Author Topic: Need Help! FEN vs FEL Alternator question  (Read 652 times)
80farmyota
  • Member since May '20
« on: Mar 15, 2023, 12:40:19 PM »
I recently got a 1981 4x4 sans motor and transmission. I would like to put my 20r out of my 80 4x4 into the 81 and reuse the 81 harness. Issue i am having is the alternator plugs are different. Green plug on 80 and black plug on the 81 harness. Is it possible to install an 80 alternator on a 81 harness? Everything i find is pointing to i need to install an 81 alternator and regulator for it to work. Or gm alternator conversion. Ive read sticky's till my eyes have crossed and cant find an answer.
a1gemmel
  • Turtle Points: 149
  • Member since Jun '21
  • Amateur shitbox whisperer
Re: Need Help! FEN vs FEL Alternator question
« Reply #1 on: Mar 15, 2023, 04:53:59 PM »
I wondered the same,  a while ago I replaced mine and had to special order in the one I had (can't remember if was FEN or LEF). Anyways, it came in and it was just the other one with a little adapter cable to change the plug. So yes, they are the same you can just swap the plug over. If you don't have the wiring diagram I can go take a pic later.
1981 Pickup - 37s, 5.29s, L52, dual cases 4.7 rear, e-locker front, grizzly rear, 22R stroker
1986 4Runner - 35s, 5.29s, auto, front Detroit, rear trutrac, 4" lift
80farmyota [OP]
« Reply #2 on: Mar 15, 2023, 06:22:39 PM »
Pics would be appreciated. I need to figure out how to rewire the 81 harness to work with an 80 alternator.
a1gemmel
« Reply #3 on: Mar 16, 2023, 10:52:20 AM »
Jeez, I forgot how hard it is to access the back of that alternator. Couple that with it being negative degrees out here and this is the best I can do, my apologies.
80farmyota [OP]
« Reply #4 on: Mar 17, 2023, 10:13:23 AM »
Thanks for the pics!!
Last post Jan 21, 2005, 11:12:52 PM
by guywithuglyyota
Last post Mar 15, 2005, 10:12:01 PM
by guywithuglyyota
Last post Jun 15, 2006, 04:47:42 PM
by lilbuddy
Last post Apr 08, 2008, 01:30:35 PM
by 91 super yoda
Last post May 30, 2012, 10:27:31 AM
by Nimyad
