Could be a number of things, solo or together, Aligment, caster,tires out of balance or out of round, shot shocks, trunion bearings to loose, wheel bearings to loose, shackles to loose, bushings shot, U-bolts loose, center bolt on springs loose or broken, those are most of them that I can think of. I would bet it is the caster is off, what size shackles are you running? What is the drop on your front spring hanger. Start with finding out what your caster angle is.
not old... experienced....
The top of my tires seem to lean out on my solid axle. Is this normal? I have replaced all bearing and seals in everything.
Started by gferris5 General 4WD Discussion
Started by 85yotabox General 4WD Discussion
Started by Rock4Runner General 4WD Discussion
Started by spc mike Engine
Started by Kenbhc Project Research and Build-Ups
