Well done fordh8er...
that brought a tear to my eye
Just some FYI: TG uses cheaper (specificaly, Chinese) materials, hence the lower price. If you want quality, American-made parts, Marlin Crawler has you covered. The same can't be said for other companies such as TG. As for gears VS dual cases, it all depends on how much you drive your truck. I lifted my 85, ran 35s (with 4.0 case gears) and 5.29s for the last year. I couldnt have been happier. I already had a pretty low low range but I still got good gas mileage and I had good power on the street. I just went dual cases and it is fantastic. Looking back, I am glad I went with case gears and axle gears BEFORE dual cases, because the dual cases dont do anything for you on the street. If you have big rubber and dual cases you are still going to be hurting on the street. On-pavement performance was important to me because I DD my 4runner, so i went axle gears before dual cases. If its more trail rig than street rig and power and gas mileage arent a concern, duals is a great addition. Just remember the front driveshaft needs to be lengthened (a square shaft is a cheap fix) and the rear needs to be shortened (not so cheap if you want it done right).As for what gears are right for you.....Up to 35s - go with 4.88s35s and Up - go with 5.29s.I went 5.29s and they are great with my 35s. Going 37s soon and IMO, 5.29s are perfect for a 35 and larger tire. I wouldnt get 5.29s if 35 was the MAX tire size i wanted to run.
not to hate at all but just an opinion, ive know at least 10+ people right now that are running the trail-creepers R&P's right now and have broke birfs and shafts over there gears all the time. im not saying that there the best or the worst or that marlin is better or worst but its mostly on how you drive that reflects on if your gears are going to last but from what ive seen is that trail-gears's trail-creeper's have lasted.-Thomas
ya fordh8r i like wat u said i think i will go with the gearing for know than when i have to extra time and money ill get the dual tcases, thnx for the advice guys lotsa help to me learning what im doin XP
o and by the way fordh8r i like fords!!! lol!!! but i am all for yotas also
ok ill make sure to do that but if i do get these axles with the gearing already in them i wont have to worry bout it bc these axles already been out wheeling on a different yota
Forgot to mention, Not only is set up important but break-in is every bit as important as well. Be sure to follow the gear manufacturer's recommended break-in procedure and fluid change interval after break-in.
Alright heres the deal my yota right now with running 35's with stock yota axle gears, i was planning on buying 5:29 gear and pinion but my friend said i shouldnt go with 5:29 wat do u think so i go with 5:29 or a lil lower??o and i want to do crawling and off roading but i wanna drive to the trails instead of trailering the truck there and back
i think if u want a crawler that extra 25% of gear reduction from 5.29's is way worth it. 5.29's and dual cases with 4.7's in the rear is the way to go for anything. i wouldnt pick just gears or just duals like everyone is stating just wait till you have the money for both so u can get the most reduction possible.-Thomas
The point is to do the one that makes the most difference first and then progress mods from there. Why save money to do everything at once when you can enjoy the benefits of one or more of the options along the way.I did the 4.7 t-case, followed by ring & pinion when I did a taller lift and larger tires and then when the parts got transferred to the 4Runner I upgraded to the dual ultimate. Some people prefer a different build order.
my excuse is that im greedy
Yep!!!!! Any D-shaft shop should be able to shorten the rear and make the front longer. One other thing you should get a long slip joint for the front, if not when you flex it out on the PS it will come apart.
Started by 86 4runner Engine
Started by longzuk Suzuki Tech
Started by 4runnin_87 « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by lowandwide21 General 4WD Discussion
Started by Ric Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
