fel pro head gaskets suck!only use multi layer steel gaskets.... OEM is the best, the stuff that engnbldr.com sells is also very goodFELPRO HEAD GASKETS ARE CRAP AND SUCK!
if you pull off the oil cap it will run rough and try to die, enough vacum to suck your palm to the valve cover. that was a WTF moment for me
my next guess was that the oil may not be draining properly from the top to the bottom and the oil pump is sucking air and pulling a vacum inside the crank case, but that doesnt explain why it would spit and sputter when i pulled the oil cap off. again wtf
Started by BLACKDOG 1989-1995: How-To Guides
Started by BLACKDOG « 1 2 » General 4WD Discussion
Started by snowrun Toyota Pickup/4Runner Tech 1979-95
Started by ccolby3 1984-1988: How-To Guides
Started by 80farmyota Toyota Pickup/4Runner Tech 1979-95
