Guide to Foreign (Non-USA) Model Toyotas
Started by 46&2, February 16, 2008, 10:15:05 PM
dk98
ill take that crusier from portugal and the 4runner lino cause its large enough to hold most of my family
884runner 4.3 needs to be refereed
46&2
Quote from: dk98 on February 23, 2010, 12:02:59 PM
Make that two of each please. :)
46&2
I wish I could go down to my local Toyota dealer and custom order one of these  :down:
Wermz84
I must commend you 46&2 for continuing to put cool  rigs in here. :thumbs:
I like to Drive!
46&2
Quote from: Wermz84 on April 26, 2010, 09:01:45 AM
Its the only kind of porn I can post on here without getting into trouble... :gap:
BUDDERS
Runar
Nice thread.  Wouldn't take some of the details in the first posts to seriously tho.
Hilux was produced on the "same" platform from the first models to 2005 when it was totally redesigned.  Until then it was just new bodies and evolution, evolution however meaning that hardly a single part was the same the first model and the lasts.  The best models where probably the live axle diesels from 1993 to 1997 (all gasoline trucks got IFS from 1989, and some diesel too).  I believe those models are also one of the most reliable car ever made (to simple to brake down actually :) )
4 latest generation Hiluxes have also driven to the South Pole, from a Russian base, that is located on the Antarctic coast almost as far away from the Pole as possible!  And yes, they have IFS up front :)  Experienced temperatures below -50 degrees Celsius (enough for pure anti-freeze to turn solid).
Land Cruiser what?
Hilux double cab diesel tdi 1995.  44" Fun Countries, custom coil suspension, streched wheelbase, air operated el-lockers front and rear with 5.29 yukons, MC07 crawler with 2.28 + 4.7 ratios, Hella Luminator Xenon, VHF, NMT, DVD, GPS, laptop and a Recaro child seat for the codriver
46&2
Quote from: Runar on April 27, 2010, 03:56:43 PM
Land Cruiser what?
When I first compiled this post it was after arduous hours of research on the internet (my only real source for this kind of information). I would most certainly agree that the information provided here is nothing more than general specifications across the board. It blows my mind how much an automobile manufacturer can modify, tweak and change their models throughout the years and across different countries and markets. Therefore I included what appeared to be the most common non-USA models and their specs, rather than going all-inclusive, which is just beyond my attention span. I know for a fact that the Toyotas available in Argentina vs say New Zealand differ drastically in everything from aesthetics to drivetrain. If you spot any specifications that are outright wrong or need additional details, please let me know. I want this to be as informative and factual as possible, so any input from Non-USA residents (or USA residents in the know!) is greatly welcomed. The Toyota market in the USA has been/is incredibly limited compared to what is available elsewhere. Any additional information that can be provided to expand/correct this post, please share!! :thumbs:
TOY087
07 TACOMA DAILY DRIVER
87 toy 22r/lc cam/350 holley/lc headers/magnaflow,5" LIFT ,35bogger
MY BUILD:  http://board.marlincrawler.com/index.php?topic=56212.0
Runar
#189
Ok, few corrections.  Although I'm no expert on this I'm pretty sure I'm right on this :)
In a post labeled: Reply #3 on: February 16, 2008, 11:46:47 PM (page one):
"Land Cruiser 80 Series (imported to USA)
1990-present - (Still produced in Venezuela)
6 Cylinder 1HZ (gas), 6 Cylinder 1HD-T (turbo charged gas), 3FE Engine (gas), 6 cylinder 1FZ-FE (gas), 6 cylinder 5VZ-FE (gas), 4 cylinder 3RZ-FS (gas),  4 cylinder 1KZ-TE (turbo-diesel), 4 cylinder 5L (diesel)."
First, 1HZ, and 1HD-t are diesel engines, 4.2 liter inline 6 motors (two totally diffrent motors actually, the later one a 24 valve unit, one of the best diesel ever made).
Secondly I'm pretty sure that the v6 cylinder 5VZ-FE (gas), 4 cylinder 3RZ-FS (gas),  4 cylinder 1KZ-TE (turbo-diesel), 4 cylinder 5L (diesel) where never available in the 80 series.  They where available in the 90 series.  Also the inline 6 motors from the 80 series where surely never available in the 90 series (engine bay simply to short !).
