started by wflaw45 Toyota Pickup/4Runner Tech 1979-95
