THE BLUE MARLIN aka 1980 project build up by Maxwe001
Started by Dr.Maxwe001, August 03, 2008, 08:32:55 PM
what color should I paint my front bumper and rock sliders ?
Black as normal
Blue like my arms and truck
Dr.Maxwe001
[img]http://bo
Dr.Maxwe001
UPDATE: I just swaped out the motor mounts for some new OEM ones I havent fired it up yet however I am sure the new ones WILL give me less vibrations and will also give the motor a little less of a jiggle. IF I SEE IT NEEDED I WILL PUT ON SOME CHAIN 3 LINKS TO THE MOTOR MOUNTS WELD THEM TO THE FRAME SO I KNOW IT WONT MOVE. I didnt get any picts of this being done so i am sorry for that however i will give updates on how the truck runs soon
[img]http://bo
Dr.Maxwe001
UPDATE:
I took the truck to a mechanic friend of mine and he adjusted the motor for me so that it would stop ticking but he also noticed it was skipping and the #4 cyl. was not fireing :smack: no wonder it didnt have good power lol he fixed that for me and its now time to go  :nonono: i was having a noise in the rear end and I didnt know what it was so I went to look and sure enough the bearings in the rear diff were killed. WHY DID THIS HAPPEN ??? some "jackleg"  :psss: names will remain unknown at this time. desided that back when he put the new pinion flanges on to use a impact wrench needless to say he didnt know what the preload was on the crush sleve and he overtightened them causeing premature failure :down: SO this brings us to here I am buying a new ring and pinion kit with 5.29:1 gears for the rear :yesnod: I KNOW I HAVE TO GET THEM FOR THE FRONT AS WELL BUT I CANT AFORDIT RIGHT NOW so i am just gona drop the front driveshaft and keep it unlocked until I can
I am also going to do rear disk brake conversion useing chevy brake parts. COMMING SOON :hyper:  :turtle: :turtle: :turtle:
[img]http://bo
ninja turtle
Dr.Maxwe001
[img]http://bo
Dr.Maxwe001
UPDATE
I installed my rear axle and while I was in the rear end I also bought the ALLPRO rear disk conversion that can be seen on this forum at this link here, http://board.marlincrawler.com/index.php?topic=74919.0
when I began to attempt to break my gears in I was told to jack the truck off the ground and to let it run for 30 min at 40 mph and let it cool for 1 hr and then repeat 2 more times for a total of 3 times. about 25 min into the first attempt the rear T case began to :puke: gear oil all over the place so i shut it down and had to find out why it did this  :headscratch: so I took the case down and was going to rebuild it but then I said heck why not just put that 4.70 gear case with twin sticks in and go for it ? so this is what i did I now have 5.29 in the rear diff. 4.70 in the rear case and 2.28 in the front crawlbox. I asked around on the MC shoutbox and got a true answer from Glen aka 79coyotefrg he is the one that told me to drive it for 5 miles and then drive it back home and let it sit over night
QuoteFROM 79coyotefrg   do it 2 more times,  then you can drive up to 10 miles out then let it rest an hour or so (20  or 30 minutes is fine too) then back home (maybe a trip to walmart or some grocery shopping),  after you get to 100 miles total (all your 5 mile and 10 to 20 mile trips combined) then change the diff oil.  I suggest Valvoline gear oil.  then at 500 miles change it again.  at that point your good to go and you can also tow a trailer if needed.
