PRACTICALLY ANYTHING YOU WANT (missouri)
Started by DTB, November 29, 2007, 04:03:48 PM
girlzlikemud2
Quote from: Peterbuilt84 on May 30, 2010, 01:45:35 PM
Price on a power steering setup for 84 pickup. Shipped to 95076. Thanks
I PM'd you. Thanks!
**If you are requesting parts, please provide a specific year of vehicle, not a range.**
anothercrazycooter
how much for a grey drivers side door panel with electric windows for a 1988 4 runner and an SR5 4 cyl cluster for the same vehicle?
4x4yota
head light brackets (that mount lights to truck) and black bezels for a 79-81 (round headlights) to 81101
Current:
Sold:
yota18
looking for a 2008 tacoma short bed rear leaf spring
girlzlikemud2
Quote from: anothercrazycooter on June 10, 2010, 07:59:06 AM
PM you. Thanks!
girlzlikemud2
krelnydelnky
i need an 81 longbed frame and bed do you have that?
thanks!
COFFIN CRAWLERZZ CRU
Matt60
hey i'm looking for a a/c compressor (22re) email me if you find any thing reverendheumader at gmail
83' fj60 white
04' tacoma silver
the_white_shadow
I am looking for one 4wd emblem that goes on the fenders of first gen 4x4 trucks (79-83) shipped to 77435?
Lucas
4XFlyin
Need this clear lense shipped to 91307. Passenger side.
82 1st Gen with 4.3L vortec and 4l60e. Linked front and rear
My build up. Getting linked
http://board.marlincrawler.com/index.php?topic=50700.msg711361#msg711361
SUNSETJOE
4WD fenders, driver and passenger for a 84-88 shipped to 91945.
Toymin8r
ajordan1975
84xcab
Bobbed 84 xtra cab, pickin up parts as I go.
If at first you do not succeed, put it in 4low and try again.
MR.FULL-FORCE
How much would an efi setup for first gen?
girlzlikemud2
girlzlikemud2
PismoJoe
Hey I'm looking for a stock exhaust manifold for an 86 22RE. It just needs to have the O2 sensor bung on it, and no cracks. Intact studs would be a plus! Thanks!
girlzlikemud2
Quote from: PismoJoe on July 03, 2010, 08:34:31 PM
I PM'd you. Thanks!
Gixxer Jon
driver side brake light lens for an 85
ifs ebrake cable, (second half) connects from brake drums to bracket by gastank
Hillcrest Crawlers
_________________________________
||_________||_________||__TOYOTA_||
||_________||_________||__________||
http://board.marlincrawler.com/index.php?topic=67011.0
ae racer
#1221
'88 4runner
I need the sensor for the gas gauge (or whatever will fix the following prob) b/c after mine drops below 3/4 tank, it goes straight to E
also need the starter coil and "computer" (or whatever its called) that is mounted on top of it (mounted on the drivers side front fender) maybe called starter switch and igniton relay?
and i might need some a/c parts..just not sure what yet (need to get in there and check it out)
Reynolds
I need a top shift transfer case shifter with the base. Price shipped to 94568, please :)
-Brian
girlzlikemud2
Quote from: Jon S on July 06, 2010, 12:58:14 AM
I PM'd you. Thanks!
paulj
How much for a couple of 1984 5.29 8" toyota thirds shipped to 65775? Thanks
Peterbuilt84
How much for a driver side wing window regulator and 4 door hinges to 95076
toyman2210
need a complete interior from a 79-83 reg cab pickup, complete wiring harness from tail lights to horn. Also need just about every piece under the hood. motor trans and tcase as well. Maybe just a whole donor truck 79-83.
"It Happened!!"
sokoji
How much for a 4x4 gray shift boot out of a 3rd gen?
1981 SR5 4x4 Longbed
PismoJoe
Hey Jennifer, thank you so much for the fast shipping at great looking exhaust manifold! Thanks again!!
trekkerpaul
I am looking for the stock mud flaps for the 79-83.  I need the passenger rear bracket too.  The mud flaps I need have the pointed top.  Please PM me.
