Author Topic: Question about doing a new front hanger on a 79-85  (Read 2973 times)
Blazer707
  • Turtle Points: -1
  • Male Posts: 80
  • Member since Nov '07
  • Rubicon Rookie
« on: Nov 30, 2007, 05:06:04 PM »
Just want to know or see in a picture how much of the 2 front body mounts people hacked away when replaceing/ forwarding there new front hanger after doing longer front springs. thanks in advance.
-Thomas
79 Hilux Bobbed *In Progress*
Blazer707 [OP]
  • Turtle Points: -1
  • Male Posts: 80
  • Rubicon Rookie
no buddy here has switched out there front springs with longer ones?
-Thomas
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
I have had a couple of friends do it and as far as I know they did not hack into their body mounts at all. Why do you think you have to?
Blazer707 [OP]
  • Turtle Points: -1
  • Male Posts: 80
  • Rubicon Rookie
ill get a picture.
fordh8r
  • Turtle Points: 850
  • Male Posts: 2,588
  • Member since Jan '07
  • when my toyota grows up it'll be just like my chevy!
  I think he means the part of the body mount bracket that hangs below the frame rail surface on a factory SA truck :psss:.  Is that, right?  I looked at doing that on mine as a possibilty down the road and figured I would cut that bracket to make it flush with the bottom suface of the frame rail in order to be able to install the front spring hanger.  I don't see a problem with doing this as long as it's welded in corrrectly and access to/removal of the body bolt is not affected.
Blazer707 [OP]
  • Turtle Points: -1
  • Male Posts: 80
  • Rubicon Rookie
exactly wut i was talking about, sry if i didnt make it that clear, ill just have to make it flush with the frame rail so i can have a solid metal to metal contact with the new hanger for the most weld room. btw i cant even post a pic of it cuz its saying its way to large.
-Thomas
fordh8r
  • Male Posts: 2,588
Cool, then I hope that works out for ya!  :biggthumpup:
On the pic thing, you'll have to resize them to atleast 100KB or less so they will post.  :beerchug:
Blazer707 [OP]
  • Turtle Points: -1
  • Male Posts: 80
  • Rubicon Rookie
thanks man, greatly appreciated!
-Thomas
EarlKann
  • Turtle Points: 160
  • Male Posts: 787
  • Member since Oct '05
I cut them flush and welded them to the hanger as a gusset.  We pushed the hanger forward to try to keep the tires out of the firewall.   It worked, but my shackle angle is bad as a result.  I wouldn't do it the same way again.  We went about 3/8" forward of flush with the factory crossmember and my shackles are pretty much vertical.  Of course every truck is a little different, so I'd clamp it in place and put the weight on the truck to see where you are before you weld it.
Blazer707 [OP]
  • Turtle Points: -1
  • Male Posts: 80
  • Rubicon Rookie
wut springs are u useing? cuz when u buy marlin/trailgear/all-pro ur suppose to move ur hanger 1.5 inchs forward. and thats wut im going for and ive seen people do that with a good shackle angle.
-Thomas
EarlKann
  • Male Posts: 787
They are AllPro springs.  I did not move the spring hanger forward that much from stock.  I wonder if that is a 79-83 thing?  Mine is an 85, I would have a better shackle angle if I had left the spring hanger in the same location as stock (just dropped 2" with the aftermarket hanger)
Blazer707 [OP]
  • Turtle Points: -1
  • Male Posts: 80
  • Rubicon Rookie
yea see now im confused i guess when i get my springs im just going to tack up/clamp up the new hanger and put some weight on it and see where my shackle angle is at and go from there.
-Thomas
Front Hanger
Last post Apr 02, 2005, 05:50:54 PM
by Uncle Jesse
Last post Aug 15, 2005, 12:42:20 AM
by RHG
Last post Mar 17, 2007, 07:00:49 PM
by rednk1980
Last post Mar 02, 2007, 09:50:44 PM
by Yota Tony
Last post Jan 21, 2017, 12:13:51 PM
by Beastcrawler85