so this brings me to where I am now  seeing how as i haven't had enough time to break the gears in completely I have been waiting on the time to get the gears broke in  but with the wife always working it seems and the kids always needing me here i cant find the time to do anything  I have reached the halfway point on repaying my Boss back for the gears I have made 3 of the 6 payments  @ 100.00 every two weeks  AFTER the front is paid and installed NEXT I should be able to buy them other two tires that I was needing to match the rears .:crossed: until next time  keep the rubber side down  :wave:
[img]http://bo
Dr.Maxwe001
UPDATE
I bought the 5.29 gears for the front and will be here on Monday and then I will pay them off and  try to get the other two tires and then I am going to pull the front gears out and have them rebuilt and  while its torn down I SHOULD HAVE enough cash to get the other two tires and that way it will be all :bling: when the summer time rolls around   :turtle: :turtle: :turtle:
[img]http://bo
boomtacoma01
85 Ext Cab 22RE, 3 Linked front D60, 14B, Full Hydro and 40s
IG @boomtacoma01
Dr.Maxwe001
something to think about doing
on board air  via YORK compressor
on board welder via ZENA  http://www.zena.net/
I would need something like this bracket to run the OBW  http://www.zena.net/htdocs/welders/piggyinst.shtml#Top
[img]http://bo
Dr.Maxwe001
I just got off the phone with LONGFIELD SUPER AXLES and I have now purchased a nice :bling: set of chromoly  30 spline inner and outer axles AND also the outer axle locking hub FOR MY LIFETIME WARRANTY   :bling: MAKE IT SHINE MAKE IT SHINE :bling:
[img]http://bo
brockbuilt85
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
Dr.Maxwe001
Update: I ran across a little bit of cash and I bought a set of chromoly  longfields and outer hub gear  and also the wiper seal so this gives me the lifetime deal. I also had my 5.29 front diff gears installed  on my HP E-Locker  and have it set in time as well
here are the pictures of the longfields and also the wiper seals  Ill try to get a :snapshot: of the gears tonight for the thread
[img]http://bo
Dr.Maxwe001
UPDATE: I bought some new body bushing for the old truck and swapped them out and also bought me a tube bender and and 10 sticks of 1.75x.120 DOM tube and  will begin making my exo roll cage this weekend. the truck runs great and has plenty of power for a old 4 cyl.  I am also going to replace the current rock sliders for the new ones that are stronger with the little  :turtle3: logo in them for a safety step. then I might reinforce the rear bumper a little with some double notched tube (LIKE THE NEW DESIGN)  I will also AT SOME POINT pull the dash apart and try to fix my currently stuck odometer  the speed cable works just not the number part   :headscratch: I THINK ITS STUCK. also while I have the dash apart I am going to install the inclinometer since my dash has been all cracked and the PO just covered it with a dash carpet pad ( :dunno: why he jut didn't fix it along time ago ) I will more than likely have to put a thin piece of sheet metal under it and some self tapping screws to hold it together. but that is for another update. so until then :wave: see ya
PS I will take as many pictures as I possibly can with my GOOD HIGH DOLLAR camera that I bought at a garage sale for 25.00  :)
[img]http://bo
brockbuilt85
are you changing out your slider JUST to get that lil turtle deal? :yupyup:
Turd Box Build:
Dr.Maxwe001
 :shhh:
naaa actually i am changing them so that 1 they will be stronger than the current ones and also so that they are in the correct location :psss: I welded them on a little to far back so I am just going to cut them off and use them on another project one day :whistle:
but most importantly because of the really groovy turtle  :afro2:
[img]http://bo
brockbuilt85
Turd Box Build:
Dr.Maxwe001
 for the record a 1980 Toyota truck with a MC bumper front and rear, sliders  and a lift kit with a Warn 9000i with syn. rope with   36x 12.50 x15R TSL Super Swamper tires  and bead-lock rims  WITH NOTHING IN THE BED  AND ME OUT OF THE CAB AND TRUCK RUNNING weighs in at 3,540 lbs.   :turtle: :turtle: :turtle: :turtle:
[img]http://bo
Dr.Maxwe001
got these today from the USPS lady  :clap2:
I have a total of 4 of them
[img]http://bo
Dr.Maxwe001
And So it has begun!!!!
WE got the new sliders on that I bought from MC  and also bent the main hoop and 1 of the front a pillar bars  for the exo cage here are the picts I have so far i will try to get better ones int he daylight WITH A BETTER CAMERA than my cell phone.
[img]http://bo
Dr.Maxwe001
[img]http://bo
Dr.Maxwe001
Bump from TAPATalk
Sent from my BlackBerry 8350i using Tapatalk
[img]http://bo
nisota
:love: first gen builds cannot wait to get to oregon & start mine!!
Oregon wheelin'
82' 2wd-4wd project
http://board.marlincrawler.com/index.php?topic=89180.0
Rockcrawlintoy
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
IronClad
why is it like a freaking mile away from the cab?
Annihilation  Fabrication
Do you need a Hammer?
Dr.Maxwe001
I don't want my body to get hit  period  I DON'T WANT MY BODY TO GET HIT !!!!!
[img]http://bo
