Front Hanger
Started by Toy1, March 31, 2005, 09:54:57 AM
Toy1
Anybody ever had this problem,or is´t a problem :conf:
Leaf mount bending. :confused:
The bolt has not been over torqued
Uncle Jesse
Is the spring pack missing the sleeve that goes through the bushings?  That is the first thing that comes to mind.
synwars
Reminds me of some homebrew shackles I've seen haha. ::)
If you're trying to fix it: bend it back out and weld a plate across the front for protection and support to prevent it from happening again, but then your spring may start slopping around in there.
I dunno. If it were me, I'd rather have a bent hanger than springs shifting side to side when I go around corners or on a side hill.  :dunno:
"Don't let common sense stop you..."
Build up thread:
http://board.marlincrawler.com/index.php?topic=11425.0
KEEP IT CLEAN PEOPLE!!! :bat:
bkg
I can't see any way to bend a hanger like that unless the bushing sleeve was missing...   ???
Jack8542
My springs shift from side to side when I go around corners :hammer: .  I could fix it, but im too lazy  :sleepy:  .  What you could do is bend the hanger back make brase it up and get some new bushings.  Some new after market  bushings have a lip on them that would probably fill up the gap or make it less apparent when going around corners.   :turtle:  :usa:
RIP SSg Sizemore, Sgt Mock, Spc McGuness, Pfc Hill, Pfc Marsh, Pfc   Garcia, Pfc Hardge, Ssg Campos. You will be missed greatly by all of C-Rock.
Mountain Yoat
 :hammerhead: Missing the bushing sleave. it gets compressed between the two tangs of the hanger and holds them parallel. :yesnod:
Toy1
It is a 96 Hilux that has a SAS.
Front hanger and bolts comes from AllPro
There were no sleave,just the bushing and bolts
Maybe that´s the problem, :idea:
Thanks anyway :usa:
KYOTA
Loosen the bolt and bend it back then retighten then box the front of the hanger in - do both sides
Island4Runner
Quote from: KYOTA on April 01, 2005, 09:00:31 AM
I dought there is enough clearence with the sring to box the front of the hanger like you are saying to do....
Life is one big road with lots of signs
So when you riding thru the ruts
Don't complicate your mind
Flee from hate, mischief and jealousy
Don't bury your thoughts
Put your vision to reality, Yeah!
Robert Nashta Marley ; Wake up & live
backseatwheeler
you bought it from all poo thats your problem bye from marlin he has better stronger parts and is a realy nice guy if you have a problem liek that with a marlin hanger he would repalce it
Uncle Jesse
.  . . if you wanted to hack it off the frame and replace it.  But I doubt he does.  If you can source up a sleeve you would be best off. You may have to use a smaller diameter bolt though.  The width between those spring mount ears is 2.5" right?  Or 2.25"?  Anyway, if there is no clearance to box that front section in, try a bit of box tube, and cut the fourth side off, then use that to box it in, as you could move it out away from the spring for clearance