Then few more details :)
The 100/105 series.  The 100 series had a IFS up front while the 105 series (generally called the UN cruiser up here) was simply a 80 series with a 100 series body on top (rather than a 100 series with a live front axle).  It had the non-turbo hz engine or the 6 cyl gas engine.
The 70 series. Replaced the 40 series in 1986.  It was introduced in two version, light and heavy.  The heavy unit had the old 40 series big diffs and leafs and big engines, while the light unit had hilux engines, 8" diffs  (high pinnion front) and coil suspension.  Then in 1989 all the 70 series got the 8" high pinnion front diff. The light unit then was replaced with the 90 series and then the 120 series and finally this year with the 150 series.  The bonnet was diffrent, the light unit having a sorter but wider bonnet while the heavy unit a longer and a narrower one (to make space for the 6 cyl inline motors).  Also few 70 cruiser, heavy type, came with a very unique diesel engine a 5 cyl version of the Z engine, called PZ.
The Hilux had live axle available until 1997 on selected models, diesel double cabs and single cabs.  Don't thing the extra cab ever had a live axle on post 1989 models, nor any gasoline model.  The live axle was improved however on the later models, that is came with the v6 diff and had vented rotors and 4 piston calibers.  A locker was never available up front as on the cruisers, but the electric locker was available in the rear.  The rear axle of the double cab had a load carrying capacity of 1.600 kg and the leafs had 4 main leafs and 3 load carrying leafs!  It was never famous for ride quality :)
The 200 series has a twin turbo 4.5 liter V8 diesel available, puking out 260 hp and 650 NM (480 feetpounds or whatever you callit )
The modern 70 series also has that engine but in that series it has puny 202 hp and mere 430 NM (317 feetpunds or whatever you callit ), which is nothing but an insult to a modern common rail diesel engine design.  But then again, more power and the allready rollover prone 70 cruiser would probably fall on its side just thinking about what it could do :)
The 3.0 liter diesel in the 120 series kicks out 173 hp and 430 NM, and that is also on the low side on modern standards.
cavey
the  1979-1984 1st generalion hilux in Australia were fitted with the 18RC petrol engine ro the L (2.2 litre ) diesel with a 4 speed gearbox
the 1988 -1997 3rd generation hilux in Auatralia were fitted with 22R petrol engine and 3L diesel then 5L diesel  where as Europe only had the 2L-II
own a 1989  LN106r diesel with a 1KZ-T 3 litre turbo diesel  bolted to a imported R151F gearbox with snorkel Rancho springs & shocks & Detroit lockers F & R & 11x 32  cooper sst ultimate dual transfer cases 130 litre fuel tank   full floating disc brake rear end
gtoyonrocks
Wow, there are some sweet rigs in there. I would love to get my hands on one of them crew cab solid axle toyotas. I wonder what it would cost to get a cab imported into the states.
46&2
Thank you Runar and cavey for updated information, I will be correcting errors as I recieve new information. Thanks!! :beerchug:
Tofudude
8D3TOY
I came very close to trying to get a roller sans engine/trans shipped through my wife's work as they import from south America often and her contacts down there agreed to help me.  As it is it is darn near impossible to get it through without paying an importer a heavy price and if going undocumented like I was going to try was too risky as they xray the containers.  I am still working on it and have an American in Guatemala looking to ship his car home so I may be able to get him to buy it and ship it as his, he has done it fairly hassle free in the past.  As of now it is a long shot but I want one bad.
46&2
Quote from: 8D3TOY on August 10, 2010, 09:21:36 PM
Yeah, there was a thread about it on Pirate a while back. Basically it all comes down to being a major PITA to get one imported. That said, its probably a lot easier to get a Canadian spec than anything else.
46&2
This was taken from an Aussie member's expedition rig post on PBB. I want one sooooo bad...  :rivers: :sad2:
Quote from: Jaztaz;11855765Bit of Aussie flavour, hope you like it...
2007 Toyota Landcruiser VDJ79GXL.
4.5Lt DI Turbo Diesel V8.
5 Speed H151F,
Air-con, pwr steer, pwr windows, usual GXL stuff.
