Front Hanger
Started by rednk1980, January 03, 2007, 01:29:46 PM
rednk1980
I want to build a front hanger for my 1st gen pick up to save some money on my build up. Does any one know the measurements and what type of metal im gonna need.
mickeyfinn
 i thought i would build one also, but after buying one, in would be hard to duplicate it for the money. save your quarters. they add up fast i bought the sas kit, but i think the hanger comes with bolts and bushings. don't hold me to that
Rockcrawlintoy
i built mine. there was one sas kit when i did my sas from all pro and it was $$$$$ the measurements are 29 inches center to center for the spring width and i used 3.5x3.5x.250 tube for my hanger it has about 10 bucks of scrap steel in it
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
rednk1980
nice, i did some measurements on my buddies who has the allpro hanger and i was gonna use 4x4 tube steel with .250 walls and a piece of 1x2 .120 for the crossmember
I have about $50 into mine.  i took two pieces of 2x3x.250 and welded them together making a 2x6.  baught some spring hangers for $20 and welded them on.
86bobbedtoy
i used 2x6 and welded up custom hangers half way in the tubing.
rednk1980
mine
i
mickeyfinn
looks good what do you use the weight bench for. i some times use the weights to sag the suspension for measurements
rednk1980
thanx that really is very appreciated.  :bowdown:
Quote from: michaelfinn on January 03, 2007, 08:43:52 PM
it was my mom's weight bench, i never really used it.
Max Heintz
nice i needed to know this also
rednk1980
I have mine finished if you want me to take some pics. I used 2x3 .120 wall tube steel with rear spring hangers i bought from marlin off set them 3/4 inch and welded them on capped the ends and braced the bracket. Yet to install it though.
