THE BLUE MARLIN aka 1980 project build up by Maxwe001
Started by Dr.Maxwe001, August 03, 2008, 08:32:55 PM
what color should I paint my front bumper and rock sliders ?
Black as normal
Blue like my arms and truck
unclejpl4x4
Dr.Maxwe001
I got my E brake adaptor  from ALLPRO and now I am wating on the special of the week that was lastweek from marlin its the flanges i ordered up 4 of them  one at EACH end and this will soon be hasa as well i am thinking it should get here monday or tuesday  then I got to thinking while I was helping a buddy today I am going to have to change out the front and rear of my cv joints on my drive shafts cause I have the early first gen flanges that will not work for the e-brake  and i dont think its going to work either with the flanges from marlin  but we will cross that bridge when we get there  :turtle: :turtle: :turtle:
[img]http://bo
Bert Vega
Support Your Local Brawlers: www.rockbrawlers.com
Dr.Maxwe001
:woohoo: I got some :bling: parts today from the FEDEX guy
lets take a look
here you can see the tripple drilled flange (with dust shield)
and here is the dust shield that goes onto the flange down at the diff.
I have 4 flanges and 2 diff shields so they I should be able to get away with most any type of driveshaft
 But wait there is more :yikes: in the box was a SPECIAL GIFT SENT FROM SANTA'S LITTLE HELPER HIMSELF
[img]http://bo
Redeyejedi
alcohol.....the cause of, and solution to, all life's problems
http://www.flickr.com/photos/78234902@N06/
Dr.Maxwe001
[img]http://bo
Dr.Maxwe001
[img]http://bo
Dr.Maxwe001
wana talk about clearance issues well here are some CLOSE calls this is a shot of the e-locker motor and leaf spring on the front high pinion e-locker
and here is another shot looking down on it
you can real see in these pictures just home close it is  I had to use a flat headed allen head bolt.
[img]http://bo
Dr.Maxwe001
stress releaver
after all this time and work its time I think I take a short time to look out my back yard and injoy the view.
Please enjoy these as well I know I do
[img]http://bo
unclejpl4x4
Dr.Maxwe001
Update: the truck is ready for its voyage I just need to put the new diff cover on the rear and also need to weld the anchor plates onto the trailer :flamer: I bought me a top shift t-case for 50.00 local parts yard and put my 4.70 gears in it I also bought a clean uncut 83 harness from a friend on here I will be doing these two swaps in the winter unless something else come along in that time or before that forces me to take other matters. the 4.70 case is a twin stick and it is :bling:
[img]http://bo
Dr.Maxwe001
the rear harness and fuel sending unit and pump sock showed up today  this will complete the 80-83 harness conversion :woohoo: now if I can just get the truck out of the garage and wheel it and see what she will do I can then maybe tinker with the old harness removal  I will more than likely be either pulling the whole dash unlike last time when I just fished it in and out and over and under the parts of the dash I will be reading up on how hard it is to pull the whole dash from a 1980 truck couldnt be THAT hard OR COULD IT :think:    :turtle: :turtle: :turtle:
[img]http://bo
motormouth559
gtoyonrocks
Post up some new pics. I'm glad to see you were able to clean up those welds.
toyman2210
yeah, mine was simple. some screws up by the windshield and some bolts on the kick panel. then all the little stuff has to come off, but really not to much work. Hope my harness fits in there well. If you need any more parts for it that i might have forgoten, or just want, let me know, i'll send them off right away. good luck
"It Happened!!"
Dr.Maxwe001
[img]http://bo
toyman2210
anytime big guy, just let me know how well it works for ya
"It Happened!!"
Dr.Maxwe001
:update: I got the reverse light switch for the 1983 harness plug and play type it has the round type plug end on it
part number on box
reverse light switch that goes in the trany
round plug tip with two tips inside
I must give credit to bigmike for this since it was one of his pictures that gave me the tranny and part to look for on the rebuild trany page   :turtle: :turtle: :turtle:
[img]http://bo
Dr.Maxwe001
[img]http://bo
Dr.Maxwe001
Update I bought the weekly special lastweek it was the long lasting shifter sockets that are better then the stok oem rubber parts and i must say they are very nice and are easy to install I also bought this weeks special and have the no crush sleves for my front and rear diff. this will be better  :D
[img]http://bo
Dr.Maxwe001
UPDATE
I took the truck out for its first off road wheeling adventure and I killed the drivers side tire :rivers: as you can see from these 4 pictures the rock won this battle.
a single battle lost but not the war :horseride:
so in order to get me back off the trail and back onto the trailer to go home I had to put a spare stock size tire on that didnt have enough backspacing for the wheel to clear it :smack: SO I borrowed one from a buddy of mine on the trail and then I was on my way back up the hill and this was the end of the funday on sunday.
I then made some :phone: calls to AllPro offroad on monday and got me my own set of wheelspacers to keep as a EVENT OF AN EMERGENCY to get me home. as seen here
I also made a :phone: call to  National Tire and Wheel and bought two new tires since they were kinda expensive but I also wanted to take advantage of the low low shipping deal they had if the order was over $500.00 your shipping would only be $19.95 so this is why i got two insted of just 1 I can get the other two after i pay my mother back :shhh:  here are the two tires I got they are 36x 12.50 15R TSL
I mounted them on the beadlock rims I bought from a friend off pirate 4x4 this past winter. I mounted them in the drive way they sliped right on and then I centered the tire over the inner locking ring then began to put all of the little screws in and was able to torq them down and had a buddy of mine light the starting fluid that I sprayed on the rim. it burnt his hair off of his lower leg :yupyup: sorry Nick and this is was the point we put them on the truck. :woohoo:  then we noticed that the backspacing just dosent clear the ifs caliper from the 1993 toy. :smack: so I shut her down at that point and began to clean'er up and got to thinking and I asked a few people on here what to do  I have given some thought to buying a Mr. Gasket wheel spacer "VERY SMALL AND THIN TYPE" or just get the grinder out and clearance the caliper :thumbs: I think this will be easier and less expensive since I must pull the tire off anyways .
[img]http://bo
bleakhorizon
i have the ifs hubs and v6 calipers on the front.... depending on the wheel i use the mr gasket wheel spacers... never had a problem with them
Those are some huge welds!
Tillamook, OR
Dr.Maxwe001
I don't know if I should go with the Mr.G's or Mr Grinder ???
[img]http://bo
Dr.Maxwe001
ok tonight I had a few min to check out whats going on with that wheel it was hitting *( notice I said WAS hitting )* I took the grinder and rubed about maybe 4 /16ths  of a inch off the drivers side caliper and the wheel clears perfectly  :clap2:
[img]http://bo
Dr.Maxwe001
EVIL
:maddest:    :tantrum:      :snare:        :mad:     :(     :thumbdown:
[img]http://bo
-Jake-