EXTRAS:
Hella Rallye 4000 HIDs, spread & spot with covers,
Warn 8000lb Hi Mount with braced drum & drain/fill plugs,
ARB bar with under radiator protection plate,
Triple battery set up with extra fuse panels & heavy wiring,
Overhead console,
GME TX4400 UHF (in console) with AE409L ground independant aeriel,
Genuine Toyota sheepskin seat covers,
Sandgrabber floor mats,
3" Taipan exhaust with ceramic coated dump pipe (still very quiet),
ARB Air Lockers front & rear,
16x8 Dynamic rims with 315/75/16 M/T MTZs x 6,
Hayman Reece high clearance tow bar with 6" dropped slip in tongue,
Superior Engineering 5" Suspension with-
Dropped radius arms,
Dobinson front coils,
EFS rear leaf springs with air bags,
Ext. greasable rear shackles,
Ext. brake lines,
Tough Dog shocks with in cab controller (in o/head console),
Custom Shelley Industries 2.5x1.9mt tray with-
5 welded-in flush mount tie down points,
2 spare tyre mounts,
2 under tray ali toolboxes (lockable),
Ali lining on inner tray sides,
Hella LED combo tail light assemblies & larger reverse lights,
No rattles or squeaks at all.
Custom made, stand alone canopy with-
False floor,
Full length & height doors on sides (replaces tray sides),
2 twin tube flouro lights,
2 fridge/accessory plugs,
Third battery with 6 fuse panel.
Pump up rear air bags, bolt on legs, let down air bags & pull out.
Canopy stands alone all locked up with battery to run fridges, etc.
Roof rack with roof-top tent, full awning (although not in pics)
86turboyota
My Build 1986 4runner SAS 36s etc
http://board.marlincrawler.com/index.php?topic=22625.0
"Later, I learned that even though I engage 4WD my hubs are not automatically locking? Something about manual locking hubs I think. What's manual mean? I need to read a manual to lock them? lol  So I found these neat autolocking hubs and installed them. Sometimes they dont stay locked while I am backing up, but that's fine because I dont have a backup camera to see where Im going (like our RV) so I just simply dont ever back up"- BigMike
Yotafoot
thought this was funny guys    :greengrin:
46&2
Quote from: Yotafoot on September 17, 2010, 06:15:44 PM
I love that picture. I was actually born in Saudi Arabia (moved back to the states when I was 1) and my parents said that is a VERY common sight. Hiluxes with camels in the bed are everywhere in Saudi. :haha:
46&2
46&2
I know its probably pointless. But since Facebook seems to actually draw attention to things these days, I figured I would start this page and see if some day we can't have a couple thousand "Likes". Maybe it will show Toyota there is a decent demand for these trucks in the USA. Futile... probably... but why not.  :biggthumpup:
http://www.facebook.com/pages/Toyota-Bring-the-70-Series-Landcruiser-and-Diesel-Engine-Options-to-USA/114538188610595
46&2
BUDDERS
Not a bad idea.  I gave you a like.  I would love a 79 series cruiser with a regular bed on it!  You might want to post this over on TTORA or YotaTech too.
46&2
Quote from: BUDDERS on November 01, 2010, 10:27:23 AM
Yeah, I figure its worth a try. I know if I could go to the Dealer and buy a brand new 78 Series Troopy with a 4.5 V8 diesel and 5 speed.... I'd do it in a heartbeat. With Mahindra trying to get into the light truck/diesel market, I'm hoping Toyota will see this as a chance to bring Toyota diesels back to the states.
I'll post this on TTORA and YT, good idea.
BUDDERS
I did some research on Mahindras a while ago, in fact, I think I made a topic on MC about it.  In my opinion, those Mahindras are ugly and I would never buy one - and I'm a little scared to see how poorly they are built.
I did some searches of 79 series cruisers after you posted this and found this pic:
BUDDERS
I know it's not a landcruiser, but I thought everyone on here would like to see it.  It's a custom hilux/surf combo that seats 7 pasengers comfortably and has a 13b diesel in it.
46&2
Quote from: BUDDERS on November 01, 2010, 12:51:44 PM
Haha that is awesome. Yeah I don't know what to expect from Mahindra, however I do know people that have used their tractors and speak very highly of them. We'll have to see. I know a lot of people are eager to get their hands on a light duty diesel truck so hopefully Toyota does something...
